Old 1st January 2009, 15:02   #201  |  Link
That card has the VP2 decoding engine that you require.
You can test it using the CUVID server/client applications at my web site. They are not licensed. You can find them at the bottom of this page:
http://neuron2.net/dgvc1decnv/dgvc1decnv.html
Guest is offline
Old 1st January 2009, 15:12   #202  |  Link
~bT~
н∂-ƒαиαтι¢
^ awesome! donation soon on the way
edit: donated
~bT~ is offline
Old 1st January 2009, 16:50   #203  |  Link
laserfan
Aging Video Hobbyist
Originally Posted by ~bT~ View Post
this is the card i have: http://support.packardbell.com/uk/it...amadeus_ipower
i don't see any info on CUDA.. pls help.
A definitive "Purevideo HD" card list can be found on this page in a PDF file in the column at left "PureVideo HD Support Table" (which BTW confirms the above). Maybe neuron2 you'll want to link to the doc from yours.
BTW I have a 9600GT (and Q6600 cpu/mobo) on-the-way so you sold another card and I'll be donating once the system's built!
laserfan is offline
Old 2nd January 2009, 08:31   #204  |  Link
nm
Note that Purevideo HD != VP2: http://en.wikipedia.org/wiki/PureVid...ing_confusions
The table you mentioned is somewhat incomplete for checking VP2 availability since it doesn't separate between different GeForce 8800 models, some of which do have VP2. The Wikipedia article lists these and also some of the GPUs that have VP3, i.e. full hardware decoding of VC-1 streams (not that it matters much since DGVC1DecNV works fine with VP2).
nm is offline
Old 2nd January 2009, 16:49   #205  |  Link
laserfan
Arrgh, I had seen that page and it confused me, cuz it has "some models" and "unknown" qualifiers in a couple of the columns. I guess there is no "definitive list" and I'm disappointed Nvidia's product manager(s) don't publish something more complete...
EDIT: I guess the wiki page *IS* complete assuming VP2 is the magic bullet. It's easy to get distracted by all the "PureVideo HD" qualifiers.
laserfan is offline
Old 2nd January 2009, 16:59   #206  |  Link
One needs VP2 or greater, e.g., VP3.
Guest is offline
Old 3rd January 2009, 05:45   #207  |  Link
Version 1.0.2 test
Here is a test version of DGVC1IndexNV.
* Support new audio types on BluRay disks.
* Improve audio delay calculation.
Don't freak out if your machine ID changes. Your old license file will continue to work. New licenses, however, will use a new ID method that doesn't change when you reformat, boot a different partition, change drives, etc.
http://neuron2.net/dgvc1decnv/DGVC1IndexNV102test.zip
Feedback on this version will be appreciated.
Guest is offline
Old 4th January 2009, 01:01   #208  |  Link
rica
It works; thanks.
Here is the sample file to give it a go:
http://www.mediafire.com/?sharekey=6...a6ed47efffdcad
And here is the log:
Stream Type: Transport [192]
Profile: Advanced
Level: 3
Frame Size: 1920x1088
SAR: 16x9
Display Size: 1920x1080
Frame Rate: 23.976024 fps
Colorimetry: BT.709* [2]
Frame Structure: Progressive
Frame Type: I
Coded Number: 267
Playback Number: 267
Frame Repeats: 0
Field Repeats: 0
Bitrate: 36.583
Bitrate (Avg): 34.209
Bitrate (Max): 51.926
Audio Stream: 1100: AC3 3/2 48 640
Audio Stream: 1101: AC3 2/0 48 192
Audio Stream: 1102: TrueHD AC3 3/2 48 640
Elapsed: 0:00:01
Remain: 0:00:00
FPS:
Info: Finished!
HW:
nVidia 260 GTX AMP2 Edition/
nVidia 8600 GTS
VIDIA System Information report created on: 01/04/2009 02:13:10
System name: RICA-PC
[Display]
Processor:		Intel(R) Core(TM)2 Duo CPU     E6750  @ 2.66GHz (2662 MHz)
Operating System:	Windows Vista (TM) Home Premium, 32-bit (Service Pack 1)
DirectX version:	10.0
GPU processor:		GeForce GTX 260
Driver version:		180.60
Stream processors:	216
Core clock:		650 MHz
Shader clock:		1400 MHz
Memory clock:		1050 MHz (2100 MHz data rate)
Memory interface:	448-bit
Total available graphics memory:	1662 MB
Dedicated video memory:	896 MB
System video memory:	0 MB
Shared system memory:	766 MB
Video BIOS version:	62.00.1A.00.0A
IRQ:			16
Bus:			PCI Express x16
[Components]
nvCplUIR.dll		2.2.200.00		NVIDIA Control Panel
nvCpl.cpl		2.2.200.00		NVIDIA Control Panel Applet
nvCplUI.exe		2.2.200.00		NVIDIA Control Panel
nvViTvSR.dll		7.15.11.8060		NVIDIA Video and TV Server
nvViTvS.dll		7.15.11.8060		NVIDIA Video and TV Server
nvDispSR.dll		7.15.11.8060		NVIDIA Display Server
NVMCTRAY.DLL		7.15.11.8060		NVIDIA Media Center Library
nvDispS.dll		7.15.11.8060		NVIDIA Display Server
NVCPL.DLL		7.15.11.8060		NVIDIA Compatible Windows Vista Display driver, Version 180.60
nvGameSR.dll		7.15.11.8060		NVIDIA 3D Settings Server
nvGameS.dll		7.15.11.8060		NVIDIA 3D Settings Server
rica is offline
Old 4th January 2009, 01:10   #209  |  Link
Thank you for your test result.
Guest is offline
Old 4th January 2009, 01:16   #210  |  Link
rica
You are welcome,
I'll send some more test results.
rica is offline
Old 4th January 2009, 18:42   #211  |  Link
rica
neuron, pls test this file; it doesn't work with 1.02_test while it works with 1.0.1.
http://www.sendspace.com/file/61lfv8
(btw, eac3to doesn't recognize this file)
Cut made via clip.exe as is.
rica is offline
Old 4th January 2009, 19:02   #212  |  Link
What do you mean by "doesn't work". It works fine for me.
Guest is offline
Old 4th January 2009, 19:25   #213  |  Link
rica
It plays the file but when i try to "save project", nothing happens and i get this:
Stream Type:
Profile:
Level:
Frame Size:
SAR:
Display Size:
Frame Rate:
Colorimetry:
Frame Structure:
Frame Type:
Coded Number:
Playback Number:
Frame Repeats:
Field Repeats:
Bitrate:
Bitrate (Avg):
Bitrate (Max):
Elapsed:
Remain:
FPS:
Info:
rica is offline
Old 4th January 2009, 19:53   #214  |  Link
OK, I know what's wrong. Standby...
Guest is offline
Old 4th January 2009, 20:00   #215  |  Link
Re-download 1.0.2test. My code for counting orphaned B frames was hosed.
Thank you for pointing this out!
Guest is offline
Old 4th January 2009, 22:29   #216  |  Link
rica
Yes, it works fine now, thanks
Profile: Advanced
Level: 3
SAR: 16x9
Frame Rate: 29.970030 fps
Frame Type: P
Coded Number: 374
Playback Number: 374
Frame Repeats: 0
Field Repeats: 0
Bitrate: 29.794
Bitrate (Avg): 29.388
Bitrate (Max): 32.593
Audio Stream: 1100: PCM 96K 24bit 2/0
Audio Stream: 1101: TrueHD AC3 3/2 48 448
Elapsed: 0:00:03
Remain: 0:00:00
FPS:
Info: Finished!
rica is offline
Old 6th January 2009, 17:31   #217  |  Link
~bT~
н∂-ƒαиαтι¢
i have a quick question.
i currently have 2 x 8600gs cards @ 512mb each.
i wanted to know if the encoding speed would increase if i got myself a 9800gtx @ 512mb?
my local store has got this bfg 9800gtx oc'd card for sale @ 97 quid which is really tempting me..
~bT~ is offline
Old 6th January 2009, 18:41   #218  |  Link
rica
DGVc1DecNV uses nVidia's HW decoder, doesn't encode anything. So nothing will change.
rica is offline
Old 7th January 2009, 17:34   #219  |  Link
~bT~
н∂-ƒαиαтι¢
^ i was thinking that if the decoding speed increases then maybe it would increase the encoding speed.
~bT~ is offline
Old 7th January 2009, 17:36   #220  |  Link
As discussed several times, any gain for transcoding will typically be small, because decoding time is small compared to encoding time.
Guest is offline
