Old 15th March 2018, 19:57   #15681  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
It works for others but not for you ,so it means that problem is on your side. Simple. Do not waste your time...
Old 15th March 2018, 20:18   #15682  |  Link
MaistroX
And it can't be determined by the errors given and logs, so I can solve this and get it working for me also?
Regards MaistroX
MaistroX is offline   Reply With Quote
Old 15th March 2018, 21:10   #15683  |  Link
Atak_Snajpera
Try running Ripbot264 DE mode on virtual machine (win7 SP1 x64).
Old 15th March 2018, 21:14   #15684  |  Link
MaistroX
I would IF I could, had Win 7 Before I was forced by new HW to update to Win 10!
Old 15th March 2018, 21:21   #15685  |  Link
Atak_Snajpera
You do not have to activate win7. This ISO is good
https://thepiratebay.org/torrent/722...hed___Windows7
Old 15th March 2018, 21:55   #15686  |  Link
MaistroX
Activate???
And still The HardWare I have dont support Win7, that why I was forced to upgrade to Win10.
+ Torrents, thatīs a no-go!
Old 16th March 2018, 00:01   #15687  |  Link
slalom
slalom's Avatar
Originally Posted by MaistroX View Post
Activate???
Or here
https://www.w7forums.com/threads/off...wnloads.12325/
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
slalom is offline   Reply With Quote
Old 16th March 2018, 01:32   #15688  |  Link
burt123
burt123's Avatar
Activate???
So what hardware are you running, that W7 doesn't support ??
Maybe you should consider trying Atak's "Windows 7 Image Updater" !!
Windows 7 SP1 x64 Professional, or Ultimate, should support most modern hardware.
burt123 is offline   Reply With Quote
Old 16th March 2018, 06:52   #15689  |  Link
burt123
burt123's Avatar
He is also using older version of AviSynth+ r2455. I have r2580.
Looks like AviSynth+ r2636, is available.
Old 16th March 2018, 10:14   #15690  |  Link
Atak_Snajpera
Activate???
I'm shocked how easily people bought that BS.
Ryzen is FULLY supported on win7!
https://support.amd.com/en-us/downlo...s%207%20-%2064
APU also works. You just have to re-add few entries in main GPU driver (.inf).
ThreadRipper is also working without any issues!
https://hardforum.com/threads/thread...ost-1043435113
Old 19th March 2018, 16:06   #15691  |  Link
byteshare
ByteShare
byteshare's Avatar
FYI, HEVC 2.7 stable was bumped from 2.7+1 to 2.7+2
Old 24th March 2018, 17:25   #15692  |  Link
PreLimit3r
Hi.I have a little problem with HEVC profiles.Everything works fine when I encode with default Main10 or Main8 progressive profile,but when I want to tune preset with Slow and Animation option I got an error.Can you tell me what's wrong?
PreLimit3r is offline   Reply With Quote
Old 27th March 2018, 14:19   #15693  |  Link
Ryushin
Ryushin's Avatar
I just wanted to write again about the bug that replaces a job if your editing or setting options for a newly demuxed job during the combining/muxing phase. The job that is being muxed will have it's job number and title changed to the job that is being edited. Stopping Ripbot264, editing jobs.list and manually fixing the replaced line with the correct job number and the name brings the job back after starting Ripbot264 back up.
Ryushin is offline   Reply With Quote
Old 30th March 2018, 14:44   #15694  |  Link
JASAN
Recommendation?
Sorry if this is the wrong place Atak and everyone else, Your program has worked very well for years, thank you for your effort in creating it.
Would you be able to recommend or create an easy to use program that would edit mp4 metadata, specifically adding the cover images to existing files?
Ripbot works for new encodings of course. But I have about 10,000 mp4s I've made that I would like to add this data to. All tv seasons so they would only need the same cover for each season. (I travel where there is no streaming for weeks at a time)
I'd pay good money for a program that can do this :-)
Thanks in advance, Have a good one.
Just in case anyone is asking how am I bringing this data around, Its easy, Run twonky on a tall Intel NUC with 2.5tb internal storage and two tiny 4tb WD drives :-). VLC on tablet/phone for playback.
JASAN is offline   Reply With Quote
Old 31st March 2018, 13:03   #15695  |  Link
george84
Encode fails after Auto update
Normally RipBot 1.22.0 generates me a file job9.avs which contains a line:
video=Import("P:\photo\Scans\Edited sRGB\PhotoDirList.xml.smil.avs").ConvertToYV12(matrix="rec709")
Today there was an auto update and afterwards the generated line is:
which causes the encode to fail.
My solution is to disable Auto Update and do a reinstall of RipBot and everything works again.
george84 is offline   Reply With Quote
Old 31st March 2018, 13:15   #15696  |  Link
burt123
burt123's Avatar
Just curious, what version / build were you running before the update than "ruined it all" ??
You mentioned 1.22.0, should be 1.22.2..with a Ripbot.exe build date of 28/03/18.
Have got avisynth up to date (in Tool's folder)
Old 31st March 2018, 14:46   #15697  |  Link
Atak_Snajpera
@george84
My solution is to add ConvertToYV12(matrix="rec709") to your PhotoDirList.xml.smil.avs. Problem solved.
Old 31st March 2018, 17:36   #15698  |  Link
foxace
Hello @Atak_Snajpera
it possible to add nvenc support ?
foxace is offline   Reply With Quote
Old 31st March 2018, 17:45   #15699  |  Link
Atak_Snajpera
no .
Old 31st March 2018, 18:15   #15700  |  Link
george84
I currently run 1.22.0, downloaded from first page of this forum.
Yesterday I was running 1.21, than there was an automatic update, which caused problems.
Then I downloaded 1.22.0 and it worked again. Today in the morning everything worked, at noon there was an automatic update which caused problems.
