Old 29th November 2017, 18:03   #361  |  Link
AKBabel
Hi to all,
I have noticed, that the FFV1 encoder configuration window doesn’t show all possible settings for this codec. You can actually also define an interframe compression by using the GOP argument of ffmpeg:
https://trac.ffmpeg.org/wiki/Encode/FFV1
Why Golomb Rice coding could just be applied to 8Bit Video?
AKBabel is offline   Reply With Quote
Old 29th November 2017, 18:16   #362  |  Link
shekh
Hi, to set GOP argument you can use VirtualDub`s "Force keyframes every ... frames" option. It also overrides maximum gop for x264, x265 etc.
It is limitation of the FFV1 codec itself.
VirtualDub2
Old 29th November 2017, 19:01   #363  |  Link
AKBabel
Thank you.
I have tried, now and it works.
But it doesn’t affect file size that much in this case.
So maybe I’ll stay with every frame as keyframe.
Old 29th November 2017, 19:12   #364  |  Link
shekh
Yes, it does not help with photographic sources. Maybe works better with something like cartoon, I don't know.
Old 4th December 2017, 20:08   #365  |  Link
AKBabel
Is there any chance to include a flac audio encoder in the VirtualDub modification?
Old 4th December 2017, 21:01   #366  |  Link
shekh
Chance is good
I already experimented with it and the good news flac is supported in wav/avi formats. The main difficulty is VirtualDub's AVI interleaving algorithm (there was something missing in it).
Old 4th December 2017, 21:12   #367  |  Link
sneaker_ger
AVI isn't really build for variable frame length formats. So for FLAC in AVI you should at least use constant frame lengths. (Or better yet: don't implement it at all. Let old containers die ... )
Old 4th December 2017, 22:16   #368  |  Link
LigH
LigH's Avatar
But VDubFilterMod does not only save AVI. It can also save more modern and flexible containers. — Now I wonder whether it is possible to restrict the content format selection to output containers.
New German Gleitz board
Old 5th December 2017, 12:48   #369  |  Link
shekh
I'm thinking about this. It is possible (not easy) to find which formats are compatible. Making the UI right is more difficult. There should be single "compression dialog" with file format, video and audio.
VirtualDub2
Old 5th December 2017, 15:46   #370  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
But VDubFilterMod does not only save AVI. It can also save more modern and flexible containers...
Is there any particular reason why the default output container is still .AVI. Could it not be say, .MKV?
Old 5th December 2017, 16:28   #371  |  Link
Should not be changed unless user sets some preference, default should always be AVI.
Old 5th December 2017, 16:39   #372  |  Link
SeeMoreDigital
Any particular or technical reason "why" this has to be the case?
The AVI container is so last millennium. It should have been phased out years ago.
Old 5th December 2017, 17:30   #373  |  Link
shekh
Many things work perfectly in AVI. It is as good as TGA which is also simple and old.
There is long list of very legacy features.
Who will benefit from this changed default?
Things which do not work in MKV now:
Uncompressed video: not tested at all.
Audio offset: not applied (maybe will fix soon).
File comments: maybe not important at all.
Also, technically you can delete any plugin and live without it.
And since MKV output is in the plugin, how can it be the default?
VirtualDub2
Old 6th December 2017, 09:50   #374  |  Link
AKBabel
Every format has its advantages and disadvantages.
AVI is still alive and it is supported and used, also for archiving.
Well, mkv is seen as a new free solution for archiving, exactly because of the file comments, its easy editable header structure and its ability to perform a content check via CRC (https://kieranjol.wordpress.com/2016...or-film-scans/).
I saw it also at this year’s IASA conference and that is the reason why I am here, because I consider it as a possible solution beside IMF for our archive.
So, it also would be ideal if there could be a menu inside VirtualDub to edit the metadata of the mkv header (aspect ratio, cropping etc.)
Old 6th December 2017, 10:07   #375  |  Link
LigH
LigH's Avatar
VDubFilterMod has already come a long way since Avery Lee's original VirtualDub, easily passed VirtualDubMod; and its possible future sounds promising with such an inspiration.
Old 6th December 2017, 10:41   #376  |  Link
SeeMoreDigital
In the course of my encoding work I receive A/V sources in many different formats. For many years I've been re-encoding them to 4.2.0 8-bit AVC Lossless and muxing them within the .mkv container.
Personally, I've never had a problem with them...
Old 6th December 2017, 10:44   #377  |  Link
jpsdr
Well, i'm still using a lot AVI, because in my video processing, i have several steps, and i save each steps in lossless avi file (UT Video actualy), which is the easiest way. And it's the final AVI lossless file i feed to my encoder at the end. I absolutely don't want AVI to die, as said, each format as its benefit.
Old 6th December 2017, 18:24   #378  |  Link
AKBabel
Today have tried to load 6K DPX files (roughly 205MB per file) in VirtualDub.
And it could open the sequence, even 16Bit per channel and with alpha. Seeking failed (that could also be a problem of the low access speed of the workstation).
But as I tried to encode it, VirtualDub crashed because it could’t allocate enough memory (for one frame I guess). I have tried to lower the resolution per resize and the encoding started, but it also ran out of memory after a few frames.
Old 6th December 2017, 19:19   #379  |  Link
shekh
Encoding to what?
I experimented with 5000*2500@rgb48 converting to FFV1, and it used around 2GB for encoding. Are you trying with 32-bit version?
VirtualDub2
Old 7th December 2017, 09:49   #380  |  Link
lansing
I encountered a bug, when I loaded in a 32 bit png, adjust the color using colormill, and then export it as single image out as png, the resulting image became all white.
