Old 4th January 2015, 20:05   #61  |  Link
Groucho2004
Originally Posted by Khanattila View Post
 Device Version                                    OpenCL 1.0 CUDA
According to khronos API:
 If the -cl-std build option is not specified, the CL_DEVICE_OPENCL_C_VERSION is used to select the version of OpenCL C to be used when building the program executable for each device.
Possible the same source code generate different machine code. In this case slower.
(-cl-std=CL1.0 is not allowed)
I believe that "CL_DEVICE_OPENCL_C_VERSION" refers to "OpenCL C Version" which in my case is "OpenCL C 1.1".
Old 4th January 2015, 23:15   #62  |  Link
Khanattila
Khanattila's Avatar
But your device only support OpenCL 1.0, so I guess some instructions are downgrade for backward compatibility.
In a OpenCL program the kernel (the problem to be solved) is compiled just before running.
Probably I used some instruction OpenCL 1.1.
Khanattila is offline   Reply With Quote
Old 5th January 2015, 00:21   #63  |  Link
Khanattila
Khanattila's Avatar
Edit.
Old 5th January 2015, 00:45   #64  |  Link
Groucho2004
032:
Frames processed:               500 (0 - 499)
FPS (min | max | average):      13.51 | 14.27 | 13.86
CPU usage (average):            25%
GPU usage (average):            95%
Thread count:                   8
Memory usage (phys | virt):     74 | 73 MB
Time (elapsed):                 00:00:36.062
034 (legacy = true):
FPS (min | max | average):      13.52 | 14.26 | 13.86
Thread count:                   8
Memory usage (phys | virt):     90 | 88 MB
Time (elapsed):                 00:00:36.063
So, performance is identical to 0.3.2 but the memory usage is a tiny bit higher.
Old 8th January 2015, 16:15   #65  |  Link
Khanattila
Khanattila's Avatar
Edit.
Old 8th January 2015, 17:10   #66  |  Link
Groucho2004
0.4.0 does not work with my card (GT240) any more, whether I specify "legacy = true" or not:
[clBuildProgram (CL_BUILD_PROGRAM_FAILURE)]
I guess that's by design?
Old 8th January 2015, 18:03   #67  |  Link
Khanattila
Khanattila's Avatar
OpenCL, NVIDIA and portability, can not be together
Please use this plugin that generates a debug file, link.
EDIT.
Old 8th January 2015, 18:23   #68  |  Link
Groucho2004
Log file:
"Language version specified by -cl-std is greater than the language version supported by the device!"
Old 8th January 2015, 18:59   #69  |  Link
Khanattila
Khanattila's Avatar
Log file:
Fixed, just re-download.
Thanks Nvidia.
In this version (0.4.0) I have specified -cl-std 1.1 because AMD support OpenCL >1.2 and could create problems. With legacy = true this check is now disabled.
Old 8th January 2015, 19:06   #70  |  Link
Groucho2004
Works, thanks!
Just to confirm - Memory consumption is lower than with the last version (0.3.4)
Old 9th January 2015, 23:33   #71  |  Link
Groucho2004
This has been asked before in this thread a couple of times - any plans to implement temporal mode?
Old 10th January 2015, 12:59   #72  |  Link
Khanattila
Khanattila's Avatar
First I have to solve a performance problem with B > 1 or 2.
Problem size is := [-Ax, ..., Ax] x [-Ay, ..., Ay] x [-Dpast, ..., Dfuture].
So Az=1 (three frame processing) is three times slower.
EDIT.
B = 0, 13.48 FPS //correct
B = 1, 41.38 FPS //correct
B = 2, 47.82 FPS //wrong, expected ~67 FPS
B = 3, 24.01 FPS //wtf???
Old 28th February 2015, 15:59   #73  |  Link
Pulp Catalyst
could anyone recommend a default that will give be a ultralight kind of setting, i only want the bare minimum, my aim is so the original source will be affected so lightly that it will not be detected by the naked eye, i've been using the ultralight setting on Handbrake (vidcoder i use), but i don 't know the config parameters of course they use. (the strength value is very low though, and surprisingly still give very pleasing results as a generic profile)
if anyone can suggest recommended values and possible an example NLMeansCL2(????), that would be great.
Thanks,
p.s i really hope that a gpu version of this gets ported over to handbrake though one day.... the cpu version is so SLOWWWWW lol
Pulp Catalyst is offline   Reply With Quote
Old 10th March 2015, 16:33   #74  |  Link
Khanattila
Khanattila's Avatar
Thanks,
Handbrake's nlmeans it's very different:
1) use a temporal search;
2) use a median filter (3x3 / 5x5);
3) use a edge mask;
4) other.
Normally, NLMeans2CL(A=4, S=2, B=1, h=1.3) is light enough.
Old 11th March 2015, 04:39   #75  |  Link
Pulp Catalyst
NLMeansCL2(A=4, S=2, B=1, h=1.3, device_type="GPU")
I'm giving it a try, thanks for the feedback.
I did not realize the handbrake NLMeans was so different, is there version more mature than this one (has more features)?
I also hope for the day when i can insert this version into QTGMC .... Wink Wink.
Old 11th March 2015, 08:59   #76  |  Link
feisty2
I'm Siri
feisty2's Avatar
TNLMeans got a temporal mode but it's sloooooooow like hell and no support for high bitdepth
feisty2 is offline   Reply With Quote
Old 21st March 2015, 16:57   #77  |  Link
Stereodude
What is the expected behavior if the arguments passed to NLmeanCL2 require more resources (VRAM?) than the OpenCL device has?
I was trying to run this script suggested in this thread on a FHD source.
nlmeanscl2(a=10,b=0,s=4,lsb_inout=true,h=4.8,aa=3.2, device_type="GPU", info=true)
With both the Intel HD 4600 (i7-4770k) and Nvidia GT440 (1gB) the graphics driver crashes (momentary black screen followed by a message in the system tray about it).
This message is returned to the application by AVIsynth
NLMeansCL2: Houston, we've had a problem!
[clCreateContext (CL_OUT_OF_RESOURCES)]
If I just use a NLMeansCL2 call of
nlmeanscl2(device_type="GPU", info=true)
it works fine.
I'm running Windows 7 x64 w/ 16gB of RAM and have the latest drivers on both the GT440 and the HD4600.
Stereodude is offline   Reply With Quote
Old 1st April 2015, 09:32   #78  |  Link
Khanattila
Khanattila's Avatar
it works fine.
Please, use GPU Caps Viewer: http://www.geeks3d.com/20150127/gpu-...23-0-released/
I need some more info. Most likely your system does not have enough video memory.
Validation => Submit. Get a link like that: http://www.ozone3d.net/gpudb/gpu.php?which=49098&v=2
Old 4th April 2015, 14:11   #79  |  Link
Stereodude
Here you go. http://www.ozone3d.net/gpudb/gpu.php?which=49162&v=2
Old 7th April 2015, 18:31   #80  |  Link
Mangix
Audiophile
Latest Nvidia drivers support OpenCL 1.2. Any performance benefits?
Mangix is offline   Reply With Quote
