26th July 2007, 21:12 | #441 | Link | ||
Nuendo certified Dolby Decoder seems to apply both, DRC and Dialog Normalization. Can be true ,because you can see in the Options from Soft Encode Dolby Decoder and from Digigram, (both older certified Dolby Dec-Enc Versions) that youve few Options to change DRC and Dialog Norm for Ac3 to pcm decoding But You cant change Decoder Options in Nuendo. So Nuendos/Cubase default seems to be DRC/Dialog Norm Output, not nice..all my last AC3 reencodes from last the Years are all from Nuendo 3.2 Anybody know which Decoder Option is 100% "no" DRC AND Dialog Normalization in SoftEncode ? There are following DRC Decoder Options : -Custom Analog /Dialog Norm -Custom Mode / Digital Dialog Norm -Line Out -RF Remod Mode The Softencode wave and RMS Values looks as like as Besweet (no DRC enabled) when RF Remod Mode is active. All other Modes are as like as Nuendo or Tranzcode. I found this : Quote:
Soft Encode Setting at "Line Out" is as like as Nuendo All i want is to find a reference to decode AC3 to Wave "without DRC and Dialog Normalization. Then i can compare TrueHD/EAC3 with AC3 Last edited by ACrowley; 26th July 2007 at 22:11. |
26th July 2007, 22:15 | #443 | Link |
It cant decode it
Q:\test>"D:\_eac3to\eac3to.exe" "Q:\test\PEVOB_1_MERGED.rebuilt. EVO" "Q:\test\PEVOB_1_MERGED.DD.6ch.s03.German 5.1.ac3" -448 -24 Muxing evo's first audio track to raw. Please wait... Converting the raw file to wav. Please wait... Converting the wav file to ac3. Please wait... Aften: A/52 audio encoder Version 0.07 (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. invalid or empty chunk in wav header invalid wav file: -b "aften" reported error code "1". A valid *.wav file was created sucessfully, tho ugh. Q:\test> |
27th July 2007, 07:24 | #447 | Link | |
Yeah..sure. To bad that Nuendo decodes with DRC/DN without Options to change it ( 1000$ Software!) But still 2 Questions : 1. Which Softencode DRC Mode is without DRC/DialogN. ? 2. Besweet Downmix Overflows Its no Problem so far i know..only a warning and is relevant when downmixing to 2Ch right ? greets Last edited by ACrowley; 22nd August 2007 at 23:38. |
27th July 2007, 07:24 | #448 | Link |
Somehow I got it to work.
But theres a problem left... Q:\test>"D:\_eac3to\eac3to.exe" "Q:\test\PEVOB_1_MERGED.DD.6ch.s 03.German 5.1.ddp" "Q:\corpse_demux\PEVOB_1_MERGED.DD.6ch.s03.German 5.1.ac3" -448 E-AC3, 5.1 channels, 1:17:12, 640kbit/s, 48khz Muxing eac3 file to raw. Please wait... The NCBENUM return code is: 0x0 The NCBENUM return code is: 0x0 Audio Decoder output was 24 bit this time. Unfortunately the Audio Decoder has output only 2 channels. Converting the raw file to wav. Please wait... Converting the wav file to ac3. Please wait... Aften: A/52 audio encoder Version SVN (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al. input format: Signed 24-bit 48000 Hz 5.1-channel output format: 48000 Hz 3/2 + LFE progress: 100% | q: 233.2 | bw: 34.0 | bitrate: 448.0 kbps Done. Q:\test> How can I get it to be 5.1? Thanks for your help |
27th July 2007, 07:52 | #449 | Link | |
27th July 2007, 10:00 | #452 | Link | |
But maybe it can cause Problems when you donwmix 5.1 to stereo. But when you decode all channles it will not have any Effect Anway, The Optimum would be to decode AC3 to wave with certified Dolby Decoder. To Bad Nunedo outputs DRC without any Decoder Options ( 1000$!) Soft Encode/Digigram has a Dolby Decoder too ( Dolby Engine too)..but as i say above i dont know wich Option means 100% "No" DRC/D.N Besweet/Foobar is fine so far Last edited by ACrowley; 27th July 2007 at 15:04. |
27th July 2007, 13:25 | #453 | Link | ||
W7: Downmix overflow (1: +0dB) is not related with channels downmix and is produced when the decoder, translating from frequency domain to time domain, reach a value upper to 0 dB and can't be translated exactly. Is not a problem and must be assumed like others imperfections in the encoder/decoder process with lossy formats. Quote:
- Custom digital: DRC + DN - Line Out: also DRC + DN - RF Remod Mode: DRC + Gain (+8 dB in my sample but I don't know the reason) Then RF Remod Mode is not Full Dynamic Range. |
27th July 2007, 13:50 | #454 | Link | |
I made AC3 reencodes from all waves . These Settings should keep alwys Source Volume Level: http://forum.doom9.org/showthread.ph...ght=Sony+Vegas The AC3 Reencode from Azid Waves with disabled DRC/DN sounds perfect Same Dynamics/Wavestructure/RMS Value ,compared with the AC3 Source. Reencodes from SoftEncode "RF Mode Wave" plays at lower Volume in loud Dynamic Parts but a little bit gained...so youre Right I cant find any Soft Encode decoding Mode with all disabled and full Dynamic Range..strange At least you can see in the Screenshot NeroAudioDecoder decodes AC3 with full DRC+DialogNormalization. No Effect from Showtime Options. Sonic applies DRC and or DialogN. too. However , the AC3 decoding Thing is cleared for me. THX Last edited by ACrowley; 27th July 2007 at 15:02. |
27th July 2007, 17:44 | #456 | Link |
Once again with TrueHD ,This is from the 300 HDDVD :
The Decoded Wave has less dynamics as like as the DVD AC 448kbps I tried to change the NeroShowtime Options, but no Effect! I used this AC3 file for my last Test. This AC3 Sample is perfect for a Testrun because it has a lot of dynamic Sounds and a Speech Part http://rapidshare.com/files/45393728...ample.ac3.html EDIT: ...can be true maybe its only DalogNormalization I will compare it with Azid and DialogNormalization Last edited by ACrowley; 28th July 2007 at 04:55. |
27th July 2007, 18:46 | #457 | Link | |
In your previous tests with the Serenity AC3, the first half of the AC3 was significantly compressed with the DRC decoders, but the 2nd half was more or less identical to the non DRC decoders. So there it was clearly visible that the DRC compresses some parts of the track but not everything. In your 300 test I don't see this behaviour. It seems to me that the whole TrueHD decode is just of lower volume. Or am I wrong? Yeah, that's a very good test AC3. Thanks! |
27th July 2007, 19:14 | #458 | Link |
Here are my test results with Nero. I've tried the Nero filters through GraphEdit. And I've also checked what Nero outputs if you use Nero "ShowTime". It seems that the DRC setting in ShowTime does affect AC3 decoding, but only inside of ShowTime. When using the Nero filter in GraphEdit, AC3 decoding seems to have very strong DRC applied. Here are the results:
First wav is "Nero filter in GraphEdit". Second wav is "ShowTime with DRC turned on to 50%". Third wav is "ShowTime with DRC turned off". The third wav looks fine to me. It seems to have dialnorm applied, but no DRC. |
eac3to |
