Old 19th May 2012, 03:05   #801  |  Link
wiak
hey lord, please add basic audio demux/muxing support and it will be perfectly simple
no need for any encoding like MeGUI, just demux the original audio and mux it into mkv with the time delay if there is any
keep up the good work, its seems stable on my computer
Woah! Ninja?! http://nwgat.ninja/ (AV1 Overview)
"Not available in your region" has now been redefined as "Go Pirate, you filthy scum" Nwgat
wiak is offline   Reply With Quote
Old 19th May 2012, 03:27   #802  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Please read the section about audio encoding from the Readme file!
Old 19th May 2012, 10:05   #803  |  Link
docholliday
Hi Dude
How To use (Simple x264 Launcher) software...?
Can you Help me ?
Example : I want to encode m720p and how to setup software
Thanks Mate
I want this command-line to enter simple x264 software
x264-- 1280*544 -- bitrate 2600 -- ac3 5.1 48000 448 Kbps -- mkv -- 23.976 fps
what is the command-line ?
Thanks mate
docholliday is offline   Reply With Quote
Old 19th May 2012, 12:39   #804  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by Y@SH@R View Post
Hi Dude
Can you Help me ?
Thanks Mate
Thanks mate
This is a GUI program. The program itself does not use or need a command-line.
Moreover it will generate the command-line that is needed to call the encoder for you. And, as this is a front-end to x264, audio encoding is not currently possible.
...with the exceptions mentioned in the README file.
Old 23rd May 2012, 18:01   #805  |  Link
michaelusa
Is the Readme file up to date? or am I missing something?
I pulled down the latest (I think..) JEEB x264 revision 2184 from http://x264.nl/, tested the --acodec option and it worked fine. Copying that version to the Launcher/toolset folder invokes an out-of date message. "Your revision of x264 is too old. Minimum required revision is 2189"
Please help, Regards Michael.
Last edited by michaelusa; 23rd May 2012 at 18:04. Reason: forgot to mention source of download
michaelusa is offline   Reply With Quote
Old 23rd May 2012, 18:15   #806  |  Link
LoRd_MuldeR
Software Developer
I don't think the builds from http://x264.nl/ (although built by JEEB too now) include the audio support patch!
The builds from JEEB's web-site do include that patch. But, as you have noticed, JEEB has't updated these builds for a while. They're still at r2184.
You either have to wait for JEEB to update his patched builds or you must decrease the minimum required x264 version manually.
(The Simple x264 Launcher contains that check to prevent people from encoding with outdated x264 versions - as many people tend to do)
Old 23rd May 2012, 19:41   #807  |  Link
michaelusa
Thanks for the quick response. I sent JEEB a question regarding an upgrade, Lets see what comes back.
Old 26th May 2012, 16:17   #808  |  Link
shinchiro
I think option to minimize to system tray when close might become handy too
shinchiro is offline   Reply With Quote
Old 27th May 2012, 12:50   #809  |  Link
LoRd_MuldeR
Software Developer
I will look for a way to implement this.
Old 29th May 2012, 14:51   #810  |  Link
VideoFanatic
Hi, I have a 4:3 720 x 576 video. Is the following the correct SAR to use?: 12:11
VideoFanatic is offline   Reply With Quote
Old 29th May 2012, 15:29   #811  |  Link
LoRd_MuldeR
Software Developer
720/576 * 12/11 = 1,363 ≈ 4/3
Old 1st June 2012, 16:49   #812  |  Link
dado023
isnt --fps valid x264 parameter? why do i get this error:
Intel Core i7-3720QM, Samsung DD3 8GB 1600 MHz, Intel HM77 (Panther Point), GeForce GT 650M 2GB DDR5 384pipelines :ETA, end of May.
dado023 is offline   Reply With Quote
Old 2nd June 2012, 04:08   #813  |  Link
stinman
Haven't been here in awhile, once again this gets better and better. I know audio is important but most will just re-mux the same audio back in, I would think, or just use the dts core. I love "Simple" x264 launcher and don't want it bloated up. Thanks again LoRd MuldeR!
stinman is offline   Reply With Quote
Old 2nd June 2012, 17:53   #814  |  Link
dado023
how can i force it to encode in 24fps?
Old 2nd June 2012, 18:23   #815  |  Link
Kaiser Bill
Hi LoRd_MuldeR. Want to thank you for this great app, which has now become the only one I use for converting from Avisynth scripts.
Would it be possible to add an option to hibernate after finishing any jobs rather than just shutdown? I very rarely use shutdown on my PC any more so hibernate would be a welcomed option, and the only addition I would really like to see.
Kaiser Bill is offline   Reply With Quote
Old 5th June 2012, 05:34   #816  |  Link
VideoFanatic
OK here's another one. I have a 352 x 576 PAL video. I would like an aspect ratio of 2.39:1. What calculation would I do in Wolfram Alpha to find out the SAR to use?
Old 5th June 2012, 09:45   #817  |  Link
kypec
User of free A/V tools
kypec's Avatar
I'd use --sar 43:11 which yields to 2.3888888888888888888888888888889 display aspect ratio. If you wanted to have 2.39:1 DAR precisely, the resulting SAR would be 2151:550 and I'm not sure if x264 (or H.264 specs) allow for such big numbers
The final error from 43:11 is negligible anyway, less than a pixel in horizontal resolution so no one cares about anyway.
kypec is offline   Reply With Quote
Old 5th June 2012, 12:13   #818  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Here you go: -
Old 5th June 2012, 17:05   #819  |  Link
VideoFanatic
Awesome tool. Thanks I will use that from now on. Just a question though. Mulder said for a 720 x 576 clip I should use 12:11 however your tool says 16:15. Which is correct? I tried both methods and both videos look the same as each other.
Old 5th June 2012, 17:44   #820  |  Link
SeeMoreDigital
12:11 conforms to the ITU (International Telecommunication Union) standard. And is the method used for correcting the shape of non-square pixel standard-definition media.
16:15 is mathematically correct. And is the method used for correcting the shape of non-square pixel high-definition media.
