Old 3rd April 2013, 04:48   #141  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Originally Posted by foxyshadis View Post
It's actually a reasonably fast range coder, and keeps separate state in both threads; most of the time seems to be spent in prediction, which is already SIMD'd to hell and back.
That seems kind of hard to believe -- median prediction only takes a few SIMD operations per 16 pixels, while even a highly optimized arithmetic coder like x264's takes a dozen or two cycles per output bit. Is something else odd going on here?
Old 4th April 2013, 01:01   #142  |  Link
zerowalker
Is anyone able to decode Lagarith with the 64 bit version of Avisynth?
I get FourCC error.
I can decode it if i use Lavfilterīs decoder for it though, but itīs a bit problematic.
zerowalker is offline   Reply With Quote
Old 3rd July 2013, 22:13   #143  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
A kind soul would add multithreaded colorspace rgb<->yuv conversion as well - a fairly straightforward optimization, which would make both encoding+decoding faster.
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 5th November 2013, 04:09   #144  |  Link
Lenchik
Can anyone add YV24 support to Lagarith, please?
Lenchik is offline   Reply With Quote
Old 16th November 2013, 19:07   #145  |  Link
SirLagsalot
I am experimenting with re-writing Lagarith to support high-bitdepth (10 bits/color channel or more). To do this though, I need to know what color formats would be the most useful, and sample videos in those formats. Hopefully, some people in this thread would be willing to provide such video. My criteria for test video is as follows:
  • Must be from a source that uses the full bitdepth (upsampled video will not properly test the compression).
  • Should not have lossy compression applied
  • Should not have been resized
  • Uncompressed AVI would be the desired format, since it guarantees that I will be able to access the video
  • Should be short to keep the file size reasonable (100 frames or so is plenty)
SirLagsalot is offline   Reply With Quote
Old 16th November 2013, 19:49   #146  |  Link
zerowalker
Donīt have any sample videos, but can say state some color formats.
First YV24, even though itīs mostly unnecessary, it shouldnīt be to hard to implement while you are at it.
And then Rec.709, which is extremely useful but very rarely supported in a lossless codec.
Well thatīs probably about it now that i think about it, i hope that was something you wanted to know, or perhaps you wanted to know something about bitdepth and such, if so i provided the wrong information.
I hope you see this through, Lagarith is an underestimated codec, and whatīs it mostly is lacking is support and perhaps tweaks for encoding/decoding with newer CPU instructions.
EDIT:
Original 10bit videos will probably be quite hard to obtain, but itīs fairly simple to make one.
Take a video with much darkness and gradients. Fix it with Avisynth and work in 16bit.
Dither it to 10bit.
That way it wonīt be upsampled from 8bit for no reason, and there should be pretty useful information in the last 2 bit that should have impact on compression.
But of course a 10bit Broadcast tape would be preferred, but canīt see a way to obtain one if you donīt have some good contacts.
Old 17th November 2013, 00:51   #147  |  Link
qyot27
qyot27's Avatar
The better reason to support YV24 (and YV16, YV411, and Y8) is because that rounds out all the colorspaces that AviSynth 2.6 supports.
And really, if Rec.709 support gets added, might as well future-proof it a bit and also add Rec.2020.
Old 17th November 2013, 00:57   #148  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
ffmpeg can make nice high bit depth / deep color test videos...
EDIT test ramps seem to be generated with 8-bit math - sorry for not checking previously.
Try this thread: http://forum.doom9.org/showthread.php?t=158836
raffriff42 is offline   Reply With Quote
Old 17th November 2013, 20:45   #149  |  Link
SirLagsalot
I can use upsampled or generated high-bitdepth video for developing and testing for losslessness, but to really tune the compression algorithms and speed optimizations, I need real footage. The upsampled/generated video simply won't have the same statistical distribution for the synthesized bits, and that could skew the results. I don't need test video immediately either, just in the next couple of months.
Since this would be a re-write, I would like to simplify how color formats are handled so it is easier to support more of them. YV24 and YV8 would probably be added, and Lagarith can already support encoding YV16.
I don't think I will add an option for Rec.709 (or Rec.2020), since it is another option the user has to get right or they can introduce noticeable loss. I feel that is an option better left to the encoding or decoding program.
Old 17th November 2013, 22:00   #150  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
OK try:EDIT
Old 17th November 2013, 23:04   #151  |  Link
ChiDragon
ChiDragon's Avatar
Do you have any use for crummy-looking 10-bit footage? I can send you some VHS captures in v210, but I haven't figured out how to verify if the devices are actually filling those bits.
ChiDragon is offline   Reply With Quote
Old 17th November 2013, 23:56   #152  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Define "real". Every 10bit footage is artificially produced one way or another. If Ill take some video, apply to it 16bit color correction, dither it down to 10bit - would that be real enough for you?
Edit: actually sorry. something like that was already suggested by zerowalker. Only that "Broadcast tape" is not any different and just as "real" as the footage people here proposed.
Old 18th November 2013, 01:40   #153  |  Link
ChiDragon
ChiDragon's Avatar
Howso? If color-correcting a 10-bit source was no different than starting from an 8-bit source, there would be no high-depth film scanners.
Old 18th November 2013, 04:27   #154  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
If you answered to me, whatever you don't understand what I'm saying or I poorly explained it. By "If Ill take some video" I mean if I'll take 8-bit video. And after color correction, new color values will be created. Resulting footage is just as "real" as any other 10bit footage. And in fact may be even better, as most of the 10bit footage is created during production and not by scanners. Of course 3DCG rendered at 10+bits is an option too.
Old 20th November 2013, 04:27   #155  |  Link
SirLagsalot
Originally Posted by Keiyakusha View Post
Define "real".
Either unprocessed source from a high-bitdepth camera, film scanner or similar capture source, or complex CG renderings done in high-bitdepth. Footage from an analog capture source is what I am most interested in, since I want to see how noisy such sources are. I figure if Lagarith can handle those types of footage well, it'll shouldn't have any trouble on upsampled video.
Originally Posted by raffriff42
Links
Those look like they should be useful.
Sure, I can check if it is using the full bit-depth.
Old 24th November 2013, 11:05   #156  |  Link
zerowalker
Wait, are Broadcast Tapes 10bit upsampled?
Arenīt those originally in 10bit, but everything that actually shows to the World (Cinema, TV, DVD you name it) is 8bit, so the actual original (At least for broadcasts) are never actually seen?
It makes no sense if they just have 10bit tapes for the heck of it, if all material is actually 8bit, and when they are going to show it, they dither it down after it was upsampled once.
EDIT:
Not adding Rec.709 etc will actually be worse than not adding it.
As if you have RGB and save it to YV something, you will automatically convert it to Rec.601, so if thatīs wrong the only way to solve it is through Avisynth and Colormatrix conversion, which is a lot more advanced, and also not perfect.
I think you could add it as, "Expert", or something, cause Decoding will not solve this if itīs converted, as it will stay Rec.601 all the time.
Old 24th November 2013, 20:08   #157  |  Link
benwaggoner
Storing in higher precision makes it possible to do overlays, color correction, etcetera without having to add more dither with every single filter. The same reason professional formats are all 4:2:2 even though all delivery formats are 4:2:0.
Ben Waggoner
My Compression Book
Old 25th November 2013, 01:49   #158  |  Link
zerowalker
I see, so 4:2:2 are also upsampled?
Though i am pretty sure that thing were broadcasted as 4:2:2 before Digital took over.
Old 25th November 2013, 02:14   #159  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
zerowalker
You are doing too strong accent on the word "upsampled". For some reason I feel some kind of disappointment in your posts. It doesn't matters if it's upsampled or not. Also even though video often starts as 8bit, if some 16/32 bit processing applied to it (after which it is dithered to 10bit for archiving, delivery, whatever), you can no longer call it "upsampled". It became "real".
If you're talking about upsampled video that was simply converted 8->16bit without any further modifications.... why would someone want to compress it with lagarith? I don't see the reason for that. I only happens when you was requested to deliver some footage in some "standard" format, which happened to be 10bit. In case of lagarith one would compress it before upsampling and upsample when needed. But I also don't think one would use 10bit lagarith for raw noisy captures. Not in professional world. And most likely more casual users won't do it either.
If you're talking about upsampled video that received some kind of processing on top of that, as I said above, I don't think you can call it "upsampled" anymore. This is exactly the kind of content for which you want to optimize the encoder. And not for some random noise... unless for lagarith it doesn't matter which content you have. But then there is even less reasons to optimize for something exotic
Old 25th November 2013, 04:19   #160  |  Link
Lenchik
For finding best x264 settings while not loosing time on repeating previoud work.
lagarith
