22nd February 2009, 13:18 | #1201 | Link | |
н∂-ƒαиαтι¢
ps. a lot of ppl don't realise how great this tool is but they will once it's gone |
22nd February 2009, 13:28 | #1202 | Link | |
way to go ! |
22nd February 2009, 15:07 | #1203 | Link |
I could reproduce a bug in the custom menu when combining more than 12 AVCHD folders:
If I select with the RC of my SAP in the shown custom menu the arrow to the 13th folder, the files of the 12th folder are played again and not the files of the 13th folder. If I play the folders sequentially they show and play all! And I can select the folder-title directly via RC through a so-called 'info-menu', which shows the titles and chapters as numbers. The bug can be reproduced with Nero Show Time as well. It seems to me that the arrow of folder-title 13 is pointing to the wrong playlist. But why? For these tests I had created very simple AVCHD folders containing just one single file. FSNAVI |
22nd February 2009, 15:34 | #1204 | Link |
Programmer (or just 教务长)
This is for the list menu (with 14 titles) not the thumbnail one, right?
I did a lot of tests and couldn't see the problem. Is it always and ONLY with nav-arrow 13? edit: I found the problem. Last edited by deank; 22nd February 2009 at 15:53. |
22nd February 2009, 15:51 | #1205 | Link | |
It is only with nav-arrow 13, but my tests ended with15 folder-titles! I'm happy to do more tests, but I don't know which one. FSNAVI |
22nd February 2009, 16:46 | #1207 | Link |
Dear Deank, since you have complete control over the expiration of the program or not, why don't you provide us with the full functionality (footer, fonts etc) until you decide what to do in the future ? Just asking
22nd February 2009, 17:02 | #1208 | Link | |
What's wrong? (The new dat-file seems to have exactly the same size as the old one1) FSNAVI |
22nd February 2009, 17:16 | #1212 | Link |
Probably because the "outdated" error occurs before the check for new version is performed. I'll change it in next versions. You can always use multiUPDATE.exe. What it does is download the last available version and then launches it.
22nd February 2009, 17:42 | #1213 | Link |
@fsnavi: Please post back if the problem with Title#13 is fixed. The problem with this navigational placeholder is since day one... First, the arrow was of different type, then pointing to wrong play item... Now it should be okay.
23rd February 2009, 09:56 | #1215 | Link | |
Also a bugfix in case of outdated dat-file - exe will update. |
23rd February 2009, 14:03 | #1216 | Link |
Ok, let's give another try of the SD card playback support.
Here is the sample. It is 55MB 1920x1080 h264 video 23.976fps with 2 subtitle tracks and DTS audio. A great success will be if it shows your VIDEO playback menu not to say if it plays. Please post back with results. ---- It seems there is a way to test if SD contents are valid using Panasonic's HDwriter application. A little observation: changing ONE BIT in .CLPI files (the one that defines the audio tracks) - makes SD contents invalid. If the audio is DolbyDigital (STEREO) - it is all okay. No multichannel support. Last edited by deank; 23rd February 2009 at 14:57. |
23rd February 2009, 14:40 | #1217 | Link | |
(Edit : the credits info font is not saved still ) Last edited by vpapanik; 23rd February 2009 at 14:51. |
23rd February 2009, 15:02 | #1218 | Link |
You're right. It is fixed now in 411.
DLL UPDATE Download calclib_dll.exe and overwrite your old calclib.dll in multiAVCHD base folder (it is just 600KB). It will be included in the full download (build 411) in first post. The author of CalcIT made major improvements speedwise. Thanks to dhmk again! Last edited by deank; 23rd February 2009 at 16:10. |
23rd February 2009, 17:08 | #1219 | Link | |
23rd February 2009, 17:14 | #1220 | Link |
What kind of ICON/THUMBNAIL do you see in your video screen?
Build 412 Some interface changes. It seems that novice users find multiAVCHD too complicated to use. Most of you probably didn't notice as we're together since multiAVCHD was "born" but piling up so many options makes multiAVCHD a not-so-easy to use. I made some space in some tabs and added others and will try to make it look and feel better. Anyway - I need space for the next features as popup menu and chapter creation, SD support along with h.264 stream processing if border-addition is needed. So - keep fingers crossed. Last edited by deank; 23rd February 2009 at 17:26. |
