Old 25th January 2010, 03:37   #21  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@mackworth
download package in first post of this thread
set paths to all required tools in settings tab
move ffms2.dll from FFMS2 folder to your AviSynth plugins folder
try conversion again
MuLTiTaSK is offline   Reply With Quote
Old 25th January 2010, 09:05   #22  |  Link
_hawk_
BluRip author
BluRip: 1-click BluRay/m2ts to h264 mkv converter
I created a new GUI for eac3to, BDsup2sub, x264 & mkvmerge
You only have to select streams you want - rest runs automatically.
Please let me know, if you have ideas for new features.
Next on list is 720p support.
Greets
_hawk_
Link: http://code.google.com/p/blurip/
_hawk_ is offline   Reply With Quote
Old 25th January 2010, 09:26   #23  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
welcome glad you came i created a thread for your program->BluRip v0.4.0 - BLURAY->1080p AVC MKV ONE CLICK CONVERTER
Old 25th January 2010, 09:30   #24  |  Link
_hawk_
BluRip author
Originally Posted by MuLTiTaSK View Post
@_hawk_
Thx saw it after I created my thread.
So you already used my tool? Any problems?
Old 25th January 2010, 09:36   #25  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
no problems i found very good coding helps save alot of time with BluRay->MKV conversion
now that your hear i know the community can help you improve it
Old 25th January 2010, 09:42   #26  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
some ideas i have for BluRip
support for bdmuxing selecting streams skiping encoding muxing to .mkv
script import .avs
DGIndexNV support
AviSynth filter profiles
Old 25th January 2010, 10:05   #27  |  Link
_hawk_
BluRip author
I hope so
In german forum I didn't get any reply yet...
AviSynth profiles should be no problem.
Does DGIndexNv support commandline usage?
What do you mean with avs script import? The avs is created from results of autocrop - if you have AVS profiles custom commands are added after crop/resize.
What do you mean with 'support for bdmuxing selecting streams skiping encoding muxing to .mkv'?
Old 25th January 2010, 10:23   #28  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
DGDecNV can be called from commandline and it decodes and indexes BluRay video using the gpu
if i have already created a AviSynth script with indexed source cropped, resized, denoised, sharpen etc i would like to import it in BluRip .avs->encode->mux
bdmuxing means open movie with BluRip select streams then mux to .mkv skipping cropping and encoding
Old 25th January 2010, 11:04   #29  |  Link
setarip_old
setarip_old's Avatar
@_hawk
Hi!
(Previously asked in thread started by "MuLTiTaSK)
What would I select if all I wanted to do was convert the subtitles and create an otherwise unaltered (NO re-encoding or cropping) .MKV file from the .M2Ts file?
setarip_old is offline   Reply With Quote
Old 25th January 2010, 11:24   #30  |  Link
_hawk_
BluRip author
Originally Posted by setarip_old View Post
@_hawk
Hi!
Atm you have to do Demux & Process subtitles (not using the start button)
Then edit the *_streamList.xml file:
change <encodedFile /> to <encodedFile>filenametoyourvideo</encodedFile>
Load the changed streamList file.
Now muxing should work
I can add an option to use untouched video in next release.
Old 25th January 2010, 11:30   #31  |  Link
_hawk_
BluRip author
@_hawk_
I'll add muxing without reencoding in next version.
I can add options to edit the streamlist. But if you only want to mux existing files it may be easier to use megui or something?
If I have a lot of free time I'll take a look at DGAVCDecNv - only have a ATI in my main PC.
Old 25th January 2010, 15:21   #32  |  Link
mackworth
That seemed to work.
Seems to work pretty well. I like how it doesn't mess with the audio stream like ripbot does. Although it would be nice to transcode the audio when needed.
mackworth is offline   Reply With Quote
Old 25th January 2010, 15:44   #33  |  Link
_hawk_
BluRip author
I think I'll add some audio downmix options when I add 720p support.
But I don't want BluRip to become to complicated
There are a lot of GUIs that support every single option...
BluRip : 1-Click BluRay/m2ts to h264 mkv converter
Old 26th January 2010, 08:38   #34  |  Link
_hawk_
BluRip author
New version - changelog
Changelog
v0.4.1
- Added AviSynth profiles
- Support for muxing untouched video
- Support for 720p resizing
v0.4.0
- Added support for 2-pass profiles
- Bugfix: Subtitles were not muxed
- Bugfix: Stream number for subtitles in Sub folder not incremented
v0.3.9
- Added support for .m2ts files
v0.3.8
- Option to use -core for DTS-HD tracks
- Quotes around all filenames
v0.3.7
- Removed MediaInfoWrapper - used interface form MediaInfoDll
- Fixed typo for crop modes
- Log windows for each step
- Copy subtitles in same order as in streamlist
v0.3.6
- First public release
Old 27th January 2010, 04:02   #35  |  Link
johnny50
Where is Avisynth after installing it? After installing all the tools necessary to run BluRip I get an error that states
avs[error]:failed to load Avisynth
x264[error]:could not open the input file 'c:\temp\_encode.avs'
Any idea why?
johnny50 is offline   Reply With Quote
Old 27th January 2010, 04:35   #36  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@johnny50
move ffms2.dll -> C:\Program Files (x86)\AviSynth 2.5\plugins
which programs did you actually install and what versions where they?
Old 28th January 2010, 04:59   #37  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
v0.4.1
Old 28th January 2010, 16:33   #38  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
v0.4.2
- Added option to downsample AC3 & DTS tracks
- Added DTS Hi-Res to dts audio tracks
- Resized GUI (smaller)
- Added some file existence checks
Old 30th January 2010, 09:52   #39  |  Link
DIEGO7-5
I keep getting an extraction error on all files (downloaded and tried several times). I use Windows XP Pro SP2 and no download managers.
DIEGO7-5 is offline   Reply With Quote
Old 31st January 2010, 00:27   #40  |  Link
_hawk_
BluRip author
Just tried to download and extract latest zip - no problems. Maybe you can try another unpacker?
blu-ray, blurip, eac3to, ffms2, mkv, mkvtoolnix, x264
