Old 6th February 2018, 21:46   #261  |  Link
nalor
Originally Posted by candela View Post
Shouldn't you simply discard data from a virtual drive? Or you cannot detect it's virtual? All the other FindVUK data cannot be verified/trusted either if it's not the original disc
I don't think that supporting virtual drives can cause any issues - and basically the difference between real and virtual drives is 288sectors * 2048bytes = 576KB - compared to the real size of the volume this 'error' is negligible.
Or what do you think?
nalor is offline   Reply With Quote
Old 6th February 2018, 21:51   #262  |  Link
candela
I mean how can you be sure the files in the ISO are identical to the originals ? This would also make it possible to upload fake data.
candela is offline   Reply With Quote
Old 7th February 2018, 00:01   #263  |  Link
BRC85sYrg
so later we can make a database of BD+ tables, similar to keydb.cfg for keys. The ultimate goal will be real-time playback of BD+ protected titles using VLC. We just need to find a decent C programmer to update Videolan's libbdplus to load these tables
thanks for your explanation, thats a nice goal
Just released 1.08 - fixes the Problem with CloseOnExit, decrypts the UnitKeys earlier so they are written to keydb.cfg even in case the VUK cannot be validated ...
thank you very much for this update! dumping Unit Keys works now perfectly with BEE drives.
Originally Posted by BRC85sYrg View Post
some suggestions for the next release:
- "VOLUME_ID" as an additional MeaninglessVolumeName in the config file
@nalor maybe you oversaw this suggestion, so I posted it again.
fake data uploads can't be prevent.
@nalor without virtual drive support will it still be possible to pass-trough a drive to a virtual machine?
BRC85sYrg is offline   Reply With Quote
Old 7th February 2018, 22:46   #264  |  Link
nalor
you're right - I missed your suggestion, will change it with the next release.
I don't have any plans to limit support to real-drives ... it wouldn't make any difference - in case someone creates a modified iso-file he just needs to burn it to a disc and voila it would be supported.
Basically FindVUK reads data from the memory of DVDfab products -> only discs recognized by this apps are possible and manually created iso files and/or discs will very likely always fail.
So I just leave everything as it is
Old 15th February 2018, 15:36   #265  |  Link
TTide
FindVUK 1.08 Bug
I failed to get the VUK for my disc. Some bug i found in FindVUK 1.08, as i was able to get it in FindVUK 1.07.
2018-02-15 14:28:30 # 0 # [I] main / legacy / #############################################################################
2018-02-15 14:28:30 # 0 # [I] main / legacy /  ----------- FindVUK 1.08 -----------
2018-02-15 14:28:30 # 0 # [I] main / legacy / Operating System: Windows 10
2018-02-15 14:28:30 # 1 # [I] main / legacy / SettingsFile: >C:\FindVUK_1.08\config\FindVUK.ini<
2018-02-15 14:28:30 # 4 # [I] main / legacy / Current BufferSize 120 x 9001 - ScreenSize 120 x 30
2018-02-15 14:28:30 # 5 # [I] main / legacy / Requested BufferSize 120 x 300 - ScreenSize 120 x 50
2018-02-15 14:28:30 # 5 # [I] main / legacy / Max. ScreenSize 240 x 72
2018-02-15 14:28:30 # 29 # [I] main / legacy / Final New Values - BufferSize 120 x 9001 - ScreenSize 120 x 50 - Resize >1<
2018-02-15 14:28:30 # 29 # [I] main / legacy / M1 - New BufferSize 120 x 9001
2018-02-15 14:28:30 # 29 # [I] main / legacy / Mx2 - New ScreenSize 120 x 50
2018-02-15 14:28:30 # 32 # [I] main / legacy / Information! Passkey MainApp is not valid! ><
2018-02-15 14:28:30 # 32 # [I] main / legacy / Information! MediaPlayer MainApp is not valid! ><
2018-02-15 14:28:30 # 33 # [I] main / legacy / Untested DVDfab Version >0.0.0.0< found
2018-02-15 14:28:30 # 34 # [I] main / legacy / Preferred application is not available
2018-02-15 14:28:30 # 34 # [I] main / legacy / DVDfab is available!
2018-02-15 14:28:30 # 34 # [I] main / legacy / DVDfab-MainFile:      >C:\Program Files (x86)\DVDFab 10\DVDFab.exe<
2018-02-15 14:28:30 # 34 # [I] main / legacy / DVDfab-LogFile:       >C:\Users\gamer\Documents\DVDFab10\Log\dvdfab_internal.log<
2018-02-15 14:28:30 # 34 # [I] main / legacy / DVDfab-CloseAtTheEnd>1<
2018-02-15 14:28:30 # 34 # [I] main / legacy / KEYDB-Path:           >C:\Users\gamer\AppData\Roaming\aacs\<
2018-02-15 14:28:30 # 35 # [I] main / legacy / KEYDB-Backup-Path:    >C:\FindVUK_1.08\VUKbackup\<
2018-02-15 14:28:30 # 35 # [I] main / legacy / ProcDumpFile:         >C:\FindVUK_1.08\tool\procdump.exe<
2018-02-15 14:28:30 # 35 # [I] main / legacy /  --- PART 1 --- GET VUK ---
2018-02-15 14:28:30 # 39 # [I] main / legacy / No running application process discovered
2018-02-15 14:28:30 # 39 # [I] main / legacy /  >> Start it now >C:\Program Files (x86)\DVDFab 10\DVDFab.exe<
2018-02-15 14:28:32 # 1856 # [I] main / legacy / Untested DVDfab App Version found ><
2018-02-15 14:28:32 # 1856 # [I] main / legacy / Value set in ini file will be used for 'Folder2DiscID'
2018-02-15 14:28:32 # 1856 # [I] main / legacy / Value set in ini file will be used for 'Folder2VUK'
2018-02-15 14:28:32 # 1856 # [I] main / legacy / Offset Folder2DiscId >0x114< - Folder2Vuk >0x173<
2018-02-15 14:28:43 # 12665 # [I] main / legacy / Drive opened
2018-02-15 14:28:43 # 12666 # [I] main / legacy / DiscType detected >Blu-ray BDMV<
2018-02-15 14:28:43 # 12666 # [I] main / legacy / Volume Label detected >Deadpool<
2018-02-15 14:28:56 # 25581 # [I] main / legacy / DriveLetter detected >E<
2018-02-15 14:28:59 # 28604 # [I] main / legacy / Detected CopyProtections AACS >1< BD+ >1<
2018-02-15 14:29:11 # 40103 # [I] main / legacy / DiscID found >CFC68F3D31093942BE12908CED8C02C4494F1C5E<
2018-02-15 14:29:37 # 66597 # [I] main / legacy / MainPlaylist found >00800.mpls<
2018-02-15 14:29:45 # 74754 # [I] main / legacy / DVDfab got VUK - create memdump now!
2018-02-15 14:29:45 # 74876 # [I] main / legacy /  DUMP >>>
2018-02-15 14:29:45 # 74876 # [I] main / legacy /  DUMP >>> ProcDump v9.0 - Sysinternals process dump utility
2018-02-15 14:29:45 # 74877 # [I] main / legacy /  DUMP >>> Copyright (C) 2009-2017 Mark Russinovich and Andrew Richards
2018-02-15 14:29:45 # 74877 # [I] main / legacy /  DUMP >>> Sysinternals - www.sysinternals.com
2018-02-15 14:29:45 # 74878 # [I] main / legacy /  DUMP >>> No process matching the specified name can be found.
2018-02-15 14:29:45 # 74878 # [I] main / legacy /  DUMP >>> Try elevating the command prompt or using PsExec to make one as SYSTEM.
2018-02-15 14:29:45 # 74878 # [I] main / legacy /  DUMP >>> 	psexec.exe -s -d -i cmd.exe
2018-02-15 14:29:45 # 74879 # [I] main / legacy /  DUMP >>> 	procdump.exe -accepteula ...
2018-02-15 14:29:45 # 74880 # [I] main / legacy / ERROR!! Exitcode >-2< - Dump failed! - Program >C:\FindVUK_1.08\tool\procdump.exe< Parameter > -ma -o DVDFab.exe "C:\FindVUK_1.08\dump\CFC68F3D31093942BE12908CED8C02C4494F1C5E_Deadpool.dmp"<
2018-02-15 14:29:45 # 74880 # [I] main / legacy / Error during process memory dump >C:\FindVUK_1.08\dump\CFC68F3D31093942BE12908CED8C02C4494F1C5E_Deadpool.dmp<
2018-02-15 14:29:45 # 74881 # [I] main / legacy / Error during process memory dump - please report in the doom9 forum!
2018-02-15 14:29:45 # 74884 # [I] main / legacy / ERROR! Couldn't create memory dump! Exit application!
2018-02-15 14:29:45 # 74896 # [I] main / legacy / CloseAtTheEnd is active, but no running application >C:\Program Files (x86)\DVDFab 10\DVDFab.exe< could be found
TTide is offline   Reply With Quote
Old 15th February 2018, 22:36   #266  |  Link
nalor
Hi! I've no idea what really happens in your case - it already starts at the beginning of the logfile:
Which DVDfab version are you using?
Old 16th February 2018, 23:51   #267  |  Link
nalor
Just released 1.09 - it fixes a few DVDfab related bugs I've found during the investigation of @TTide s problem - but I've still no idea why 1.07 is working for him and 1.08 isn't.
Old 17th February 2018, 18:35   #268  |  Link
TTide
My DVDfab Version is 10.0.7.7 and FindVUK 1.09 also fails to create a Dump. I keep getting this:
2018-02-17 17:29:21 # 54896 # [I] main / legacy / DVDfab got VUK - create memdump now!
2018-02-17 17:29:21 # 55003 # [I] main / legacy / DUMP >>>
2018-02-17 17:29:21 # 55003 # [I] main / legacy / DUMP >>> ProcDump v9.0 - Sysinternals process dump utility
2018-02-17 17:29:21 # 55004 # [I] main / legacy / DUMP >>> Copyright (C) 2009-2017 Mark Russinovich and Andrew Richards
2018-02-17 17:29:21 # 55004 # [I] main / legacy / DUMP >>> Sysinternals - www.sysinternals.com
2018-02-17 17:29:21 # 55004 # [I] main / legacy / DUMP >>> No process matching the specified name can be found.
2018-02-17 17:29:21 # 55005 # [I] main / legacy / DUMP >>> Try elevating the command prompt or using PsExec to make one as SYSTEM.
2018-02-17 17:29:21 # 55005 # [I] main / legacy / DUMP >>> psexec.exe -s -d -i cmd.exe
2018-02-17 17:29:21 # 55005 # [I] main / legacy / DUMP >>> procdump.exe -accepteula ...
Old 17th February 2018, 21:51   #269  |  Link
nalor
Your main problem is that DVDfab 10.0.7.7 does not work any longer - you have to downgrade to DVDfab 10.0.4.8 - this is the latest release that is compatible with FindVUK.
Usually FindVUK should automatically detect that your release is not compatible and should exit, but I did it wrong - corrected it now for the next release.
On the other hand something is still strange - I still don't know why you're getting version 0.0.0.0.
Does it still display version 0.0.0.0 even with findVUK 1.09 ?
Old 18th February 2018, 01:16   #270  |  Link
candela
new ini help file. Hopefully everything is explained correctly
Old 18th February 2018, 20:43   #271  |  Link
TTide
No it displays this now:
Tested DVDfab Version >10.0.4.8< found
Old 19th February 2018, 00:17   #272  |  Link
candela
I just noticed there are serious problems with the dates (1.09 and before)
For example Predator:
<DiscId Date="2010-03-20">AA5B2D0735BF048400155066E30221C5ABB12AB4</DiscId>
Correct date:
2010-04-27 18-38-34 A---R--- 65.536 Unit_Key_RO.inf
There is not a single file on this disc with date 2010-03-20
<BDplus Date="2010.04.28">1</BDplus>
Again, there's not a single file on the disc with this date
The BDSVM dir is also dated 2010-04-27. BDSVM files
2009-10-15 19-42-20 A---R--- 20.971.520 00000.svm
I think
- for discid use date of unit_key_ro.inf
- for BD+ date , same as DiscID or folder BDSVM (not sure if it's ever different)
Note: makemkv reports Timestamp: 2010-04-27 10:46:49 for this disc, don't know where that time is coming from
Old 19th February 2018, 11:37   #273  |  Link
nalor
I think
Currently I'm using the creation-date of unit_key_ro.inf for the discid-date (I thought this makes more sense than using the last-modified date ?? ) - but the spec is not clear in this point, so just tell me if I should change it.
The date used for the BD+ date is stored inside the file itself - has nothing to do with the creation/last-modified or last-accessed dates as reported by windows. (I read the first 18 bytes of \BDSVM\00000.svm and get the date as visible here: libbdplus loader.c
Old 19th February 2018, 12:23   #274  |  Link
candela
Aha, maybe that's also why I have been seeing sometimes 1 day differences when comparing different sources for the disc date, I will investigate and check also the original doom9 posts. Maybe store both?
I didn't know BD+ actually had the date internally stored, thanks for this new information
Why the different formats though "-" vs "."
Old 19th February 2018, 21:23   #275  |  Link
nalor
The libaacs spec says the delimiter character has to be '-', this is the reason why it is not '.' for the DiscId date
Old 19th February 2018, 23:15   #276  |  Link
nalor
I'll change the - to . with the next release! I just noticed that there's no need to follow the keydb-spec inside the MetaXML file
Old 4th March 2018, 23:19   #277  |  Link
candela
Just released 1.08 - fixes a stupid bug I noticed when I checked the MetaXML files I've uploaded into the online-db: in case a few discs are uploaded one after the other, the 2nd disc includes 2 hashed, the 3rd disc 3 of them ... and so on. never cleared the previous hash values in 1.07
problem still exists in version 1.09 for MetaTitles. if the second disc does not have any metatitles, it's using the metatitle from the previous disc
too many bugs nalor, more testing ! better check all the other fields in this scenario
Old 4th March 2018, 23:36   #278  |  Link
nalor
Also noticed this 2nd bug 2 days ago....
Will release a new version hopefully tomorrow.
Gesendet von meinem E5823 mit Tapatalk
Old 4th March 2018, 23:45   #279  |  Link
candela
1) some more bad volume labels
BLURAY, blu-ray-pc, DISC_TITLE BD1, DISC_TITLE BD2, DISC, _YOUR_DISC_LABEL_, DISC1, DISC2, BD_ROM, SPE_BDLIVE, BD_VIDEO, PS3VOLUME
2) bad meta titles
BLU-RAY AUDIO, BLU-RAY 3D, BLU-RAY, Blu-ray, Blu-ray™, BLU-RAY VIDEO
also chars (utf-8): 0x2e, 0x20, 0x20 0x20 0x20 0x20 0x20, 0xc2 0xa0
3) xmls aren't generated when upload is disabled. probably by design but may be reconsider? xmls can then be generated offline and uploaded later
4) maybe add Batchfiles for the sychronize and GetMetaInfoFromDisc modes
5) how about auto start GetMetaInfoFromDisc in case no or bad verson of dvdfab is detected
Old 5th March 2018, 23:27   #280  |  Link
nalor
2) bad meta titles
Hi!
I've added BLURAY to the list of meaningless volumenames - but I don't think it makes sense to add the other names also. Currently there are ~1100 entries in the onlinedatabase and the other titles are not in the list, so I don't think it's really necessary to add them.
Same for the meta-titles - none of them from your list above is in my list and I don't think it's helpful to add such special titles to the list.
When I check the titles in the database I also find a couple that really look meaningless to me - but those are specials that only occur 1 time.
XML creation: changed the behaviour, MetaXML is always created now - but currently I have no plans to allow a manual upload into the online database.
Batchfiles: I will think about it, maybe when the onlinedb is really functional and the synchronisation is correctly working
Automatic GetMeta: will also think about it - but honestly I still don't know why we should collect this data at all?
