9th October 2012, 21:28 | #14581 | Link |
That's quite interesting. Won't that change the look of the image a bit, though?
What happens if I simple ignore that some values may lie outside of the [0,1] range? Will I get wildly inaccurate results, like division by zero, infinity or something like that? |
9th October 2012, 21:29 | #14582 | Link |
Nicolas Robidoux
Question: Wouldn't it be better to simple "linearize" the Y channel and only sigmoidize that?
(I need to reread these various definitions. Is Y' physically a linear light channel (luminance) or a gamma-encoded light channel (luma)? P.S. Just reread. So, you normally work and enlarge in a perceptual space (R'G'B'). The formulas I gave assumed that I was working with physically linear light channels. Apparently you can convert to some form of linear light (light RGB with something-something-something primaries). But maybe this is a waste. ----- Need to think. Maybe some form of the dirty hack would turn out better in the end? P.S. Something like: Y'CbCr -> R'G'B' -> negate -> pretend it's RGB -> R'G'B' -> resample -> RGB -> negate -> "retag" as R'G'B' -> Y'CbCr ? P.S.2 How does gamma correction handle negative values? By clamping? Last edited by NicolasRobidoux; 9th October 2012 at 21:52. |
9th October 2012, 21:42 | #14583 | Link | ||
Nicolas Robidoux
For example, assuming no rounding error, nearest neighbour would give the same result with all variants. However, it changes somewhat how sigmoidization affects the result, just like going through linear light or La*b* to upsample would affect the result. But someone could argue that it's an as good, or better, sigmoidization. I don't really know. Quote:
----- In ImageMagick, this is fixed by clamping the argument of atanh to [-1+MagickEpsilon,1-MagickEpsilon]. You would not lose all the blacker than black and whiter than white, esp. when the contrast is low. But with high contrast, you may lose a chunk of whiter than white. The solution works within ImageMagick because we're mostly concerned about sRGB and it converts to and from linear RGB with sRGB primaries without over- and undershoots. Last edited by NicolasRobidoux; 9th October 2012 at 21:53. |
9th October 2012, 21:42 | #14584 | Link | |
9th October 2012, 21:46 | #14586 | Link | |
9th October 2012, 22:00 | #14587 | Link |
Nicolas Robidoux
Mathias:
This is exciting. And I think that we both understand and agree that the issue is how to handle values that go "out of nominal gamut" without diminishing the ability of sigmoidization to enhance what's within the nominal gamut. |
9th October 2012, 22:10 | #14588 | Link |
Nicolas Robidoux
Mathias:
I just clicked on something: It should be easy to compute a maximum allowable contrast ("a") that guarantees that things don't go to hell. The maximum allowable contrast would depend on A and B in an elegant way. Then, sigmoidization would be "intact". There just would be "less of it" when there is a possibility of large overshoots. ----- The simplest fix is simply to clamp like in ImageMagick. If the clamping messes things up, we should be able to see it. I'm a bit concerned that we are messing up sigmoidization by trying hard to preserve outliers (very large whiter than white, for example). |
9th October 2012, 23:55 | #14589 | Link |
Nicolas Robidoux
Mathias: I think that my "one multiply-add at the beginning, one at the end" is probably a pretty good solution, in part because giving more intense sigmoidization near darks (which is the case since A apparently is generally quite close to zero) may match what's best given the HVS: We're less sensitive to light halo because our eyes are more sensitive to darks.
----- Otherwise, I think that the clampling solution built into ImageMagick would be both good and simple. All it is is clamping -s+(2.0*s)*x to the interval [-1+fudgeEpsilon,1-fudgeEpsilon] before feeding to atanh. No more and no less. Part of why I think this may work well is that even for the huge overshoot you estimated, namely 1.2143440435408780674380747705496, you'd need contrast > 3.468 before any clamping occurs. Sure, I like something like 7.5. But we are not talking orders of magnitude. This being said, with contrast=7.5, clamping will start at 1.024 or so. ----- I have a third solution, but I'll leave it out until I know better whether the above two work or fail. Last edited by NicolasRobidoux; 10th October 2012 at 00:05. |
10th October 2012, 00:05 | #14590 | Link |
I have a little problem:
I created a custom resolution with 59,94 Hertz and added it and the native 60 Hertz resolution to the madVR display modes list (both 1280x1024). It works well with 720p59,94 and 1080p60 videos but for a 1080p59,94 it refuses to choose 59,94 Hertz. What's going wrong? |
10th October 2012, 00:40 | #14592 | Link | |
Nicolas Robidoux
Now: Sigmoidization is a method that I invented less than 3 months ago. So I don't know everything there is to know. Let's assume that you use the "clamp the argument of atanh" like it's done in ImageMagick. Otherwise contrast values are not really comparable. My hunch is this: Given that: 1) You actually "come from" Y'CbCr, not sRGB 2) Your luminance channel is better resolved. (Is it?) 3) Your video images are generally somewhat "soft" (by DSLR standards) I would say that it is quite likely that contrast 11.5 is almost always safe. Maybe even 12. I'd consider, however, using the slightly larger LanczosSharp deblur I discuss earlier in this thread and in my new ImageMagick recommendations: Let sigmoidization take care of "tightening things" and let EWA Lanczos take care of "smoothing things". If people start complaining about something, it will be this: They will notice that sometimes a colour that has a very high component (say R=255) mixed in with more midtone-like values in the G and B channels will "bleed" near sharp interfaces. Same if you have R=0. What's happening is that the extreme colour values are "sharpened" differently by the low pass filter than the midtones, and mixed extreme/midtone interfaces thus are "rolled up" differently in the three channels. Fixing this would be hugely complicated... sRGB does this too. All the perceptual color spaces, actually, to the best of my understanding. But then enlarging through linear light sucks! ----- If you use the [A,B] gamut control "system", I'd say you may want even higher sigmoidization. Does my answer make sense? (You understand that I'm the one who invented EWA LanczosSharp in all its mutliple variants, yes? Was kind of an obvious extension of what people had done before, and Anthony Thyssen and Fred Weinhaus, as well as publications by Gustafson and deForest, were strongly pointing in the right direction, but still. I'm the one who finally put all the pieces together, and then added "optimizing the deblur" to the mix, mostly in response to Anthony Thyssen's knowledgeable list of shortcomings of the earlier ImageMagick implementation.) P.S. TTBOMK I'm the one who finally got is just right. If anybody knows of predecessors I should acknowledge, by all means, please point me to them. "As usual," Paul Heckbert and associates got this going. At some point I may take the time to carefully track down everybody who had pieces of this lying around. Last edited by NicolasRobidoux; 10th October 2012 at 15:06. |
10th October 2012, 02:14 | #14593 | Link | |
AMD Radeon 6570/1GB DDR3 Driver ver. 12.8 MPC-HC or MPC-BE (latest versions) LAV Filters: 51.3-120 Windows 7 and Windows 8 test – identical systems (64 bit) Official 0.84.2 Windowed Mode Interlaced: BAD Progressive: BAD FSE Mode Interlaced: GOOD Progressive: GOOD 0.84.2 – special madVRblackjack test build Windowed Mode Interlaced: CRASH Progressive: BAD (4 plus jumps = dropped frames and buffers don’t fill) FSE Mode Interlaced: CRASH Progressive: GOOD Go back to 0.82.5 and all is GOOD...
MPC-HC and MPC-BE (latest), MadVR 0.92.17, LAV 0.73.1 Intel NUC w_650 internal, Roku Ultra, Nvidia Shield, Apple TV 4K PLEX Server with QUADRO 2000 Windows 10 Pro (all latest updates) |
10th October 2012, 06:02 | #14594 | Link | |
Shader support sounds exciting but my experience is avisynth can do everything shaders can do and often better, except madvr's anti-ringing, you did a great job on it! Sharpen complex is bested by simple avisynth sharpen() imo and deband shaders aren't effective at all. Shaders shift cpu load to gpu which is a plus but kind of irrelevant with madvr loading the gpu more than cpu. 3D support sounds nice for those that have 3DTV's are you talking SBS, Top/Bottom, both can be done via avisynth, or is it something else? Here's parking meter 4x upsize test with -1 and 0 blur if you want to take a look, it's more of a difference then the pic's I posted earlier. Here's hoping you haven't given up on it. Vapoursynth is cross platfrom and requires avisynth plugins to be rewritten. |
10th October 2012, 08:07 | #14595 | Link | |||||||||||
If the tweak settings are not the problem, would you mind creating another debug log or 2 or 3? Please seek until you get those frame drops, then let it run for ca. 10-20 seconds, then close the media player. Please don't reseek after you achieved the frame drop situation. That will make it easier for me to find the right location in the monster sized log files. Please also use a progressive source, that makes the logs a bit easier because no deinterlacing is performed. Thanks! Quote:
(1) Extend the settings records. (2) Modify madVR to read, write, understand and use the new setting. (3) Probably add a toggle keyboard shortcut. (4) Make sure the setting is only available for cubic algorithms. (5) Change my resampling weight calculator to support custom blur. (6) Think about how to make the dropdown work with Bicubic, SoftCubic, CatmullRom and Mitchell. Using the same blur value for all wouldn't work because they have different blur values on their own. Of course it would be possible to limit negative blur capability to Bicubic, only. All added up it might easily take 2-3 hours. More if I'm stupid and introduce bugs. Add to that that the user interface gets more complicated again, which means that new users will ask not only "which is the best algorithm" but also "which blur factor should I use" etc. I prefer the idea to offer a fully configurable cubic resampler, which could replace all the other cubic based algorithms (Mitchell, Bicubic, Catmull-Rom, SoftCubic). But then, that would definitely be a settings for experts, only, and will have to wait until I have separate beginner/expert settings. Quote:
Look, if I knew a way to support negative blur without making the settings dialog more complicated, I would consider it. Maybe I will add it in the future when I find the time to do separate settings dialogs for noobs and experts. But for now I don't want to implement it because I don't want to spend that time and because I don't want to make the settings dialog more complicated. Just have a bit of patience. Quote:
10th October 2012, 11:35 | #14597 | Link | |
ASUS H97 Plus, Intel i5-4690 2.50Ghz, 16GB DD3 1600, XFX R9 270X 2GB DDR5, LynxTwo B Win 8.1 Pro with WMC 64Bit, Kodi, MPC-HC 1.7.8, LAV 0.65.0, Reclock 1.8.8.5, HD AnyDVD |
10th October 2012, 11:56 | #14598 | Link | |||||
Nicolas Robidoux
This can be done with a "knob" that changes the deblur of the filter, like actually used with Jinc right now, except hardwired to .98... P.S. (I realize that you probably have this figured out already.) Actually, some DSLR people have gotten acceptable results doing this with tensor Lanczos as well (Lanczos 3 with roots spaced tighter than 1 by scaling the support of the filter), which will make some people shudder in horror big time, when downsampling. But it appears that careful USM or other sharpening is better, at least when downsampling. (The jury is still out.) Quote:
What do you think? Quote:
Honest advice: Use your eyes, and the eyes of your users. There is a possibility that BluRay people ask you to back this down. Or that some people ask for more of this "strange halo free sharpening". Or that some people will want less of it even when enlarging somewhat blurry images. 11.5 is a good, solid, pretty strong value. Maybe a little too strong? Probably not with enlargements of slightly blurry images that can't be scrutinized because they go by at 30fps. But remember that sigmoidization, as a resampling technique, is not even 3 months old. You're in terra incognita. Yes. Quote:
So, I could explain sigmoidization purely "physically", but actually I think it works well partly because it connects to the perceptual: "Midtone" halos don't offend us. "Extreme" ones do. This is why I can fake sigmoidization with linear RGB -> sRGB -> linear RGB conversions + inversions (going "through the photo negative"). What I'm doing, in a sense, is symmetrizing the perceptual spaces so that white does not creep too much into the darker end, in other words, I'm symmetrizing w.r.t. black <-> white interchange. Will read the rest after making coffee for my wife! ----- My earlier LUT advice was backward. Will fix in a later post. Last edited by NicolasRobidoux; 10th October 2012 at 14:08. |
10th October 2012, 13:13 | #14599 | Link | |
Nicolas Robidoux
Will need to think of the consequences. I think it may be equivalent to the "two multiply-add" suggestion, saving flops. Basically, it's like simplifying the fraction (I think). |
10th October 2012, 13:40 | #14600 | Link |
Nicolas Robidoux
Mathias:
RE: "Is sigmoidization perceptual?" Near the dark end, the lightly truncated logistic curve (same as tanh, really) approximates a gamma correction curve (or it's inverse: depends how you define forward/backward). |
