Old 12th May 2009, 22:16   #21  |  Link
rotty
1.10.5
Same result with tsmuxer 1.10.5, It says it does not recognise some files and will ignore them, (these being the extra sub files).
rotty is offline   Reply With Quote
Old 7th June 2009, 14:50   #22  |  Link
rotty
no result
Originally Posted by micha019 View Post
Did no one find a solution?
I have the same Problem like rotty with mummy as blu-ray.
Did you find a soloution to this problem. I sent quite a few private messages to Roman (tsmuxer) but didnt get a reply
Old 25th September 2009, 10:35   #23  |  Link
chompy
Sorry to bring this old post up, but has anybody found a solution to extract text subtitles?... Are they in the .m2ts file or are they in any other file?
Greetings
chompy is offline   Reply With Quote
Old 25th September 2009, 14:56   #24  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
You can probably use tsRemux and demux the subtitle stream. If you succeed drop me a PM.
Old 25th September 2009, 18:15   #25  |  Link
chompy
The "problem" is that subtitles from #33 to #68 are in separate streams: the first 32 subtitles are in main movie stream (00000.mt2s), but subtitle #33 is in 00001.m2ts, subtitle #34 is in 00002.mt2s...
tsRemux opens these m2ts streams that only contain the PGS subtitle perfect, but the only optin available are to remux them to .ts, .m2ts and bluray so the problem is the same as I cannot demux the stream to get the .sup
If I try to open these streams with tsMuxer, I get the message of "Unsupported format" and it cannot find any track.
Finally I've tried eac3to which also finds the PGS subpicture, but if I use the -demux parameter I get this error: "The source file doesn't contain any video/audio tracks. <ERROR>"
Do you know any software that doesn't need video/audio tracks in a m2ts in order to demux it?
Greetings
Old 25th September 2009, 18:18   #26  |  Link
deank
deank's Avatar
If tsRemux detects these text subtitles just right-click the subtitle stream and select to demux/save in elementary stream (ES) or program stream (PES).
Text subtitles ARE NOT SUP subtitles - don't confuse both formats. SUP are pictures, Text subtiels are TEXT
Old 25th September 2009, 20:01   #27  |  Link
chompy
Ok, lots of thanks for the tip. Extracting as ES results in a 1KB file with no data, extracting as PES I get the subtitles but I don't know wich format they have (I've uploaded the original mt2s and the resulting PES here so if you want, you can give me a hand with it).
Now I only need to know how can I remux these subtitles with the movie, as for example tsMuxer doesn't support neither tsRemux does (only SUPread streams seems to be supported).
Greetings
Old 25th September 2009, 20:20   #28  |  Link
deank
deank's Avatar
Right
But the files you sent can be converted to SRT and then be accepted by tsMuxeR or multiAVCHD.
edit: It is the first time I see a text subtitle stream, but it is obvious that it can be converted to SRT, since you have all the text in the .m2ts file... the problem is 'timings'...
Old 25th September 2009, 20:36   #29  |  Link
chompy
So you mean that this text subtitle stream has an unknown format and I have to manually convert to SRT and set its timings?... Because do you know any way to link via BDedit the m2ts with the movie remuxed and the original m2ts containing the text subtitles?
Old 25th September 2009, 20:40   #30  |  Link
deank
deank's Avatar
I said it is not a big deal to convert the extracted stream (or directly from m2ts) to SRT subtitles.
If you need to change it and re-mux it -then it may be a problem. Of course it is possible just to edit the m2ts file if you want to translate the subtitles or anything...
edit: since I think it will brake the rules of the forum, please PM me with the playlist (mpls) files that refer this text-subtitle m2ts so I can take a look at the timings and check if I can make it generate a simple SRT file with timings (i.e. extract text subtitles from the m2ts to srt)
Old 25th September 2009, 21:48   #31  |  Link
chompy
I'm sorry but no mpls refer to these text subtitles streams, so I think timing is defined in the subtitle itself.
I'm looking to BDedit trying to find how these text subtitles m2ts are linked to the main movie m2ts, but I a neeb and it's quite hard... A debugger similar to DVD-Remake would really help (maybe in a future release ).
If I send you index.bdmv and Movie Object.bdmv could help in any way?
Old 25th September 2009, 22:01   #32  |  Link
deank
deank's Avatar
No, bdmv files won't help.
m2ts file is referred as normal or 'subpath' in some of the playlist files - it is for sure - how did you find it then if you can't find it in a playlist file?
And the playlist is only needed to define the start-time of the playlist, otherwise the information for subtitle display time is usless (or it will be off with 0-30 seconds, which of course is easy to correct with Subtitle Workshop).
Old 25th September 2009, 22:09   #33  |  Link
chompy
You're right I missed looking all subpath in main movie playlist (I only looked at first entry)... Oh, and I found it just checking each m2ts
You have a PM
Old 25th September 2009, 22:19   #34  |  Link
deank
deank's Avatar
Thanks... Let me take a look at it and post back later (since it is 00:20 here)...
Old 25th September 2009, 22:24   #35  |  Link
chompy
Thanks to you, and don't worry I don't need it urgently (here it's just one hour earlier, 23:24h now)
Old 26th September 2009, 13:46   #36  |  Link
deank
deank's Avatar
textST
I wrote a small tool to process .pes files extracted with tsRemux or directly the original m2ts files with text subtitles...
Here is what came out of yours:
Detected 41 presentation marks:
001 00:02:29,538 00:02:33,000 -> What are you doing here?
002 00:02:51,227 00:02:53,771 -> Who has touched you?!
003 00:03:00,778 00:03:01,862 -> Imhotep?!
039 01:49:21,986 01:49:23,446 -> Give me that book!!
040 01:49:37,668 01:49:39,796 -> Now you die.
041 01:50:30,471 01:50:32,723 -> Now it's your turn.
00:02:29,538 --> 00:02:33,000
2
00:02:51,227 --> 00:02:53,771
3
00:03:00,778 --> 00:03:01,862
Imhotep?!
39
01:49:21,986 --> 01:49:23,446
Give me that book!!
40
01:49:37,668 --> 01:49:39,796
Now you die.
41
01:50:30,471 --> 01:50:32,723
Now it's your turn.
I haven't used the presentation times from the playlist file, only those in the textST stream, but if you can compare with the movie - let me know if they fit at all.
textST (CLI) (630KB) self extractable 7z archive (contains calclib.dll and textST.exe), or if you're using multiAVCHD then you can download just the executable textST.exe (80kb) and put it in your multiAVCHD folder.
Drag-drop your .m2ts or .pes file to textST.exe - it will create a .srt file, or if using command prompt:
textST in_file [out_file]
* in_file must be in .m2ts or .pes format, containing only textST text subtitle stream (one per file)
* out_file if not set, output will be written to in_file.srt
It does quite basic parsing, ignoring styles, fonts, positions and other information, extracting only the text and timestamps.
Dean
Old 26th September 2009, 15:36   #37  |  Link
chompy
Lots of thanks for this great software... Unfortunately, the times don't match with the film. I'm not 100% sure, but looking at the times I think that maybe some 50fps -> 24fps time conversion should help.
Greetings
Old 26th September 2009, 15:38   #38  |  Link
deank
deank's Avatar
Yep.. you can download the .exe only and try again... it was using 45khz multiplier instead of 90khz.
Old 26th September 2009, 16:21   #39  |  Link
chompy
Lots of thanks again!!
I see that you've also fixed the time format in the srt. I'll try it again tonight in a new remux (I have to leave for 3 hours) and give you me feedback.
Greetings
Old 26th September 2009, 16:31   #40  |  Link
deank
deank's Avatar
I compared the output with some .srt subtitles I found on the internet and it seems that it is now okay... It is possible that a start-offset / delay has to be applied, but once you compare it with your movie you will let me know if there is need for adjustment.
Yep, I fixed the dot (.) back to comma (,) as it should be in SRT - just overlooked it the first time.
Dean
