Old 28th January 2009, 00:08   #921  |  Link
rica
I have to solve a few issues and add audio support first.
Flac is gonna be an additional audio file which you will support as well with mkv decoding; i guess?
rica is offline
Old 28th January 2009, 01:31   #922  |  Link
I found the cause of the long hang on some files. Please wait for a fix before testing further.
I plan to demux all audio types.
Guest is offline
Old 28th January 2009, 02:06   #923  |  Link
rica
BTW, i've been awaiting you to make a CUDA encoder tool since i know you are the best in those CUDA things.
Still no hope on Cyberlink's Power Director 7 to me.
rica is offline
Old 28th January 2009, 05:07   #924  |  Link
I fixed the seeking in the MKV test version. It should be really fast now without any hangs.
http://neuron2.net/dgavcdecnv/dgavcdecnv1011test.zip
I'm learning way more than I wanted to know about Matroska files.
A CUDA encoder is a massive project. Ask Dark_Shikari about it.
Guest is offline
Old 28th January 2009, 05:29   #925  |  Link
Audionut
I'd search for his previous responses before doing that.
http://www.7-zip.org/
Audionut is offline
Old 28th January 2009, 06:12   #926  |  Link
Sagekilla
x264aholic
I'd not even ask about a CUDA encoder to begin with. Discussion of it has popped up -many- times and it's a no go because of the extensive resources required. Unless you have a lot of coders who are willing to put time and effort into optimizing code for CUDA, it's not happening. IIRC, one huge issue Dark Shikari had was getting functions to run fast enough to make it worthwhile.
@neuron2: Thanks for adding mkv support No need for me to demux a mkv for doing comparisons of my encodes anymore!
Sagekilla is offline
Old 28th January 2009, 15:07   #927  |  Link
yeye69
How about Linux version?
yeye69 is offline
Old 28th January 2009, 15:53   #928  |  Link
Inventive Software
Turkey Machine
Care to port AviSynth and neuron2's DG toolset to Linux?
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
Old 28th January 2009, 16:10   #929  |  Link
Port DirectShow too while you're at it because NVCUVID needs it.
Guest is offline
Old 28th January 2009, 17:13   #930  |  Link
Inventive Software
Turkey Machine
What? No stand-alone? Poor NVIDIA.
Old 28th January 2009, 17:34   #931  |  Link
They're working on disconnecting it from DirectShow.
Guest is offline
Old 29th January 2009, 15:10   #932  |  Link
MKV support with audio demuxing
I've added audio demuxing. Note that some formats are not supported yet. If you hit one of them you'll get a popup asking you to send me a sample. I need samples to implement the support.
Be sure to update with the included nvcuvid.dll.
Guest is offline
Old 29th January 2009, 15:45   #933  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
which ones don't you have supported yet? might be easier to
A. compare against a non-supported list and give you samples for the ones on the list rather than trying to hunt
B. compare against a supported list and give you samples for things not on the list.
i imagine B would be easier to do as you know what you've implemented and may forget listing some formats for A.
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline
Old 29th January 2009, 16:15   #934  |  Link
The documentation of audio CodecIDs is incomplete, so by hunting I will find out ones that are in use but not documented. Anyway, here are the ones I currently support (because I have samples):
A_AC3
A_MPEG/L1
A_MPEG/L2
A_MPEG/L3
A_DTS
Guest is offline
Old 29th January 2009, 18:23   #935  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
A_AAC
A_EAC3
A_FLAC
A_PCM/INT/LIT
A_REAL
A_TTA1
A_VORBIS
A_WAVPACK4
http://haali.cs.msu.ru/mkv/codecs.pdf
http://samples.mplayerhq.hu/Matroska/
http://www.bunkus.org/videotools/mkvtoolnix/samples/
Kurtnoise is offline
Old 30th January 2009, 00:35   #936  |  Link
Added A_AAC support to MKV demuxer
Added support for A_AAC in MKV files.
What's the priority on the remaining formats?
Guest is offline
Old 30th January 2009, 01:15   #937  |  Link
rica
I think ac3, dts, aac and flac is enough for mkv since DTS-HD and TrueHD are not supported by matroska for now.
Stream Type: Matroska
Profile: High
Level: 4.1
Frame Size: 1920x1080
SAR: 1:1
Display Size: 1920x1080
Frame Rate: 23.976024 fps
Colorimetry: BT.709 [1]
Frame Structure: Frame
Frame Type: I
Coded Number: 257
Playback Number: 257
Frame Repeats: 0
Field Repeats: 0
Bitrate: 27.122
Bitrate (Avg): 13.526
Bitrate (Max): 27.122
Audio Stream: 1: A_FLAC 48000 6ch "und"
Elapsed: 0:00:00
Remain: 0:00:00
FPS:
Info: Finished!
For m2ts, all formats seem to be supported:
Stream Type: Transport [192]
Profile: High
Level: 4.1
SAR: 1:1
Frame Type: I
Coded Number: 217
Playback Number: 217
Frame Repeats: 0
Field Repeats: 0
Bitrate: 35.124
Bitrate (Avg): 34.615
Bitrate (Max): 35.383
Audio Stream: 1100: DTS HDHR C+L+R+SL+SR 48 1536
Audio Stream: 1101: DTS C+L+R+SL+SR 48 768
Audio Stream: 1102: DTS C+L+R+SL+SR 48 768
Audio Stream: 1103: DTS C+L+R+SL+SR 48 768
Audio Stream: 1104: AC3 3/2 48 448
Elapsed: 0:00:01
Remain: 0:00:00
FPS:
Info: Finished!
Profile: High
Level: 4.1
SAR: 1:1
Frame Type: I
Coded Number: 258
Playback Number: 258
Frame Repeats: 0
Field Repeats: 0
Bitrate: 27.123
Bitrate (Avg): 13.697
Bitrate (Max): 27.123
Audio Stream: 1100: TrueHD AC3 3/2 48 640
Audio Stream: 1101: AC3 3/2 48 640
Audio Stream: 1102: AC3 3/2 48 640
Audio Stream: 1103: AC3 3/2 48 640
Audio Stream: 1104: AC3 3/2 48 640
Audio Stream: 1105: AC3 2/0 48 192
Audio Stream: 1a00: E-AC3 2/0 48 192
Elapsed: 0:00:01
Remain: 0:00:00
FPS:
Info: Finished!
Thanks neuron.
_ _ _
rica is offline
Old 30th January 2009, 01:25   #938  |  Link
Added A_FLAC
Added support for A_FLAC in MKV files.
I'd like to release this, so please beat on it.
Guest is offline
Old 30th January 2009, 01:37   #939  |  Link
rica
Sorry, but i haven't understood the difference with previous version?
That already gave me the flac.
rica is offline
Old 30th January 2009, 01:45   #940  |  Link
No, the previous version displayed FLAC as the detected audio type, but if you tried to demux it, you got an error. With the latest version you get a demuxed FLAC file.
Guest is offline
