Old 20th December 2005, 20:42   #21  |  Link
guada 2
Sorry Beteboy,
It is similar.
The problem persists.
guada 2 is offline   Reply With Quote
Old 21st December 2005, 00:11   #22  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
Originally Posted by guada 2
Sorry Beteboy,
It is similar.
OK... i'll look into it....
Here is v0.71d:
http://picard.exceed.hu/tcpmp/test/t...in32.0.71d.zip
and it now includes:
- AVC weighted prediction support
Dan "BetaBoy" Marlin
Ubiquitous Multimedia Technologies and Developer Tools
http://corecodec.com
BetaBoy is offline   Reply With Quote
Old 21st December 2005, 04:35   #23  |  Link
CruNcher
CruNcher's Avatar
as soon as it supports cabac i try it
It is about Time
Old 21st December 2005, 04:43   #24  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
it does: http://forum.doom9.org/showthread.ph...347#post754347
Old 21st December 2005, 06:02   #25  |  Link
CruNcher
CruNcher's Avatar
ups sorry , yeah wow this thing is fast damnit nice work Betaboy really nice playback of that 1920x1080p sample is not easy but TCPMP + CoreAVC do it perfect looking forward for a Directshow Filter and implementation into mplayer and VLC would be also nice but i see you don't want to open it for now what a pitty Like you have another Skal on your team now hehe this Picard guy really knows low level coding it seems. Skals Decoder should be as fast as this If the Encoder gets the same optimization cure as the decoder my my alot have to watch out and CoreAVC Encoder could be in the future on the 1 place here on Doom9 i wish it CoreCodec so much that this becomes reallity
@BetaBoy
something is strange with the ffmpeg.plg it's very slow compared to CoreAVC rendering to slow compared with a recent ffdshow build hmm seems you useing a very outdated ffmpeg with libavcodec here ?
It is about Time
Old 21st December 2005, 06:48   #26  |  Link
superdump
Posts: n/a
I look forward to trying CoreAVC when binaries are available for dshow use. *Looks at Toff* And it will be nice to have another AVC codec on the scene. By the sounds of the the quality of the decoder is very good so... Thanks for the news Betaboy and good luck with the programming for this little lot.
Old 21st December 2005, 07:19   #27  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
http://picard.exceed.hu/tcpmp/test/avc.win32.0.71e.zip
Plugin 'only' for TCPMP for Windows... with the new AVC weighted prediction support
Old 21st December 2005, 18:19   #28  |  Link
DeathTheSheep
<The VFW Sheep of Death>
DeathTheSheep's Avatar
So now it supports everything except lossless, CQM, and interlaced stuff (x264 doesn't do interlaced encoding anyway)! It's very fast, and it's optimized for the PocketPC, so it performs even better there relative to the PC.
Sony's PSP AVC decoder, shabby as it is, is falling behind rapidly, as is Nero's PocketPC AVC decoder, it seems...
The age of true handheld AVC-HP has arrived with a BOOM thanks to Picard, BetaBoy, and the TCPMP team!
Recommended all-in-one stop for x264/GCC needs on Windows: Komisar x264 builds!
DeathTheSheep is offline   Reply With Quote
Old 22nd December 2005, 03:10   #29  |  Link
Sirber
retired developer
Sirber's Avatar
I'm upgrading my 400Mhz PPC with the latest TCPMP.
currently decoding x264 (Q35) + vorbis (8kbps) = 65% realtime with FFMPEG
Detritus Software
Sirber is offline   Reply With Quote
Old 22nd December 2005, 03:58   #30  |  Link
Sirber
retired developer
Sirber's Avatar
110% with new codec
great work!!!
Detritus Software
Old 22nd December 2005, 04:17   #31  |  Link
Sirber
retired developer
Sirber's Avatar
Any clue why bench I ahve all frames while in real playback I have dropped frames? It's unfair
Detritus Software
Old 22nd December 2005, 04:20   #32  |  Link
DeathTheSheep
Well, AVC is a format in which certain scenes of the video requre more processing power than others--more complex in certain areas than in others.
While benchmarking, the 110% you achieve is an average. As such, it is very inconsistent throughout the video stream--some places in the video may decode at 250% while others lag at 75%. In realtime playback, you notice the more complex places with frame drops.
Old 22nd December 2005, 04:36   #33  |  Link
Sirber
retired developer
Sirber's Avatar
ok... fair enough
Also it might be my PPC, but I cannot playback from SD card It jam after few seconds.
Detritus Software
Old 22nd December 2005, 16:58   #34  |  Link
DeathTheSheep
Oh? Try freeing some ram, giving it to mostly program memory, and/or adjust the player's buffer size in the settings-> player menu.
If the problem keeps up, try uninstalling some 3rd-party programs, removing the SD card, and doing a soft-reset (keeps your data). Then try it again
Old 22nd December 2005, 17:28   #35  |  Link
HQ-LQ
have you already a directshow-decoder?
translated by google
thanks for reading
HQ-LQ is offline   Reply With Quote
Old 22nd December 2005, 18:13   #36  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
@BetaBoy
It is from source coode from about 3 months ago.... However even with the changes that thay have made it would not make a diff with the current code.
This is why we made the choice to do a decoder/encoder from scratch and expand our business model to include AVC as we were going to license it anyway for TCPMP and our licensees.
Toff is working on it now and we hope to have it out as soon as possible.
Old 22nd December 2005, 18:38   #37  |  Link
Scarpad
I've been waiting to get AVC support. I have an Axim X30 624mhz PPC, anyone using it with this hand help. I primarily want to use the files I create for my Ipod Video on the PPC. The files are only 320x240 at 768kbps
Scarpad is offline   Reply With Quote
Old 22nd December 2005, 22:57   #38  |  Link
PicardGK
We are both demoscene trained
Heaven 7
That plugin is not meant for real life usage. I'am building it with Visual Studio without any gcc inline assembly (mmx/sse). Maybe I will have look at the DivX version of ffmpeg where the assembly stuff is separated to libavdsp.
PicardGK is offline   Reply With Quote
Old 22nd December 2005, 23:26   #39  |  Link
nm
Heaven 7
Still my favourite 64k intro , though I haven't followed the scene much lately.
Nice work you're doing here too.
Old 22nd December 2005, 23:36   #40  |  Link
CruNcher
CruNcher's Avatar
yeah picard i got your exceed background very impressive nice to see you working on multimedia solutions , and yes heaven 7 is also 1 of my favs hehe
You mean Dr.DivX OSS with that ?
It is about Time
codec, coreavc, corecodec, coremvc, cuda, decoder, dxva, h.264, mvc, scam
