Old 8th September 2023, 12:06   #1  |  Link
Lucius Snow
Blu-Ray pure audio authoring software?
Hi all,
I'm looking for a Blu-Ray pure audio authoring software. I read that DoStudio used to do it but it seems discontinued.
Does anyone have another suggestion?
Thank you.
Lucius Snow is offline   Reply With Quote
Old 8th September 2023, 23:26   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
I would think that copying/editing a menu and running tsMuxeR + BDedit on your assets should do it.
Old 9th September 2023, 11:56   #3  |  Link
Lucius Snow
Thank you. I'm going to find an existing Pure Audio disc and edit it then.
Old 9th September 2023, 12:57   #4  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Are you actually looking for HFPA Blu-ray Audio discs?
Old 20th September 2023, 14:49   #5  |  Link
Lucius Snow
Yep, that's it. That kind of menu would be the best so far: https://www.youtube.com/watch?v=w7hLIZ9Li24
It's probably made with DoStudio. I had a look inside it with a template they gave. But it's incomprehensible for me (I'm a DVD-Architect user). It looks like a BD-J but I'm not sure.
Old 23rd September 2023, 21:57   #6  |  Link
Roger1972
Blu-Disc Studio can handle Blu-ray Audio and Pure Audio®
Blu-Disc Studio can handle Blu-ray Audio and Pure Audio®:
https://blu-disc.net/
Roger1972 is offline   Reply With Quote
Old 24th September 2023, 17:44   #7  |  Link
Lucius Snow
Good to know, thanks.
