Old 28th June 2017, 23:51   #1701  |  Link
iSeries
No speed effect, but surely less writes to the hard drive is better?
Also, more of a general x264 question. Its been a while since I've done any encoding but I remember from some time ago that when using ffms2 having to explicitly state --fps and --force-cfr in the command line as ffms2 fairly often got it wrong. Is this still the case?
iSeries is offline   Reply With Quote
Old 29th June 2017, 01:43   #1702  |  Link
GMJCZP
GMJCZP's Avatar
When I make a simple update with the setup, in the "About..." option does not show version 2.83, still showing 2.81.
By law and justice!
Flea Market
GMJCZP is offline   Reply With Quote
Old 29th June 2017, 15:47   #1703  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
I don't think you really need to worry about this.
On the other hand, it's quite easy to just set the output filename to NUL in the first pass, so I will probably add an option for this.
Old 29th June 2017, 15:52   #1704  |  Link
LoRd_MuldeR
Software Developer
Not quite sure what you mean with "update with the setup". But if it shows "v2.81" in the about screen, then you are running v2.81, not v2.83.
The setup program can "overwrite" (upgrade) an existing installation, so you do not need to uninstall to old version first. Anyway, the setup program will install whatever version is contained in the particular setup package that you are installing. Old setup package will install old version. You need to download the latest setup program from the project site and install that! Or just let the auto-update function upgrade your existing "v2.81" installation to the latest...
(I just tested that v2.81 will upgrade to v2.83 flawlessly and couldn't notice any issues)
Old 29th June 2017, 19:39   #1705  |  Link
iSeries
Thank you! :-)
Old 30th June 2017, 04:40   #1706  |  Link
GMJCZP
GMJCZP's Avatar
Fixed issue, I was using an old setup, thank you.
By law and justice!
Flea Market
Old 3rd July 2017, 03:21   #1707  |  Link
Shb
Firstly, thanks for all the work! I'm using this pretty much daily and it's been great.
Recently, I've been having a slight issue with hitting the deadlock timer. I've been using the --no-deadlock-detection switch to avoid the problem for the most part, however I'm somewhat confused as to why both creating the avs2yuv and x264 process take a long time. Before the latest version, these would start almost immediately, but on the current version (I think I updated in-app and it said to build #1114), each of these processes takes well over the 5 minutes before deadlocking kicks in. I've even tried manually indexing the files but the same outcome occurs.
Is there anything I can provide you with to assist?
Edit: Seems it was source-specific. I tried a different source and it had none of the same issues.
Shb is offline   Reply With Quote
Old 5th July 2017, 20:33   #1708  |  Link
LoRd_MuldeR
Software Developer
Well, the included avs2yuv hasn't changed for ages. x264 has been updated recently, but there should be no change effecting "startup" time.
If avs2yuv or x264 takes a long time to start or even triggers "deadlock" detection, then it almost certainly means that Avisynth (or more precisely: your Avisynth script) takes a very long time to initialize.
A typical cause for this is FFMS2 (or whatever source filter you use) taking a long time to index the source. But there could be other reasons, e.g. your script is just painfully slow overall.
Old 6th July 2017, 08:51   #1709  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Personally, I check my script in AvsPmod before encoding it with Simple X264 Launcher. With AvsPmod, I have a visual feedback, and if something goes wrong, I can see the avisynth error message. And the indexing of the source is already finished when I decide to encode. With that method, I have no startup problem any more.
r0lZ
Old 6th July 2017, 14:09   #1710  |  Link
Shb
That's what I have been doing, and I didn't have any issues with any source up until the one I posted about. Even after moving on to different sources I am back to normal again, I'm just not sure why it struggled. There was nothing unusual about the script, just resizing and a slight bit of cropping. Along the lines of:
FFVideoSource("..\source.mkv")
Crop(0, 20, 0, -20)
Spline36ResizeMod(1024, 552)
No deinterlacing or anything intensive at all. It seemed as though the file was being reindexed every single time no matter if the index file already existed.
Old 6th July 2017, 19:04   #1711  |  Link
LoRd_MuldeR
Software Developer
Crop(0, 20, 0, -20)
Try setting the "cachefile" option explicitly in your FFVideoSource() call.
Old 15th July 2017, 21:39   #1712  |  Link
LoRd_MuldeR
Software Developer
Simple x264 Launcher v2.84
https://github.com/lordmulder/Simple...ases/tag/v2.84
Version 2.84 [2017-07-12]
* Updated x264 to revision 2851
* Updated x265 to version 2.5+2
Old 17th September 2017, 17:34   #1713  |  Link
tormento
Acid fr0g
tormento's Avatar
I read, from website, I can use portable AviSynth:
InstallPath\
├─ x264_launcher_portable.exe
└─ extra\
   └─ Avisynth\
      ├─ x86\
      │  ├─ avisynth.dll  <32-Bit>
      │  ├─ devil.dll     <32-Bit>
      │  └─ etc…
      └─ x64\
         ├─ avisynth.dll  <64-Bit>
         ├─ devil.dll     <64-Bit>
         └─ etc…
Imaging I can put there AviSynth+, how can I place there plugins too, with the same structure of AviSynth+, forgetting forever the PITA of installing AviSynth?
@turment on Telegram
Old 17th September 2017, 19:08   #1714  |  Link
LoRd_MuldeR
Software Developer
InstallPath\
└─ extra\
   └─ Avisynth\
      ├─ x86\
      │  └─ etc…
      └─ x64\
         └─ etc…
My experience with Avisynth+ is limited.
When you install "normal" Avisynth, it will offer you the "Standalone, Unpack Files only" install option. That will extract the required files. For "portable" use, those files need to be placed exactly as described in the README file.
You can try doing the same with Avisynth+. If case that there is no "Standalone, Unpack Files only" option in the Avisynth+ installer, you will need to extract the required files in a different way...
Old 7th October 2017, 10:33   #1715  |  Link
LoRd_MuldeR
Software Developer
Simple x264 Launcher v2.85
https://github.com/lordmulder/Simple...ases/tag/v2.85
Version 2.85 [2017-10-04]
* Updated x265 to version 2.5+22
* Updated build environment to Visual Studio 2017 with Update-3
