Old 11th February 2009, 22:28   #1001  |  Link
miloka
.....one more donator
miloka is offline   Reply With Quote
Old 11th February 2009, 22:38   #1002  |  Link
asherungar
Hi dean,
i tried with 1 episode and the same thing happens, in the menu if i choose title 1 it goes back to the menu.
besides that - 3 mts files are for the movie in stream folder, 1st is 33 mins - works when played straight from the PS3. 2nd is 1 hour and something (should the larger one be first?) but it is the second part of the movie - but no sound when playing straight from PS3!! and third part 10 mins - just stuck, nothing moving when played straight.
here's my log:
[22:22:57] Log started for multiAVCHD v2.3 (build 367)
[22:22:57] Processing 1 input files/folders .
[22:22:57] Converting mkv file to AVCHD (H:\movies\folder\movie.mkv).
[22:22:58] Detected video: ID#1:V_MPEG4/ISO/AVC:1920x1080 25.000fps (AR:1.78)
[22:22:58] Detected audio: ID#2:A_AC3:audio (48000Hz/2ch) Language: eng
[22:22:58] Detected subtitles: ID#3:S_TEXT/UTF8 Language: eng
[22:22:58] Detected subtitles: ID#4:S_TEXT/UTF8 Language: heb
[22:22:58] Generating meta file for tsMuxer...
[22:22:58] M2TS stream split set at 3999MiB...
[22:22:58] Searching for original chapters (mediainfo)...
[22:22:58] None found. Inserting 5 min chapters...
[22:22:58] Detected frame reference count: 3 (max:4).
[22:22:58] Compliant with L4.1 for 1920x1080p.
[22:22:58] Creating BluRay folders (tsMuxer)...
[22:34:47] Done!
[22:34:48] CLPI transfer: H:\multiAVCHD\_TEMP\20090211-222258-4888\BDMV\CLIPINF\00001.clpi -> G:\AVCHD\BDMV\CLIPINF\00000.clpi
[22:34:48] M2TS transfer: H:\multiAVCHD\_TEMP\20090211-222258-4888\BDMV\STREAM\00001.m2ts -> G:\AVCHD\BDMV\STREAM\00000.m2ts
[22:40:01] CLPI transfer: H:\multiAVCHD\_TEMP\20090211-222258-4888\BDMV\CLIPINF\00002.clpi -> G:\AVCHD\BDMV\CLIPINF\00001.clpi
[22:40:01] M2TS transfer: H:\multiAVCHD\_TEMP\20090211-222258-4888\BDMV\STREAM\00002.m2ts -> G:\AVCHD\BDMV\STREAM\00001.m2ts
[22:45:15] CLPI transfer: H:\multiAVCHD\_TEMP\20090211-222258-4888\BDMV\CLIPINF\00003.clpi -> G:\AVCHD\BDMV\CLIPINF\00002.clpi
[22:45:15] M2TS transfer: H:\multiAVCHD\_TEMP\20090211-222258-4888\BDMV\STREAM\00003.m2ts -> G:\AVCHD\BDMV\STREAM\00002.m2ts
[22:45:38] MPLS transfer: H:\multiAVCHD\_TEMP\20090211-222258-4888\BDMV\PLAYLIST\00000.mpls -> G:\AVCHD\BDMV\PLAYLIST\00000.mpls
[22:45:38] Old pointer to 00003.m2ts in 00000.mpls now set to -> 2
[22:45:38] Old pointer to 00002.m2ts in 00000.mpls now set to -> 1
[22:45:38] Old pointer to 00001.m2ts in 00000.mpls now set to -> 0
[22:45:38] Preparing authoring information...
[22:45:38] Creating NTSC top menu.
[22:45:38] Authoring custom titles menu (NTSC).
[22:46:00] Encoding menu pages (x264)...
[22:46:39] Muxing h264 stream for menu pages (tsMuxer)...
[22:46:39] Populating menu structure...
[22:46:40] Encoding navigational pages (x264)...
[22:47:12] Setting navigational buttons behaviour...
[22:47:26] Authoring custom menu completed.
[22:47:26] Authoring custom welcome screen (NTSC).
[22:47:26] Encoding welcome screen (x264).
[22:48:27] Populating welcome screen structure...
[22:48:27] Authoring custom welcome screen completed.
[22:48:28] Setting menu for 1 titles...
[22:48:28] New offset for m2ts#1 -> 2
[22:48:28] New offset for mpls#1 -> 00000
[22:48:28] Setting titles #2 to #40 to point at top menu.
[22:48:28] Setting custom titles menu...
[22:48:28] Processing clip (CPI/CLPI) files...
[22:48:28] Completed.
[22:48:28] Creating AVCHD compatible 8.3 filenames...
[22:48:28] Done!
[22:48:28] G:\AVCHD folder created!
[22:48:29] Rename G:\AVCHD to AVCHD and copy it to root of USB drive or USB disk.
[22:48:29] or rename G:\AVCHD to AVCHD and copy it to X:\PRIVATE\ of SD/MMC card.
Hope you can find something wrong?
im using NTSC menu (the movie itself is 25 fps).
Thanks!
Last edited by asherungar; 11th February 2009 at 22:39. Reason: removed name of the movie
asherungar is offline   Reply With Quote
Old 11th February 2009, 22:46   #1003  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
I remember someone said earlier that PAL PS3 consoles are capable of playing PAL and NTSC content, but NTSC consoles can't handle PAL (25fps) content.
If you pass your file thru tsmuxer does it play on your PS3?
My (PAL PS3) plays everything, no matter if I choose PAL or NTSC menu or content.
Old 11th February 2009, 22:50   #1004  |  Link
asherungar
Ok, I'll try that tomorrow, thanks for the quick answer!
Old 11th February 2009, 23:52   #1005  |  Link
jdeiro
Brazilian PS3 Fanboy
Dean,
Whenever I try to edit the custom title (clicking edit on the media tab), the program crashes.
Will post the exact description of the error popup ASAP.
BTW, I'll donate next week, I promise!!
Forget about it, it stopped happening.
Cheers!
jdeiro is offline   Reply With Quote
Old 12th February 2009, 01:08   #1006  |  Link
~bT~
н∂-ƒαиαтι˘
Originally Posted by deank View Post
Yes, but AVCHD standard says that you can have 720x resolutions both 16:9 and 4:3, so we are missing something.
Can you send me a sample video of your encodes? I have captures of 720x576 (PAL) 4:3 and I can't make them play 4:3 - they play horizontally stretched in my PS3 - so I have the opposite problem
Dean
pls test: http://www.mediafire.com/?sharekey=3...db6fb9a8902bda
Old 12th February 2009, 06:37   #1007  |  Link
kenguru2005
FinalCut´ter
kenguru2005's Avatar
Hi Dean,
367 fixed it: now even my 1080i25 mov footage get´s its second audio track. No more REPLACING, now it´s an ADDING. The best would be, to let the people decide, if they wanne REPLACE or ADD an extra audio track.
kenguru2005 is offline   Reply With Quote
Old 12th February 2009, 09:40   #1008  |  Link
deank
deank's Avatar
Originally Posted by ~bT~ View Post
pls test
The file you've sent me (720x480) plays perfectly in 16:9 in my PS3.
[10:35:19] Log started for multiAVCHD  v2.3 (build 367)
[10:35:19] Processing 1 input files/folders .
[10:35:19] Converting mkv file to AVCHD (D:\Test 720x480p.mkv).
[10:35:19] Detected video: ID#1:V_MPEG4/ISO/AVC:720x480 23.976fps (AR:1.5)
[10:35:19] Detected audio: ID#2:A_AC3:audio (48000Hz/6ch) Language: eng
[10:35:20] Using original chapters.
Old 12th February 2009, 10:34   #1009  |  Link
~bT~
н∂-ƒαиαтι˘
did u use force 16:9 dean?
Old 12th February 2009, 10:39   #1010  |  Link
deank
deank's Avatar
I tried both with checked and unchecked. Both times PS3 plays it fine.
If unchecked - TMT displays wrong AR.
If checked - TMT plays it in 16:9.
Old 12th February 2009, 10:43   #1011  |  Link
~bT~
н∂-ƒαиαтι˘
^ can u try nero with checked pls??
Old 12th February 2009, 10:45   #1012  |  Link
deank
deank's Avatar
I did... but it looks weird... 2 black bars - top and bottom and 2 vertical black bars.. and AR is not 16:9 but not 4:3 either...
Looks the same with forced 16:9 and not.
Old 12th February 2009, 10:58   #1013  |  Link
kenguru2005
FinalCut´ter
Originally Posted by kenguru2005 View Post
Hi Dean,
i.e.:
option 1: add additional audio track
option 2: replace existing audio track
Old 12th February 2009, 11:20   #1014  |  Link
deank
deank's Avatar
It is added in build 369
Old 12th February 2009, 11:20   #1015  |  Link
~bT~
н∂-ƒαиαтι˘
how to solve that or is there any other player i can use? apart from TMT or PDVD.
Old 12th February 2009, 12:09   #1016  |  Link
kenguru2005
FinalCut´ter
Perfect ... will test it this evening ...
Old 12th February 2009, 12:12   #1017  |  Link
deank
deank's Avatar
Go to Options / Video (Nero Showtime) and uncheck [x] Keep aspect ratio...
Then you can stretch video manually until it fits the correct AR.
Build 370:
* Some options are rearranged
* Bug was fixed - incorrectly setting 720p in clip files for 720x.... videos if Force 16:9 checkbox is used. Now 480p and 576p will be set properly.
* Added support for external AAC audio tracks.
* Added option to keep only external audio tracks
* Fixed: importing files with names, containing only zeroes - not showing in Title editor
* Fixed: when using "Delete" button in media tab - Title editor didn't show titles correctly
* Fixed: now colon ":" can be used in Title names in title editor
* Fixed: cutting last four letters of imported files names
Dean
Old 12th February 2009, 12:47   #1018  |  Link
~bT~
н∂-ƒαиαтι˘
^ thanks again dean.
Old 12th February 2009, 12:56   #1019  |  Link
deank
deank's Avatar
You're welcome...
Compiling menu process is now about 10 times faster.
Old 12th February 2009, 12:57   #1020  |  Link
~bT~
н∂-ƒαиαтι˘
that was the 1st thing i noticed. nice.
edit: is aac supported?? in avchd?
