Old 11th September 2016, 17:29   #20981  |  Link
CruNcher
CruNcher's Avatar
Nice contribute results please to the Decoder Thread, we know some stuff from Reviews already but it's always good to have more input data, especialy since the driver changed especialy in the power efficiency domain and those changes never have been taken into account yet by reviewers
http://forum.doom9.org/showthread.php?t=171219
It is about Time
Old 11th September 2016, 17:44   #20982  |  Link
hoborg
Hello Nevcairiel.
I just want to say Thank you for continuing on this great piece of software!
Working machine: Win10x64 + Intel Skull Canyon
My HTPC.
How to start with Bitcoin
hoborg is offline   Reply With Quote
Old 11th September 2016, 19:15   #20983  |  Link
NikosD
Originally Posted by Sunset1982 View Post
seems you're right. HEVC decoding is now working on RX480 and LAV with latest crimson 16.9.1 drivers.
Can you decode this at 60fps ?
Netflix_TunnelFlag_4096x2160_60fps_x265_8bit_700Mbit.mkv
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 11th September 2016, 20:19   #20984  |  Link
CruNcher
CruNcher's Avatar
According to the Reviewer Data the current UVD Core used shouldn't have enough Performance reserves todo it
based on that Data i would say it would be nice allready to reach 30 fps
It is about Time
Old 12th September 2016, 09:25   #20985  |  Link
oddball
I have a problem using LAV splitter in MPC-BE. I have a line to only show forced English subtitles.
eng:eng|f;eng:off;*:eng;*:*
But it is being ignored in MPC-BE. Subtitles continue showing for every video with subtitles even if it's English language audio and English language subs. It works correctly in MPC-HC but I have other issues with that player so wanted to use MPC-BE instead.
LAV splitter is set to high priority and is definitely being loaded as I can see/use it in the system tray.
oddball is offline   Reply With Quote
Old 12th September 2016, 09:26   #20986  |  Link
nevcairiel
Some players simply override the stream choices, check its settings for anything related to that.
Old 12th September 2016, 09:28   #20987  |  Link
oddball
Wow! Fast reply!
I have but can't find anything in there regarding it. In MPC-HC there is an option 'Prefer forced and/or default subtitle tracks' which does not exist in BE. I am not sure if that is anything to do with why it works in one and not the other?
Old 12th September 2016, 09:31   #20988  |  Link
nevcairiel
LAV can only do an initial selection of streams, if the player then decides to select different streams, its not something LAV has any control over. So it absolutely depends on the player, if it honors the splitters choices or just does its own selection. Different players, different behavior.
Old 12th September 2016, 09:39   #20989  |  Link
oddball
OK thanks. I will have to ask in the BE player thread then.
Old 12th September 2016, 09:50   #20990  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Uncheck this.
http://imgur.com/a/Jwtu7
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 12th September 2016, 12:49   #20991  |  Link
oddball
Originally Posted by Aleksoid1978 View Post
That did the trick thanks.
Old 12th September 2016, 13:05   #20992  |  Link
CruNcher
CruNcher's Avatar
Soory nevcairiel for being of topic but some RX 4xx users are here.
Did some RX 460,470 480 user tried if Strongene Lentoids Hybrid OpenCL Decoder still works, as each IDCT,MC and PP part is generation individually optimized and chosen at runtime i wonder if it still works @ all on Polaris GCN 4.0 supporting the Decoding or fails or if it's going to fallback to the Tonga\Hawai or some Generic GPU/CPU Path ?
It is about Time
Old 18th September 2016, 00:20   #20993  |  Link
filler56789
SuperVirus
filler56789's Avatar
Originally Posted by filler56789 View Post
apparently LAV Splitter doesn't support multichannel DTS Express
samples: http://www.mediafire.com/download/8i...SX-samples.zip
And that won't change until libdcadec supports DTS Express.
Now it does support — thanks again, Nev
Hopefully we all can do without the Arcsoft DLL, from now on
filler56789 is offline   Reply With Quote
Old 19th September 2016, 15:26   #20994  |  Link
Clemens
dxva2 bug with this video and Nvidia graphics
Hello,
I have heavy artifacts if I use dxva2 (native) with my GTX 960 4gb, with Software decoding or QSV it's no problem.
The content is of a TV channel, some of the times its just fine on that channel sometimes I get the artifacts.
Here you can download the sample (is SD and I think H.264): https://www.dropbox.com/s/2zxhgqx2dh...ia_bug.ts?dl=0
Is this a known bug? Is there a workaround? Have others also problems with Nvidia graphics playing this short sample?
If needed I want to make screen record of the artifact...
Thanks and kind regards,
Clemens
Clemens is offline   Reply With Quote
Old 19th September 2016, 16:47   #20995  |  Link
the same happens with my 960.
disable SD in hardware acceleration and you should be fine.
Old 19th September 2016, 18:37   #20996  |  Link
NikosD
I thought only very old ATI cards had that bug with SD H.264 clips.
And ATI has fixed that a long time ago.
And now Nvidia has the same bug ?
Is it only for Maxwell or Pascal too ?
Old 19th September 2016, 19:19   #20997  |  Link
this looks like broadcast. so this could be a simple error in the stream it can't handle.
there could be a bug in lav filter too because CUVID is handling this properly.
there is more than one clip that is know to make trouble with DXVA.
so just lay back and wait. we will see where the real issue comes from.
Old 19th September 2016, 21:11   #20998  |  Link
clsid
That file has invalid data at the start. Happens often with recorded .ts files. The software decoder can usually discard that and recover. You will notice black screen first two seconds. Hardware decoding doesn't have good error resilience.
CUVID also fails here (with a pretty old driver version).
Old 19th September 2016, 21:41   #20999  |  Link
Clemens
Thats not the problem I think, when looking at it live (and much longer) then the same artifacts are there no matter how much I restart the stream. (on that particular channel it isn't a problem all of the time, depends on what they broadcast haven't found a pattern yet).
But its no big deal off course, I can switch hardware decoder to another or turn hardware decoding off for SD. If the bug gets fixed nice if not then no problem, just wanted to report the bug also not quite sure if this is the right place for reporting bugs, if I can do something else please tell.
And thanks for looking at it...seems to be a very nice forum!
Kind regards
Old 19th September 2016, 21:51   #21000  |  Link
clsid
Well, FFplay shows errors. You can test for yourself if you want.
https://ffmpeg.zeranoe.com/builds/
