Old 11th February 2009, 03:02   #41  |  Link
Originally Posted by kebulek View Post
How important is updating that "win\system32\nvcuvid.dll" file?
You could miss out on bug fixes. Try not to forget.
Guest is offline
Old 13th February 2009, 04:02   #42  |  Link
Version 1.0.0b
Here is the second test version. I'll release this if there are no big problems found.
http://neuron2.net/dgmpgdecnv/dgmpgdecnv100b.zip
Guest is offline
Old 13th February 2009, 13:11   #43  |  Link
~bT~
н∂-αиαтι
^ i notice u have included dgdecode.dll with this release, is this intentional?
~bT~ is offline
Old 13th February 2009, 14:22   #44  |  Link
Oops. Please re-download it. Thank you.
Guest is offline
Old 13th February 2009, 15:59   #45  |  Link
kebulek
kebulek's Avatar
Originally Posted by neuron2
From DGAVCIndexNV thread:
2. Fixed blocking on seeks with deinterlace=1.
@neuron: Did you fix this also in DGMPGIndexNV? I notice that in VDub few days ago, when I was seeking. And when i played same .avs in MPC, everything was fine. I'm in work right now, so I can't check new version.
kebulek is offline
Old 14th February 2009, 01:02   #46  |  Link
Everybody please re-download 1.0.0b. It had a bad bug in DGMPGDecodeNV.dll.
Guest is offline
Old 15th February 2009, 21:04   #47  |  Link
blubberbirne
Deinterlacing don't work for me. The encoded File stutter. Framerate is only 29,87 and not 29,97 after encoding.
If i use yadif for deinterlacing, everythink is fine.
blubberbirne is offline
Old 16th February 2009, 02:58   #48  |  Link
I can't help you without a source stream to allow me to duplicate your issue.
Guest is offline
Old 16th February 2009, 04:50   #49  |  Link
lpm
Using 1.0.0b (with NVidia GeForce 8500 GT on XP SP3 32-bit)
Your work rocks... the new tool seem to be working great functionally for me but there are glitches. Decoding works but is choppy and slow when frameserving with AVISynth... This is only with the new MPGSource, I get great performance when frameserving AVC with DGAVCDecNV. I will try to put together a reproducible test case but it looks like I'm not the only one experiencing so you might have one already.
One regret: so far MPGSource() doesn't take the "info" parameter and passes no hints by default so the ColorMatrix() filter can't automatically decide what to do if chained next.
A side suggestion: Today there are different command line syntaxes and AVISynth syntax variations between all the DG*Dec tools. How about merging all the tools (DGMPGDec, DGAVCDec, DGVC1Dec, DGMPGDecNV, DGAVCDecNV) into a single binary at some point - and a single AVISynth function - with the NV features enabled as a switch, and of course only when the required hardware/license are present? That would be awesome.... not a major requirement but a nice-to-have at some point.
lpm is offline
Old 16th February 2009, 09:15   #50  |  Link
blubberbirne
i will upload a small sample file later this evening (german time)
EDIT:
Here is the Sample: http://rapidshare.com/files/198874638/sample.rar
it also includes 2 Encodes. One with Cuda Deinterlace and the other one with Yadif.
i use this script for encoding...
loadplugin("DGMPGDecodeNV.dll")
#Load_Stdcall_plugin("yadif.dll")
mpgsource("sample.dgm", deinterlace=1)
#Yadif(2,1) #software-deinterlace
crop(2,0,1914,1076)#Temp
spline36resize(1280,720) #Temp
Old 17th February 2009, 09:07   #51  |  Link
blubberbirne
I hope you noticed my edited post
Old 17th February 2009, 14:56   #52  |  Link
I tried with your stream and script and viewed the script in VirtualDub. Everything is fine while your MP4 is not.
Load your script into VirtualDub and single step. Is that OK? If OK, then something went wrong in your subsequent encoding. If not OK, then what is your OS, graphics card, and versions of DGMPGDecNV and CUVID Server?
Guest is offline
Old 17th February 2009, 19:52   #53  |  Link
blubberbirne
Encoding with Virtual Dub to xvid fails also.
I used the following Stuff here
- Vista x64 Sp1 and all Updates
- GeForce GTX260 with Driver 182.05 (but i will fallback to 181.22 for testing later)
- DGMPGDecNV and CUVID Server are both up2date.
Old 17th February 2009, 21:56   #54  |  Link
blubberbirne
lol i found the problem
CUVID server needs to start in windows xp compatible mode on vista64. After this, everything works fine
So i think you need something to fix in the CUVID Server
Old 18th February 2009, 02:47   #55  |  Link
I don't have Vista 64 so unless you'd like to donate one, I'll just continue to pretend that it doesn't exist. But thank you for adding this useful tidbit.
Guest is offline
Old 18th February 2009, 21:30   #56  |  Link
Sagekilla
x264aholic
@neuron2: I just recently fixed my desktop computer, and I have a copy of Win Vista x64 on hand that I'm about to install. Would you like access to the desktop?
Sagekilla is offline
Old 19th February 2009, 00:28   #57  |  Link
You mean via Remote Desktop or some such thing?
Thanks, but I'd much rather bring up a dedicated machine.
Guest is offline
Old 19th February 2009, 01:25   #58  |  Link
squid_80
You can't use Direct3D over remote desktop so CUVIDServer wouldn't work anyway.
squid_80 is offline
Old 22nd February 2009, 23:28   #59  |  Link
Deinorius
Najarenthur
Deinorius's Avatar
DGAVCIndexNV showed us, that quality is better than by decoding with DGAVCIndex. CRF-Encode was quite smaller.
Is there the same effect with DGMPGIndexNV? For example with DVDs?
Deinorius is offline
Old 23rd February 2009, 01:38   #60  |  Link
That's surprising and if it happens I can't see how it could possibly be due to just using DGAVCDecNV versus DGAVCDec.
No such effect that I am aware of.
Guest is offline
