10th January 2003, 00:59 | #21 | Link | |
I truly love my AIW 7500
My first impression of the card wasn't so good because I didn't know the first thing about capturing but once I learned of the PIC Video codec and learned a few more things (recently using iuVCR instead of virtualdub sync) I realized how good this card really is. Capture sample 1, Capture sample 2, you can take a look at the samples or download it by right-clicking and selecting save target as. Last edited by 1loser; 10th January 2003 at 01:32. |
10th January 2003, 03:38 | #23 | Link | |
1) try not to run anything in the background like antivirus software. 2) don't use the computer while capturing 3) use a very faster drive with a 8 mb cache 4) install a PCI ATA controller card to run your capture drive only! 5) use a bat file to start the program in high priority "Start/high iuVCR.exe" or change in task manager to high priority. 6) use Pic Video codec set to compression of 19 to keep quality high but file size reasonable. 9.5 GB's per 60 minutes at 640x480. The final MPEG-2 file size will be under 795 mb's at 1850 video bitrate and 192 audio bitrate with 53 minutes of edited video. Thanks goes to all those that have made posts that helped me to achieve great capturing results! |
10th January 2003, 04:08 | #24 | Link |
Banned
>Originally posted by ^^-+I4004+-^^
>anyone that says AIW has acceptable quality should check their eyes first..... me first? LOL! hi-res ati stuff doesn't look so bad these days.... bt8x8 is still a bit more flexible with sharpening (if needed) of bt8x8 tweaker,etc. >Nice shot (the blonde) no,the black girl is more interesting! (hehe) Last edited by ^^-+I4004+-^^; 10th January 2003 at 04:12. |
10th January 2003, 06:14 | #25 | Link | |
Shadowrunner
Me and others have been giving ATI a hard time over this and a few other things... I believe MMC 8.1 or later will address this and maybe a few other things. I really pushed hard for them to make their MMC do more stuff like AVI_IO and iuVCR... in terms of AVI formats... multi-segment captures, pause and resume function and the option to adjust codec's from within MMC. And lots more Another tool I recommend anyone to have is Stinky's Reg tool for MMC. It allows for some denoise and sharper/softer effect's... this is all capable... just well hidden in the registry by ATI. It also lets you adjust the Mpeg1 and Mpeg2 capture profiles so you can tweak out even more quality with certain settings that ATI seems to think the avg user should not know about or have access to. And thanks ^^-+I4004+-^^ glad you liked my sample's... as for the war's from my past I believe if i had showed samples then alot of it could have been avoided maybe(I never once lied and just stated to the best of my ability how to make nice quality 1cd encode's from DVDrips). Thanks be to Orbman for hosting my samples and to the other kind soul for making that website the guide I made. I wanna add two more guides to it both using iuVCR. One for XviD captures using the Cyberlink deinterlace filter and the other for one for how to capture using WMV9 @ 320x240 resolution. Just trying to help others and have fun As for deinterlacing.... I prefer deinterlacing since I also tend to watching alot of stuff on my monitor... even though I have a 29" TV right beside my PC. I even tend to watch TV on my PC in a little 320x240 window most times while I do stuff. |
13th January 2003, 14:41 | #26 | Link |
To Neverlift: Just watched those samples and tried your method with Xvid and iuvcr.
I have to say that I am really pleased with the results I can't capture with such high resolutions cause I have VIA motherboard and there is some line-bugs with high resolutions like 640x480 but I can barely capture with that same resolution 512X I was just wondering what bitrate or other settings you used with Xvid, cause I couldn't find your guide you mentioned. I just tried without b-frames and constant bitrate 1200. Any chance to cut garbage from capture on the fly? I mean couple of pixels from vhs tapes from bottom and top? |
13th January 2003, 22:59 | #27 | Link | |
Shadowrunner
This method I use I got from Birdy. I only used iuVCR to do wmv9 captures using a 320x240 res. I used AVI_IO before this. Birdy noticed that you could apply filters to captures in iuVCR and now this where we are with it. iuVCR has a crop filter. iulab video crop is the name I believe. I have not tried it thou. I have a VIA chipset based mobo... Abit KT7A and I have a SoundBlaster Live series card. I have no problems with it but I followed Pauls faq/guide. And I run a AthlonXP 1800+ o/c to 1649mhz on this mobo. I use 1-pass quantizer mode for when I capture, try 6-4 for the quantz's and see how it works out. in advanced settings I leave everything like they would be if I was doing a 2-pass encode. |
15th January 2003, 00:52 | #28 | Link | |
Deinterlace Filter link
15th January 2003, 02:25 | #29 | Link | |
Shadowrunner
Re: Deinterlace Filter link
http://homey.dyndns.org/vid/incoming/birdy/Filter.exe Let me know if this link works for you ok. |
15th January 2003, 03:46 | #30 | Link | |
Re: Re: Deinterlace Filter link
19th January 2003, 07:38 | #32 | Link | |
When you use a de-interlace filter while capturing does in become a progressive video? It seems I should select progressive frames and zigzag scanning order in cinema craft. When I use the project wizard in TMPGEnc it says the captured video is interlaced even thou I used the de-interlace filter. |
23rd March 2003, 00:35 | #33 | Link |
Hi There a newbees first post!
I happened 2 have a Aver DVD EZmaker kit pairing with Ulead Mediastudio pro since 1 month ago & it gives good results. I think this card is really good 4 that cheep money,but im only in it 4 fun!Edited some videos 4 my Wifes Oriental Performence & Playing with home made music videos. Ive using a parabol (SIRIUS) SCART 2 a Svhs video player & from that1 2 da card composite cable,i also use composite 2 my tv. My computer is p3-1000 512meg.Im also using vegas video4 but that ap is really much slower in capturing than Ulead,could b some fiddling around there 2. First i got strange lines in capture via Svhs cable, tryed everything,changing card possitions etc, moving eletric cable around 2 different connections,ihad 2 stay with composite. Well,i prefer mpeg2 cause the files goes 2 big otherways. Sorry 4 my poor English.Hope u got something from al this fantastic cool guys here,as i said im ust a newbee on this matter of capturing. But im Smoth satisfied. Greetings. LaScala
Im greatful 4 al u Guys!! |
