8th February 2009, 14:01 | #61 | Link | |
8th February 2009, 14:29 | #62 | Link |
ok i tried this...
resultS2H= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result2,"autowhite, manual levels correction",\ size=28,align=2).histogram(mode="levels")) resultS3H= stackhorizontal(subtitle(source2,"original",size=32,align=2),\ subtitle(result3,"autolevels + manual color correction",\ size=28,align=2).histogram(mode="levels")) resultS4H= stackhorizontal(subtitle(source2,"original",size=32,align=2),\ subtitle(result4,"manual colors and levels correction",\ size=28,align=2).histogram(mode="levels")) but now it says error in colum 157? can you just post your script please so the only thing i have to edit is load my movie .thanks |
8th February 2009, 14:41 | #63 | Link | |
Avisynth language lover
Is the script you posted earlier your complete script? It is missing lines from the start and end of the original script. |
8th February 2009, 15:22 | #64 | Link | |
8th February 2009, 16:18 | #65 | Link | |
1) Copy videoFred's script from post #14. Be sure to copy all of it, you will have to scroll down a few times. 2) Change the line at the start ["film = ..."] to put your movie filename in place of the original. 3) Make the changes I posted to correct line continuations (post #60). That's it! |
8th February 2009, 16:31 | #66 | Link | |
please just save us some time and show me the complete script for me thanks. please heres my script of what you said...... film="C:\Documents and Settings\king\Desktop\New Folder\mymovie.avi.avi") short="L" # L=long clip S=short clip try it! result="resultS3" # specify the wanted output here trim_begin=6 trim_end=6 play_speed=18.75 #trim frames and play speed (PAL: 16.6666 or 18.75) saturation=1.0 #saturation X=4 gamma=0.7 # X is a special parameter for reducing the autolevels effect black_level=0 white_level=255 output_black=0 output_white=255 # manual levels, when returning result4 AGC_max_sat=2 AGC_max_gain=1.0 #parameters of HDRAGC filter, improves colors and shadows blue=-4 red=2 #manual color adjustment, when returning result2. Values can be positive or negative denoising_strenght=800 #denoising level of first denoiser: MVDegrainMulti() denoising_frames= 4 #number of frames for averaging (forwards and backwards) 3 is a good start value block_size= 16 #block size of MVDegrainMulti() block_over= 4 #block overlapping of MVDegrainMulti() temp_radius=20 temp_luma=6 temp_chroma=6 #second denoiser: TemporalSoften grain_luma=10 grain_chroma=10 # this will add some digital grain to the final result, set it to zero if you do not want it. LSF_sharp_ness=250 LSF_radi_us=3 LSF_sub=1.5 #first sharpening parameters (LimitedSharpenFaster) sub=subsampling USM_sharp_ness=40 USM_radi_us=2 USM_thres_hold=0 #second sharpening parameters (UnsharpMask) USM_sharp_ness2=20 USM_radi_us2=1 USM_thres_hold2=0 #third sharpening parameters (UnsharpMask) maxstab=60 #maximum values for the stabiliser (in pixels) 20 is a good start value est_left=20 est_top=20 est_right=20 est_bottom=20 est_cont=0.8 #crop values for special Estimate clip CLeft=30 CTop=30 CRight=30 CBottom=30 #crop values after Depan and before final resizing (40,30,40,30) W=720 H=576 #final size from the returned clip bord_left=0 bord_top=0 bord_right=0 bord_bot=0 SetMemoryMax(1024) LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\DePan.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\DePanEstimate.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\RemoveGrain.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\HDRAGC.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mvtools.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mt_masktools.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\MaskTools.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\WarpSharp.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\LimitedSupport_09Jan06B.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\MT.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\autolevels.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\AddGrainC.dll") Import("C:\Program Files\AviSynth 2.5\Plugins\LimitedSharpenFaster.avs") SetMTMode(5) AVISource("C:\Documents and Settings\king\Desktop\New Folder\mymovie.avi.avi") converttoYV12 end= source1.framecount() end2= end-trim_end frames=end+trim_begin skip= end2/5 skip0=skip+3 skipend= 3 skipend1= skip0+3 skip2= skipend1+skip skipend2= skip2+3 skip3= skipend2+skip skipend3= skip3+3 skip4= skipend3+skip skipend4= skip4+3 skip5= end2-3 L= trim(source1,0,end2) LS= trim(source1,0,end2).scriptclip("""subtitle("frame "+string(trim_begin+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"\ +string(trim_end),x=100,y=60,size=32)""") sourceT1= trim(source1,0,skipend).scriptclip("""subtitle("frame "+string(trim_begin+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)\ +" steps: "+string(skip),x=100,y=60,size=32)""") sourceT2= trim(source1,skip0,skipend1).scriptclip("""subtitle("frame "+string(trim_begin+skip0+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+" steps: "\ +string(skip),x=100,y=60,size=32)""") sourceT3= trim(source1,skip2,skipend2).scriptclip("""subtitle("frame "+string(trim_begin+skip2+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+" steps:\ "+string(skip),x=100,y=60,size=32)""") sourceT4= trim(source1,skip3,skipend3).scriptclip("""subtitle("frame "+string(trim_begin+skip3+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+\ " steps: "+string(skip),x=100,y=60,size=32)""") sourceT5= trim(source1,skip4,skipend4).scriptclip("""subtitle("frame "+string(trim_begin+skip4+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+\ " steps: "+string(skip),x=100,y=60,size=32)""") sourceT6= trim(source1,skip5,end2).scriptclip("""subtitle("frame "+string(trim_begin+skip5+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+\ " steps: "+string(skip),x=100,y=60,size=32)""") SS= sourceT1+sourceT2+sourceT3+sourceT4+sourceT5+sourceT6 sourceT10= trim(source1,0,skipend) sourceT20= trim(source1,skip0,skipend1) sourceT30= trim(source1,skip2,skipend2) sourceT40= trim(source1,skip3,skipend3) sourceT50= trim(source1,skip4,skipend4) sourceT60= trim(source1,skip5,end2) S= sourceT10+sourceT20+sourceT30+sourceT40+sourceT50+sourceT60 stab_reference= eval(short).crop(est_left,est_top,-est_right,-est_bottom)\ .tweak(cont=est_cont).binarize(threshold=80).greyscale().invert() mdata=DePanEstimate(stab_reference,trust=1.0,dxmax=maxstab,dymax=maxstab) stab=DePanStabilize(eval(short),data=mdata,cutoff=0.5,dxmax=maxstab,dymax=maxstab,method=1,mirror=15) stab2= stab.crop(CLeft,CTop,-CRight,-CBottom).tweak(sat=saturation) stab3=DePanStabilize(eval(short),data=mdata,cutoff=0.5,dxmax=maxstab,dymax=maxstab,method=1,info=true) WS= width(stab) HS= height(stab) stab4= stab3.addborders(10,10,10,10,$B1B1B1).Lanczos4Resize(WS,HS) vectors= stab2.MVAnalyseMulti(refframes=denoising_frames, pel=2, blksize=block_size, overlap=block_over, idx=1) denoised= stab2.MVDegrainMulti(vectors, thSAD=denoising_strenght, SadMode=1, idx=1).tweak(sat=saturation) leveled= denoised.HDRAGC(coef_gain=2.0,max_gain=AGC_max_gain,min_gain=0.5,max_sat=AGC_max_sat,shadows=true) sharp1=limitedSharpenFaster(leveled,smode=1,strength=LSF_sharp_ness,overshoot=50,\ radius=LSF_radi_us, ss_X=LSF_sub, SS_Y=LSF_sub, dest_x=W,dest_y=H) sharp2= unsharpmask(sharp1,USM_sharp_ness,USM_radi_us,USM_thres_hold) sharpX= unsharpmask(sharp2,USM_sharp_ness2,USM_radi_us2,USM_thres_hold2) sharp3= sharpX.TemporalSoften(temp_radius,temp_luma,temp_chroma,15,2).addgrainC(grain_luma,grain_chroma,0.2,0.2,5) #backward_vectors = sharp3.MVAnalyse(isb = true,truemotion=true,idx=2) #forward_vectors = sharp3.MVAnalyse(isb = false,truemotion=true,idx=2) #frameclip=MVFlowFps(sharp3,backward_vectors, forward_vectors, num=25, den=1, ml=100, idx=2) result1= sharp3.addborders(X,0,0,0,$FFFFFF).levels(0,gamma,255,0,255).autolevels().coloryuv(autowhite=true)\ .crop(X,0,-0,-0).addborders(bord_left, bord_top, bord_right, bord_bot) result2= sharp3.levels(black_level,gamma,white_level,0,255).coloryuv(autowhite=true)\ .addborders(bord_left, bord_top, bord_right, bord_bot) result3= sharp3.coloryuv(off_U=blue,off_V=red).levels(0,gamma,255,0,255).addborders(X,0,0,0,$FFFFFF)\ .autolevels().crop(X,0,-0,-0).addborders(bord_left, bord_top, bord_right, bord_bot) result4= sharp3.coloryuv(off_U=blue,off_V=red).levels(black_level,gamma,white_level,0,255)\ .addborders(bord_left, bord_top, bord_right, bord_bot) result5= overlay(eval(short),stab_reference,x=est_left,y=est_top).addborders(2,2,2,2,$FFFFFF).Lanczos4Resize(WS,HS) W2= W+bord_left+bord_right H2= H+bord_top+bord_bot short2=short+"S" source2=Lanczos4Resize(eval(short2),W2,H2) source3=Lanczos4Resize(eval(short2),W,H) resultS1= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result1,"autolevels, autowhite",size=28,align=2)) resultS2H= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result2,"autowhite, manual levels correction",\ size=28,align=2).histogram(mode="levels")) resultS3H= stackhorizontal(subtitle(source2,"original",size=32,align=2),\ subtitle(result3,"autolevels + manual color correction",\ size=28,align=2).histogram(mode="levels")) resultS4H= stackhorizontal(subtitle(source2,"original",size=32,align=2),\ subtitle(result4,"manual colors and levels correction",\ size=28,align=2).histogram(mode="levels")) resultS2H= stackhorizontal(subtitle(source2,"original",size=32,align=2) ,subtitle(result2,"autowhite, manual levels\ correction",size=28,align=2).histogram(mode="levels")) resultS3H= stackhorizontal(subtitle(source2,"original",size=32,align=2),subtitle(result3,"autolevels + manual color\ correction",size=28,align=2).histogram(mode="levels")) resultS4H= stackhorizontal(subtitle(source2,"original",size=32,align=2),subtitle(result4,"manual colors and levels\ correction",size=28,align=2).histogram(mode="levels")) result6= stackhorizontal(subtitle(result5,"baseclip for stabiliser -only the B/W clip is used",size=32,align=2)\ ,subtitle(stab4,"test stabiliser: dx=horizontal, dy=vertical",size=32,align=5)) Last edited by kopmjj; 8th February 2009 at 16:33. |
8th February 2009, 16:39 | #67 | Link | |
It should not be there, that is your syntax error. You are also missing the last line of the script: Eval(result) |
8th February 2009, 16:50 | #68 | Link | |
again heres my script...... film="C:\Documents and Settings\king\Desktop\New Folder\mymovie.avi.avi" short="L" # L=long clip S=short clip try it! result="resultS3" # specify the wanted output here trim_begin=6 trim_end=6 play_speed=18.75 #trim frames and play speed (PAL: 16.6666 or 18.75) saturation=1.0 #saturation X=4 gamma=0.7 # X is a special parameter for reducing the autolevels effect black_level=0 white_level=255 output_black=0 output_white=255 # manual levels, when returning result4 AGC_max_sat=2 AGC_max_gain=1.0 #parameters of HDRAGC filter, improves colors and shadows blue=-4 red=2 #manual color adjustment, when returning result2. Values can be positive or negative denoising_strenght=800 #denoising level of first denoiser: MVDegrainMulti() denoising_frames= 4 #number of frames for averaging (forwards and backwards) 3 is a good start value block_size= 16 #block size of MVDegrainMulti() block_over= 4 #block overlapping of MVDegrainMulti() temp_radius=20 temp_luma=6 temp_chroma=6 #second denoiser: TemporalSoften grain_luma=10 grain_chroma=10 # this will add some digital grain to the final result, set it to zero if you do not want it. LSF_sharp_ness=250 LSF_radi_us=3 LSF_sub=1.5 #first sharpening parameters (LimitedSharpenFaster) sub=subsampling USM_sharp_ness=40 USM_radi_us=2 USM_thres_hold=0 #second sharpening parameters (UnsharpMask) USM_sharp_ness2=20 USM_radi_us2=1 USM_thres_hold2=0 #third sharpening parameters (UnsharpMask) maxstab=60 #maximum values for the stabiliser (in pixels) 20 is a good start value est_left=20 est_top=20 est_right=20 est_bottom=20 est_cont=0.8 #crop values for special Estimate clip CLeft=30 CTop=30 CRight=30 CBottom=30 #crop values after Depan and before final resizing (40,30,40,30) W=720 H=576 #final size from the returned clip bord_left=0 bord_top=0 bord_right=0 bord_bot=0 SetMemoryMax(1024) LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\DePan.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\DePanEstimate.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\RemoveGrain.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\HDRAGC.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mvtools.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mt_masktools.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\MaskTools.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\WarpSharp.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\LimitedSupport_09Jan06B.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\MT.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\autolevels.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\AddGrainC.dll") Import("C:\Program Files\AviSynth 2.5\Plugins\LimitedSharpenFaster.avs") SetMTMode(5) AVISource("C:\Documents and Settings\king\Desktop\New Folder\mymovie.avi.avi") converttoYV12 end= source1.framecount() end2= end-trim_end frames=end+trim_begin skip= end2/5 skip0=skip+3 skipend= 3 skipend1= skip0+3 skip2= skipend1+skip skipend2= skip2+3 skip3= skipend2+skip skipend3= skip3+3 skip4= skipend3+skip skipend4= skip4+3 skip5= end2-3 L= trim(source1,0,end2) LS= trim(source1,0,end2).scriptclip("""subtitle("frame "+string(trim_begin+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"\ +string(trim_end),x=100,y=60,size=32)""") sourceT1= trim(source1,0,skipend).scriptclip("""subtitle("frame "+string(trim_begin+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)\ +" steps: "+string(skip),x=100,y=60,size=32)""") sourceT2= trim(source1,skip0,skipend1).scriptclip("""subtitle("frame "+string(trim_begin+skip0+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+" steps: "\ +string(skip),x=100,y=60,size=32)""") sourceT3= trim(source1,skip2,skipend2).scriptclip("""subtitle("frame "+string(trim_begin+skip2+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+" steps:\ "+string(skip),x=100,y=60,size=32)""") sourceT4= trim(source1,skip3,skipend3).scriptclip("""subtitle("frame "+string(trim_begin+skip3+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+\ " steps: "+string(skip),x=100,y=60,size=32)""") sourceT5= trim(source1,skip4,skipend4).scriptclip("""subtitle("frame "+string(trim_begin+skip4+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+\ " steps: "+string(skip),x=100,y=60,size=32)""") sourceT6= trim(source1,skip5,end2).scriptclip("""subtitle("frame "+string(trim_begin+skip5+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+\ " steps: "+string(skip),x=100,y=60,size=32)""") SS= sourceT1+sourceT2+sourceT3+sourceT4+sourceT5+sourceT6 sourceT10= trim(source1,0,skipend) sourceT20= trim(source1,skip0,skipend1) sourceT30= trim(source1,skip2,skipend2) sourceT40= trim(source1,skip3,skipend3) sourceT50= trim(source1,skip4,skipend4) sourceT60= trim(source1,skip5,end2) S= sourceT10+sourceT20+sourceT30+sourceT40+sourceT50+sourceT60 stab_reference= eval(short).crop(est_left,est_top,-est_right,-est_bottom)\ .tweak(cont=est_cont).binarize(threshold=80).greyscale().invert() mdata=DePanEstimate(stab_reference,trust=1.0,dxmax=maxstab,dymax=maxstab) stab=DePanStabilize(eval(short),data=mdata,cutoff=0.5,dxmax=maxstab,dymax=maxstab,method=1,mirror=15) stab2= stab.crop(CLeft,CTop,-CRight,-CBottom).tweak(sat=saturation) stab3=DePanStabilize(eval(short),data=mdata,cutoff=0.5,dxmax=maxstab,dymax=maxstab,method=1,info=true) WS= width(stab) HS= height(stab) stab4= stab3.addborders(10,10,10,10,$B1B1B1).Lanczos4Resize(WS,HS) vectors= stab2.MVAnalyseMulti(refframes=denoising_frames, pel=2, blksize=block_size, overlap=block_over, idx=1) denoised= stab2.MVDegrainMulti(vectors, thSAD=denoising_strenght, SadMode=1, idx=1).tweak(sat=saturation) leveled= denoised.HDRAGC(coef_gain=2.0,max_gain=AGC_max_gain,min_gain=0.5,max_sat=AGC_max_sat,shadows=true) sharp1=limitedSharpenFaster(leveled,smode=1,strength=LSF_sharp_ness,overshoot=50,\ radius=LSF_radi_us, ss_X=LSF_sub, SS_Y=LSF_sub, dest_x=W,dest_y=H) sharp2= unsharpmask(sharp1,USM_sharp_ness,USM_radi_us,USM_thres_hold) sharpX= unsharpmask(sharp2,USM_sharp_ness2,USM_radi_us2,USM_thres_hold2) sharp3= sharpX.TemporalSoften(temp_radius,temp_luma,temp_chroma,15,2).addgrainC(grain_luma,grain_chroma,0.2,0.2,5) #backward_vectors = sharp3.MVAnalyse(isb = true,truemotion=true,idx=2) #forward_vectors = sharp3.MVAnalyse(isb = false,truemotion=true,idx=2) #frameclip=MVFlowFps(sharp3,backward_vectors, forward_vectors, num=25, den=1, ml=100, idx=2) result1= sharp3.addborders(X,0,0,0,$FFFFFF).levels(0,gamma,255,0,255).autolevels().coloryuv(autowhite=true)\ .crop(X,0,-0,-0).addborders(bord_left, bord_top, bord_right, bord_bot) result2= sharp3.levels(black_level,gamma,white_level,0,255).coloryuv(autowhite=true)\ .addborders(bord_left, bord_top, bord_right, bord_bot) result3= sharp3.coloryuv(off_U=blue,off_V=red).levels(0,gamma,255,0,255).addborders(X,0,0,0,$FFFFFF)\ .autolevels().crop(X,0,-0,-0).addborders(bord_left, bord_top, bord_right, bord_bot) result4= sharp3.coloryuv(off_U=blue,off_V=red).levels(black_level,gamma,white_level,0,255)\ .addborders(bord_left, bord_top, bord_right, bord_bot) result5= overlay(eval(short),stab_reference,x=est_left,y=est_top).addborders(2,2,2,2,$FFFFFF).Lanczos4Resize(WS,HS) W2= W+bord_left+bord_right H2= H+bord_top+bord_bot short2=short+"S" source2=Lanczos4Resize(eval(short2),W2,H2) source3=Lanczos4Resize(eval(short2),W,H) resultS1= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result1,"autolevels, autowhite",size=28,align=2)) resultS2= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result2,"autowhite, manual levels correction",size=28,align=2)) resultS3= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result3,"autolevels + manual color correction",size=28,align=2)) resultS4= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result4,"manual colors and levels correction",size=28,align=2)) resultS2H= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result2,"autowhite, manual levels correction",\ size=28,align=2).histogram(mode="levels")) resultS3H= stackhorizontal(subtitle(source2,"original",size=32,align=2),\ subtitle(result3,"autolevels + manual color correction",\ size=28,align=2).histogram(mode="levels")) resultS4H= stackhorizontal(subtitle(source2,"original",size=32,align=2),\ subtitle(result4,"manual colors and levels correction",\ size=28,align=2).histogram(mode="levels")) result6= stackhorizontal(subtitle(result5,"baseclip for stabiliser -only the B/W clip is used",size=32,align=2)\ ,subtitle(stab4,"test stabiliser: dx=horizontal, dy=vertical",size=32,align=5)) Eval(result) |
8th February 2009, 17:09 | #69 | Link |
For that, you need to install the amended avisynth.dll (see the MT docs).
However, a quick fix for now would be just to remove the SetMTMode line. The script should then work, though it may be slower. |
8th February 2009, 17:34 | #70 | Link | |
so please please show me a complete script rather than telling me what to fix cause one thing is fixed then other is not , it will be so much easy if you show the full script. thanks. |
8th February 2009, 18:08 | #72 | Link | |
Can videoFred (or anyone else who has actually run his script) help out here with a list of plugin versions required? |
8th February 2009, 19:15 | #74 | Link |
AviSynth plugger
kopmjj,
1. please use CODE tag for scripts (like videofred did). 2. please learn avisynth scripting (start with simple scripts), read docs and this forum. 3. It is complex script, and it may have many variants and modifications.
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
8th February 2009, 19:24 | #75 | Link | |
i know it may have variants and modifications i should be able to deal with that, i just want a working script that someone has managed to do. if anyone has worked on a video can you show me your script so i can understand. thats all im asking please thanks. |
8th February 2009, 20:11 | #76 | Link |
just noobing around
I would love me some of this avisynth power for some of my dv footage. I tried some other scripts that I found, but there are too simple, stuff that I could do with Virtualdub or Avidemux.
9th February 2009, 07:36 | #79 | Link | |
Location: Terneuzen, Zeeland, the Netherlands, Europe, Earth, Milky Way,Universe
Thanks a lot for all the good support here while I was not here. @Everybody: This is not a simple beginners script. Gavino was right: I have reorganized it for posting here and I have made some "\" mistakes.. sorry for that. I will make a list from the required plugins as soon as possible. Fred.
About 8mm film: http://www.super-8.be Film Transfer Tutorial and example clips: https://www.youtube.com/watch?v=W4QBsWXKuV8 More Example clips: http://www.vimeo.com/user678523/videos/sort:newest |
9th February 2009, 07:45 | #80 | Link | |
The rest is just a matter of having the right plugin versions. Fred.
