20th January 2009, 14:01 | #201 | Link |
For a bit of extra performance/reduction in memory usage when doing pre-filtering on a calm_super clip, specifying levels=1 works for the source_super clip:
source_super = source.MSuper(pel=2, hpad=16, vpad=16, levels=1) # create the source superclip |
6th February 2009, 07:38 | #202 | Link |
Error with MT
Hi folks!
I use simple script from doc Code:
LoadPlugin("MT.dll") SetMemoryMax(1024) SetMTMode(5) AVISource("sel.avi") # или MPEG2Source, DirectShowSource, некоторый предыдущий фильтр SetMTMode(2) super = MSuper(pel=2) backward_vec2 = MAnalyse(super, isb = true, delta = 2, overlap=4) backward_vec1 = MAnalyse(super, isb = true, delta = 1, overlap=4) forward_vec1 = MAnalyse(super, isb = false, delta = 1, overlap=4) forward_vec2 = MAnalyse(super, isb = false, delta = 2, overlap=4) MDegrain2(super, backward_vec1,forward_vec1,backward_vec2,forward_vec2,thSAD=400) MT 0.7 (I replace avisynth.dll at windows\system32 directory) MVTools 2.31 Avisynth 2.58 Windows XP SP3 Core 2 Duo 3.16 Source huffyuf encoded. Please advice. yup. |
6th February 2009, 14:25 | #203 | Link |
Hi!
Folowing script: Code:
LoadPlugin("MT.dll") avisource("sel.avi") MT(""" super=MSuper(pel=2,sharp=1) backward_vec2=MAnalyse(super,isb=true,delta=2,overlap=4) backward_vec1=MAnalyse(super,isb=true, delta=1,overlap=4) forward_vec1=MAnalyse(super,isb=false,delta = 1,overlap=4) forward_vec2=MAnalyse(super,isb=false,delta=2,overlap=4) MDegrain2(super, backward_vec1,forward_vec1,backward_vec2,forward_vec2,thSAD=400) """,2) yup. |
7th February 2009, 17:02 | #205 | Link |
Fizick!
From doc Code:
SetMTMode(5) FFmpegSource("some.avi") # avisource не работает с SetMTMode на моих машинах - TSchniede SetMTMode(2) super = MSuper(pel=2) backward_vec2 = MAnalyse(super, isb = true, delta = 2, overlap=4) backward_vec1 = MAnalyse(super, isb = true, delta = 1, overlap=4) forward_vec1 = MAnalyse(super, isb = false, delta = 1, overlap=4) forward_vec2 = MAnalyse(super, isb = false, delta = 2, overlap=4) MDegrain2(super, backward_vec1,forward_vec1,backward_vec2,forward_vec2,thSAD=400) Code:
LoadPlugin("MT.dll") SetMemoryMax(1024) SetMTMode(5) AVISource("sel.avi") # или MPEG2Source, DirectShowSource, некоторый предыдущий фильтр SetMTMode(2) super = MSuper(pel=2) backward_vec2 = MAnalyse(super, isb = true, delta = 2, overlap=4) backward_vec1 = MAnalyse(super, isb = true, delta = 1, overlap=4) forward_vec1 = MAnalyse(super, isb = false, delta = 1, overlap=4) forward_vec2 = MAnalyse(super, isb = false, delta = 2, overlap=4) MDegrain2(super, backward_vec1,forward_vec1,backward_vec2,forward_vec2,thSAD=400) This different thing modified avisynth.dll and plugin mt.dll? But why second scrip work? Where trick? yup. |
7th February 2009, 17:30 | #206 | Link |
Sleepy overworked fellow
Have you tried with ffmpegsource?
TSchniede clearly says that "avisource doesn't work with SetMTMode on [his] machines"
AnimeIVTC() - v2.00 -http://boinc.berkeley.edu/- Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p) |
7th February 2009, 19:53 | #207 | Link |
AviSynth plugger
Yup,
i know why MT(""" script work. It must work But I do no know exactly, why the first your script (SetMTMode) does not work. Try to use FFPEGSource, or other codecs. And also try various sadx264 modes. I am not sure. Please report your results here.
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
7th February 2009, 23:47 | #209 | Link |
I cannot access Fizick's website: http://avisynth.org.ru/
I get the following error: The browser could not find the host server for the provided address. Is anyone else having the same problem? |
9th February 2009, 07:03 | #212 | Link |
Hi Fizick & thetoof!
Thanks to advice. I downloaded FFMpegsource2 http://ivtc.org/new/beta/FFmpegSource-2.00b4.rar change AVISource to FFVideoSource in my script and now all work fine. yup. |
19th February 2009, 20:01 | #215 | Link |
is there a way this script could be converted to MVTools2? Code:
############################################################################## #Original script by g-force converted into a stand alone script by McCauley # #latest version from December 10, 2008 # ############################################################################## function Stab (clip clp, int "range", int "dxmax", int "dymax") { range = default(range, 1) dxmax = default(dxmax, 4) dymax = default(dymax, 4) temp = clp.TemporalSoften(7,255,255,25,2) inter = Interleave(temp.Repair(clp.TemporalSoften(1,255,255,25,2)),clp) mdata = DePanEstimate(inter,range=range,trust=0,dxmax=dxmax,dymax=dymax) DePan(inter,data=mdata,offset=-1) SelectEvery(2,0) } Is there a speed gain to be expected with MVTools2? Regards and thanks in advance McCauley |
19th June 2009, 19:36 | #218 | Link |
Not a question, but a compliment:
I've been working with AVISynth for about 2 years; I've been learning and using MVTools2 for just a few weeks now, reading about and trying out a new filter every few days, and I have to say it is the most thorough, well designed and professional piece of work I've seen in a long time! It's a real joy to study and play with. Congratulations to Fizick and everyone else who helped. The documentation is excellent too, despite occasional (small) English language errors! =} It's brought back my joy in studying complex technical stuff. |
19th June 2009, 21:55 | #219 | Link |
AviSynth plugger
pbristow,
thanks. can you can correct (small) English language errors produced by developers from France, Russia, Denmark and Germany ?
22nd June 2009, 11:55 | #220 | Link |
After playing with my aWarpSharp i went to optimize something more useful. Here is modified version of MVTools 2.4.2: http://pavelsx.googlepages.com/mvtools-v2.4.2_mod.rar
I did some source/project settings cleanup and optimized primary for MDegrain1/2/3 - depending on your settings you'll probably see 2-15% speedup, results are bit-identical to original 2.4.2. |
