Old 29th April 2020, 15:41   #5581  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by real.finder View Post
@turment on Telegram
tormento is offline
Old 29th April 2020, 15:54   #5582  |  Link
ChaosKing
The gui is an older release and has a bug where it can mix up 32 and 64bit plugins (fixed in VS version). Use avsrepo for now to be on the safe side. https://forum.doom9.org/showthread.php?t=175822
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
ChaosKing is offline
Old 29th April 2020, 16:09   #5583  |  Link
Zetti
New thread >> AviSynth+ thread Vol.2
https://forum.doom9.org/showthread.php?t=181351
Zetti is offline
Old 29th April 2020, 18:29   #5584  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by pinterf View Post
Unofficial test, grab it from here
Tested and working. A bit faster but perhaps it's placebo effect.
tormento is offline
Old 30th April 2020, 08:19   #5585  |  Link
LigH
LigH's Avatar
^ tormento: So, "imports[64]" like "plugins[64]"?
_
Oops, missed a new page.
New German Gleitz board
LigH is offline
Old 1st May 2020, 07:02   #5586  |  Link
real.finder
Originally Posted by Reel.Deel View Post
Hi everyone, I just want to say thanks to all responsible for the continued work on AviSynth+. There are now over 100+ 64-bit plugins available to use and still a handful missing.
http://avisynth.nl/index.php/Category:Plugins_x64
I just note that Asd did backport SmoothUV and DeDot and DeCross from VS, cool
See My Avisynth Stuff
real.finder is offline
Old 2nd May 2020, 11:00   #5587  |  Link
tormento
Acid fr0g
tormento's Avatar
As I wrote in the vol.2 thread it would be better starting to divide plugins into AVS supported interface versions, thus easing programmers to start a revision of the missing plugins.
tormento is offline
Old 31st May 2020, 16:04   #5588  |  Link
Selur
Selur's Avatar
Using Avisynth+ 3.6 32bit loading:
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\LoadDll.dll")
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\AddGrainC.dll")
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\dfttest.dll")
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\EEDI2.dll")
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\eedi3.dll")
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\FFT3DFilter.dll")
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\masktools2.dll")
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\mvtools2.dll")
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\TDeint.dll")
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\RgTools.dll")
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\PlanarTools.dll")
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\MedianBlur2.dll")
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\nnedi3.dll")
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\nnedi2.dll")
LoadCPlugin("I:\Hybrid\32bit\AVISYN~1\yadif.dll")
LoadDLL("I:\Hybrid\32bit\avisynthPlugins\libfftw3f-3.dll")
Import("I:\Hybrid\32bit\avisynthPlugins\QTGMC.avsi")
Import("I:\Hybrid\32bit\avisynthPlugins\SMDegrain.avsi")
Import("I:\Hybrid\32bit\avisynthPlugins\AnimeIVTC.avsi")
LoadCPlugin("I:\Hybrid\32bit\AVISYN~1\ffms2.dll")
SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE)
# loading source: F:\TestClips&Co\files\interlaceAndTelecineSamples\interlaced\YUV422_sample.avi
#  input color sampling YUY2@8
#  input luminance scale tv
FFVideoSource("F:\TESTCL~1\files\INTERL~1\INTERL~1\YUV422~1.AVI",cachefile="E:\Temp\avi_1deca8d5573c8cb8cd8489678b764f38_853323747_1_0.ffindex",fpsnum=25,colorspace="YUY2")
# current resolution: 720x576
# deinterlacing
ConvertToYUY2(interlaced=true)
AssumeTFF()
QTGMC(Preset="Fast", ediThreads=2)
SelectEven()
# cropping
Crop(16,4,-16,-12)# 688x560
# filtering
ConvertToYV12(matrix="Rec601")
PreFetch(8)
return last
I get:
'I:/Hybrid/32bit/AVISYN~1/PlanarTools.dll' cannot be used as a plugin for AviSynth.
same script works fine with Avisynth+ 3.5 (r3106, 3.5, i386)
Using:
LoadPlugin("I:\Hybrid\32bit\AVISYN~1\SSE2Tools.dll")
# loading source: F:\TestClips&Co\test.avi
#  input color sampling YV12@8
FFVideoSource("F:\TESTCL~1\test.avi",cachefile="E:\Temp\avi_0197468a3716844ade54f3f30f60eeda_853323747_1_0.ffindex",fpsnum=25,colorspace="YV12")
# current resolution: 640x352
# filtering
# grain handling
SMDegrain(interlaced=false)
PreFetch(8)
return last
I get:
Script error: expected `)' ((null), line 1, column 4) (I:\Hybrid\32bit\avisynthPlugins\SMDegrain.avsi, line 879) (I:\Hybrid\32bit\avisynthPlugins\SMDegrain.avsi, line 75) (E:\Temp\tempPreviewAvisynthFile17_00_53_414.avs, line 16)
Line 75 of SMDegrain.avsi is
"sisphbd = AvsPlusVersionNumber > 2294"
which calls line 879:
function AvsPlusVersionNumber()
    IsAvsNeo ? eval(MidStr(VersionString(),20,4)) : IsAvsPlus ? eval(MidStr(VersionString(),17,4)) : 0
-> did I miss some change that broke old plugins and scripts? (couldn't see anything about it in the release notes)
Cu Selur
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Selur is offline
Old 31st May 2020, 16:45   #5589  |  Link
Selur, Get new SMDeGrain and Zs_RF_Shared.avsi from Real.Finder repository:- https://github.com/realfinder/AVS-St...2.5%20and%20up
things changed [everything currently in turmoil].
Also, post in the new thread maybe, this one nearly dead.
StainlessS is offline
Old 31st May 2020, 17:00   #5590  |  Link
real.finder
this thread should closed
and new thread should mention this one as an archive (edit: it's already did)
@Moderators
Old 31st May 2020, 18:14   #5591  |  Link
Selur
Selur's Avatar
@StanlessS: Thanks for the info about the new scripts.
Selur is offline
