Old 19th March 2011, 06:13   #1  |  Link
MacroBull
Audio codec analyzer
I'm looking for a software to compare audio quality.
Where can I download Audio codec analyzer for free?
Is this software powerful to analyze quality?
MacroBull is offline   Reply With Quote
Old 19th March 2011, 09:52   #2  |  Link
Ghitulescu
Ghitulescu's Avatar
Define quality.
Born in the USB (not USA)
Old 20th March 2011, 14:37   #3  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
One product that I am aware of is OPERA (not to be confused with the Opera web-browser ^^).
http://www.opticom.de/products/opera.php
Old 20th March 2011, 15:51   #4  |  Link
Ghitulescu
Ghitulescu's Avatar
The purpose of these tests is to assess the digital loss due to lossy compressions using psychoacoustics. It's no use to compare two different WAVs but consecutive generations of the same original.
Old 20th March 2011, 16:36   #5  |  Link
pandy
https://secure.wikimedia.org/wikipedia/en/wiki/PEAQ
http://sourceforge.net/projects/peaqb/
pandy is offline   Reply With Quote
Old 22nd March 2011, 18:09   #6  |  Link
LoRd_MuldeR
Software Developer
Sure, most objective metrics are "full reference" metrics, i.e. they compare the compressed/modified audio against the original audio.
If you want to compare the quality of two Wave files using such an objective metric, you'd use the metric to compare each Wave file against the "perfect quality" source file individually.
Then you can compare the results of the two Wave files. The Wave file that got the "better" score obviously has the higher quality (with respect to the metric used).
analyze, audio, quality
