20th April 2009, 07:17 | #161 | Link | |
Knowing this clip is progressive 3:2, it needs IVTC, not deinterlacing - you taught me that lesson last time. Because I was seeing different field repeat values depending on the PureVideo setting, I just wanted to know if it affected the outcome. |
20th April 2009, 13:12 | #162 | Link | |
Use the method at the link I gave you. If you see the constant 3:2 field pattern but not all the duplicated fields are done with flags, then the only way for the remaining duplicates to be created is by hard copying.
21st April 2009, 16:35 | #163 | Link |
I am a bit confused. I have donated for a license, can I use this license also for your other tools DGAVCDecNV and DGVC1DecNV?
And since DGDecodeNV works with all three programs (or am I wrong?) why don't you just "merge" them into one powerful application? BTW nice work. Would it be possible to allow multiple selections of the loaded video so we could just ommit the commercials and then just deinterlace and save as mpeg2 ready for dvd authoring?
Xaser III 1000, Seasonic S12+ 650 Watt, Gigabyte EX58-UD5, Core i7 920 , 6GB DDR3 1600 Crucial Ballistix, Gigabyte GTX 470, SSD Corsair Extreme 32GB Win7 64bit,2x150GB VelociRaptors Raid 0. |
21st April 2009, 17:41 | #164 | Link | |||
21st April 2009, 22:24 | #165 | Link |
Thanks neuron, and some last question (since I still wait for the license file so I cannot really test). When I load a m2ts (from HDV camcorder) file and select to enable deinterlacer and I click save and demux the resulting m2v video file is deinterlaced and there is no need to deal with dgdecode.dll and avisynth and cuvid server. Right?
So will the resulting video file be 1440x1080 25p (PAL country here)? The original HDV is 1440x1080 50i (upper field first)
Xaser III 1000, Seasonic S12+ 650 Watt, Gigabyte EX58-UD5, Core i7 920 , 6GB DDR3 1600 Crucial Ballistix, Gigabyte GTX 470, SSD Corsair Extreme 32GB Win7 64bit,2x150GB VelociRaptors Raid 0. Last edited by Fotis_Greece; 21st April 2009 at 23:56. |
21st April 2009, 23:18 | #166 | Link | |
21st April 2009, 23:57 | #167 | Link |
Well, I don't want to frameserve it. Only to deinterlace and demux.
22nd April 2009, 11:03 | #169 | Link |
So in other words when saving and demuxing (with deinterlace checked) the only operationtaken place is just saving project and demuxing the video-audio, right?
2nd May 2009, 15:22 | #175 | Link |
I download TS stream.
Don't ask me "how" This violates the rules Code:
Inverse 3:2 Telecine with Pattern Guidance. If your telecined source material is NTSC 3:2 pulldown, you can enable pattern guidance, which can make the field matching more accurate for some clips. Proceed as follows: AssumeTFF() Telecide(order=1,guide=1) Decimate(cycle=5) |
21st May 2009, 22:05 | #179 | Link |
Trouble with deinterlace=2
I'm having trouble with the hardware bob deinterlacer. When I played back my encoded video, it was stuttering and not smooth. Looking back at the served video frame by frame, I saw that I was getting some duplicate frames often followed by some combed (not deinterlaced at all) frames. I thought that the problem was with my video card (Nvidia GeForce 9650m GT, the m means it is in my laptop) since it often struggles playing 1080i content smoothly. When I tried to use the indexer to clip out a sample to upload, the sample no longer had any combed frames, but still had some of the duplicate frames. By duplicate frames, I mean that it is repeating a frame and then another frame is missing, so no extra frames are being added.
Thinking that my video card was to blame, I tried a similar transcode using some of my video camera's footage (Canon HF100, AVCHD 1080i). However, the hardware deinterlacer seemed to work perfectly with the clips I tried. This leads me to believe that it is some sort of bug in DGMPGDecNV's code. The problems also show up when doing a preview in the index tool. When I get home tonight I'll try putting together some sample clips. I don't think there is anything more I can do until I have access to the original file again, as my first attempt at making a sample didn't reproduce all issues. Thanks. Matt |
22nd May 2009, 00:06 | #180 | Link | |
I don't plan to support MPEG1 video or MPEG1 program streams. Is that a problem? |
