5th May 2021, 05:18 | #882 | Link |
Pig on the wing
If you use Prefetch, remove the ncpu parameters from your script. Otherwise you'll be multithreading on the script and function level simultaneously, which is inefficient.
21st September 2022, 06:54 | #884 | Link | |
Formally known as .......
I thought I'd have a look on this section of the Forum, and found this post:- http://forum.doom9.net/showthread.ph...27#post1942127 has a problem with Line 711, but different. I might try that script....why would it work with Staxrip, and not RipBot ?!?!? EDIT:- I got it to work Last edited by TDS; 21st September 2022 at 07:25. |
21st September 2022, 08:08 | #885 | Link | |
21st September 2022, 10:54 | #891 | Link |
I'm pretty sure I'm running the latest, tho..I'll check.
So which one should I use:- http://avisynth.nl/index.php/GradFun2DBmod OR https://github.com/Asd-g/AviSynthPlu...Fun3DBmod.avsi Last edited by TDS; 21st September 2022 at 10:59. |
21st September 2022, 11:39 | #892 | Link | |
https://github.com/realfinder/AVS-St...Fun2DBmod.avsi |
21st September 2022, 12:16 | #894 | Link | |
https://forum.doom9.org/showthread.p...26#post1974926 |
21st September 2022, 12:32 | #895 | Link | |
28th September 2022, 15:55 | #896 | Link |
How do I get the this new MCTD version working? From here: https://github.com/Asd-g/AviSynthPlu...ter/MCTD_.avsi
I started down the rabbit hole of updating all the dependencies... I got to it complaining about ex_lut missing. Got the ExTools.avsi from here and now: Edit: Fixed. I guess my AVSynth+ version was too old. I updated to 3.7.2 and now that error went away and I can use MCTD_. Last edited by Stereodude; 28th September 2022 at 16:17. |
28th September 2022, 16:48 | #897 | Link |
What are you guys doing about LSFmod? If you have sharpening enabled in MCTD, LSFmod will puke on something that's not YV12.
The LSFmod version linked from the wiki has an explicit check for YV12. The newer version here from TheChaosCoder has a statement on line 419 of: sisphbd = AvsPlusVersionNumber > 2294 That throws an error "I don't know what 'AvsPlusVersionNumber' means." I can modify LSFmod to force sisphbd = true and then MCTD works with sharpening enabled, but it feels pretty half baked. |
28th September 2022, 16:53 | #898 | Link |
I think you need current Zs_RF_Shared.avsi for 'AvsPlusVersionNumber'.
(real.finder) EDIT: Maybe here:- https://github.com/realfinder/AVS-Stuff
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 28th September 2022 at 16:57. |
28th September 2022, 17:17 | #899 | Link | |
https://raw.githubusercontent.com/re...RF_Shared.avsi |
28th September 2022, 18:16 | #900 | Link |
While I'm excited to finally have a high bit depth capable version of MCTD, I have to nitpick a bit. No newbie is ever going to get this version up and running chasing down all the right version of all the dependencies.
Also, how well tested is the high bit depth support? Like I noticed the sharpening becomes less apparent the higher the bit depth. At 16 bits you can't even see it. At 8-bit it's very obvious. |
