Old 12th October 2017, 16:19   #14381  |  Link
madshi
Can you do anything with EAC3 tracks?
What do you mean? E-AC3 tracks should be fully supported.
Old 12th October 2017, 20:15   #14382  |  Link
tebasuna51
tebasuna51's Avatar
Not all:
http://bugs.madshi.net/view.php?id=450
https://forum.doom9.org/showthread.p...92#post1802092 and next
Old 12th October 2017, 23:46   #14383  |  Link
LigH
LigH's Avatar
Blu-ray EAC3 (as core AC3 extension only) is still a different case, I believe... ffmpeg can't handle it yet, either:
Dependent substream decoding is not implemented.
New German Gleitz board
Old 13th October 2017, 11:07   #14384  |  Link
tebasuna51
tebasuna51's Avatar
To sumarize the problem here.
I found two kind of EAC3 streams detected by eac3to without core (2 English) or with core (3 Spanish) like is show here (sample):
eac3to Eac30.m2ts
M2TS, 1 video track, 2 audio tracks, 0:01:23, 24p /1.001
1: h264/AVC, 1080p24 /1.001 (16:9)
2: E-AC3, English, 5.1 channels, 640kbps, 48kHz
3: E-AC3, Spanish, 7.1 channels, 768kbps, 48kHz, dialnorm: -27dB
   (core: AC3, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB)
Over this m2ts we can do, adding or not the -core, some times [ignored]:
eac3to Eac30.m2ts 2: output.eac3 [-core] -> OK eac3 output
eac3to Eac30.m2ts 2: output.ac3 [-core] -> OK recoded to ac3
All ok over track 2
eac3to Eac30.m2ts 3: output.eac3 -> ERROR
eac3to Eac30.m2ts 3: output.eac3 -core -> OK AC3.eac3 output
eac3to Eac30.m2ts 3: output.ac3 -> ERROR
eac3to Eac30.m2ts 3: output.ac3 -core -> useless, recoded core
Over track 3, can't extract or recode (maybe because: Dependent substream decoding is not implemented) the full eac3.
Can extract a perfect AC3 core (when demand eac3 extensión) or recode the core (useless)
Now the same m2ts converted to mkv with MkvToolNix is show by eac3to like:
eac3to Eac30.mkv
MKV, 1 video track, 2 audio tracks, 0:01:23, 24p /1.001
1: h264/AVC, English, 1080p24 /1.001 (16:9)
2: EAC3, English, 5.1 channels, 48kHz
3: EAC3, Spanish, 5.1 channels, 48kHz
Bitstream parsing for tracks 2 and 3 failed.  <WARNING>
Demuxing these tracks may still produce correct results - or not.  <WARNING>
And now:
eac3to Eac30.mkv 2: output.eac3 [-core] -> OK eac3 output
eac3to Eac30.mkv 2: output.ac3 [-core] -> ERROR
eac3to Eac30.mkv 3: output.eac3 [-core] -> OK eac3 output
eac3to Eac30.mkv 3: output.ac3 [-core] -> ERROR
Can extract both tracks but never decode/recode
EDIT:
Decoding track 3 with ffmpeg show always (from m2ts or mkv) the message: Dependent substream decoding is not implemented.
Then MkvToolNix don't extract the AC3 core, preserve the substream to convert 5.1 -> 7.1 even when eac3to show only 5.1 on mkv.
Remuxed the mkv to m2ts with tsMuxeR the track 3 is showed by eac3to like original Eac30.m2ts
Without free tools to decode EAC3 7.1 (always decode the core) the recommended option, by now, is extract the core from m2ts
and rename to .ac3
Old 13th October 2017, 11:12   #14385  |  Link
mini-moose
thanks Madshi for the great tool!
I think there are a few things that may/could use some updating:
1) E-AC3 audios with embedded Core (mentioned before)
2) libFLAC (very old version used, maybe worth updating)
3) libDcaDec (I think it's part of ffmpeg now?)
mini-moose is offline   Reply With Quote
Old 13th October 2017, 12:30   #14386  |  Link
SeeMoreDigital
Life looks better in UHD
SeeMoreDigital's Avatar
Hi @tebasuna51,
It would seem that most if not all our current tools are unable to correctly identify Dolby Digital Plus audio streams
Have you noticed that when you run your 'Eac30.m2ts' sample file through TSmuxerGUI that it reports the first audio track as having 17 channels. And when you run the same file through MediaInfo it's unable to detect the AC3 cores at all. Or identify that the second audio track has been encoded with 7.1 channels.
By contrast, my Oppo UDP-203 is able to identify the first audio track as being a 5.1 channel Dolby Digital Plus stream and second audio track as being a 7.1 channel Dolby Digital Plus stream. But neither of my LG 'smart' TV's (which support Dolby Digital Plus) are able to detect either of the audio streams at all (ie: total silence). But my Panasonic 'smart' TV can detect the first audio stream.
Cheers
Old 13th October 2017, 21:29   #14387  |  Link
zeropc
madshi, can you please bring back the feature to show the applied delay/ amount x delay could not be fixed in the log?
this was actually quite helpful when syncing/editing audio.
thanks
zeropc is offline   Reply With Quote
Old 13th October 2017, 22:57   #14388  |  Link
Snowknight26
It's still there.
Snowknight26 is offline   Reply With Quote
Old 14th October 2017, 09:21   #14389  |  Link
zeropc
Originally Posted by Snowknight26 View Post
It's still there.
nope
eac3to v3.32
command line: "C:\Users\zeropc\Desktop\eac3to 3.32\eac3to.exe" "H:\xmen atmos.mkv" 2: "H:\x\xa1.thd" +18ms
MKV, 1 video track, 3 audio tracks, 29 subtitle tracks, 2:23:58, 24p /1.001
1: h265/HEVC, 3840x1600 24p /1.001 (12:5), 10 bits
2: TrueHD (Atmos), English, 7.1 channels, 48kHz
3: AC3, English, 5.1 channels, 640kbps, 48kHz
4: AAC, English, 2.0 channels, 48kHz, 9ms
   "Commentary with director Bryan Singer and writer Simon Kinberg"
5: Subtitle (PGS), English, "Forced"
6: Subtitle (PGS), English, "SDH"
7: Subtitle (PGS), Spanish
8: Subtitle (PGS), French
9: Subtitle (PGS), French
10: Subtitle (PGS), Spanish
11: Subtitle (PGS), Danish
12: Subtitle (PGS), Dutch
13: Subtitle (PGS), Finnish
14: Subtitle (PGS), German
15: Subtitle (PGS), Italian
16: Subtitle (PGS), Norwegian
17: Subtitle (PGS), Swedish
18: Subtitle (PGS), Chinese
19: Subtitle (PGS), Chinese
20: Subtitle (PGS), Japanese
21: Subtitle (PGS), English, "Commentary"
22: Subtitle (PGS), Spanish, "Commentary"
23: Subtitle (PGS), French, "Commentary"
24: Subtitle (PGS), French, "Commentary"
25: Subtitle (PGS), Spanish, "Commentary"
26: Subtitle (PGS), Danish, "Commentary"
27: Subtitle (PGS), Dutch, "Commentary"
28: Subtitle (PGS), Finnish, "Commentary"
29: Subtitle (PGS), German, "Commentary"
30: Subtitle (PGS), Italian, "Commentary"
31: Subtitle (PGS), Japanese, "Commentary"
32: Subtitle (PGS), Norwegian, "Commentary"
33: Subtitle (PGS), Swedish, "Commentary"
[a02] Extracting audio track number 2...
[a02] Creating file "H:\x\xa1.thd"...
Video track 1 contains 207088 frames.
eac3to processing took 16 minutes, 6 seconds.
Done.
Old 14th October 2017, 13:28   #14390  |  Link
hubblec4
Matroska Dev-Helper
Feature request
Hi madshi
Is it possible that eac3to scan the sup tracks and find forced sup's before I demux the sup track.
While eac3to scans the mpls (all tracks are listed) and for the sup tracks, you could add an info "forced sup's detected".
M2TS, 1 video track, 3 audio tracks, 10 subtitle tracks, 0:43:05, 24p /1.001
1: Chapters, 8 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 5.1 channels, 16 bits, 48kHz
   (core: DTS, 5.1 channels, 1509kbps, 48kHz)
4: DTS Master Audio, German, 5.1 channels, 16 bits, 48kHz
5: DTS Master Audio, Spanish, 5.1 channels, 16 bits, 48kHz
7: Subtitle (PGS), English
8: Subtitle (PGS), Danish
9: Subtitle (PGS), Finnish
10: Subtitle (PGS), German, forced detected
11: Subtitle (PGS), Hindi
12: Subtitle (PGS), Norwegian
13: Subtitle (PGS), Spanish
14: Subtitle (PGS), Swedish
15: Subtitle (PGS), Turkish
Really great would be if you could add a new "virtual" forced-sup track to the track list. Demux the forced-sup brings only the forced sups.
16: Subtitle (PGS), German, forced
LG,
hubble
hubblec4 is offline   Reply With Quote
Old 14th October 2017, 16:11   #14391  |  Link
tebasuna51
tebasuna51's Avatar
You can replace libFLAC.dll with libFLAC_dynamic.dll (renamed) from
http://www.rarewares.org/files/lossl...170314-icl.zip
Yes, that was requested already.
Yep.
Just by curiosity I check some tsMuxeR versions and the first audio track is:
tsMuxeR 1.8.8: track not recognized
tsMuxeR 2.6.9: channels 94
tsMuxeR 2.6.11 or 12: channels 91
What is your version than show 17 channels?.
I don't see differences between log in 3.31 and 3.32 with this command.
BTW is know than eac3to can't delay thd tracks.
Only decoding that delay can be applied.
The first scan must be quick, a depth scan becomes slow.
When you demux these tracks the log show the forced captions found.
For me is enough, there are other tools to manage sup's.
Old 14th October 2017, 17:38   #14392  |  Link
SeeMoreDigital
Hi @tebasuna51,
I'm using tsMuxeR GUI 2.6.12. But I've just noticed that if you drop the same 'Eac30.m2ts' file into the application, then remove it, and re-add it, the application reports different information...
Cheers (oh bugger... I've run out of beer )
Old 14th October 2017, 18:44   #14393  |  Link
Q-the-STORM
eac3to Eac30.mkv
And now:
btw decode/recode should work after you demuxed eac3 and renamed to ac3....
So:
then
rename to output.ac3
then
eac3to output.ac3 output2.wav -whatever
At least it works with my files that have eac3 tracks and no core. I always need to demux and rename, then decoding and recoding work.
That seems like a eac3to bug to me.
Old 14th October 2017, 23:56   #14394  |  Link
hubblec4
Matroska Dev-Helper
I know but all other tools can't read sup's from the m2ts file. You have to extract them first.
I hope madshi has also the Bluray-specs and can do what makemkv does. There is not long scan to identify the forced sup's.
Old 15th October 2017, 06:50   #14395  |  Link
Megalith
Anyone know of a GUI that is still regularly updated? It seems like most of them have been abandoned.
Megalith is offline   Reply With Quote
Old 15th October 2017, 10:03   #14396  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by Q-the-STORM View Post
So:
then
then
Yep with track 2, with track 3 don't work.
And you don't need rename, eac3to identify the stream by the header not by extension, work fine also:
eac3to Eac30.mkv 2: output2.eac3
then
eac3to output2.eac3 output2.wav
With track 3:
eac3to Eac30.mkv 3: output3.eac3
then
eac3to output3.eac3 output3.wav -->
E-AC3, 7.1 channels, 0:01:23, 768kbps, 48kHz, dialnorm: -27dB
(core: AC3, 5.1 channels, 0:01:23, 448kbps, 48kHz, dialnorm: -27dB)
Removing AC3 dialog normalization...
Extracting E-AC3 core...
Decoding with libav/ffmpeg...
[libav] frame CRC mismatch  <WARNING>
[libav] get_buffer() failed  <WARNING>
The libav decoder reported error -22 while decoding.  <ERROR>
Aborted at file position 262144.  <ERROR>
You need:
ffmpeg -drc_scale 0 -i output3.eac3 -acodec pcm_s24le output3.wav
[eac3 @ 00000000006bf5e0] Dependent substream decoding is not implemented.
Update your FFmpeg version to the newest one from Git.
If the problem still occurs, it means that your file has a feature which has not been implemented.
Or directly from the mkv:
ffmpeg -drc_scale 0 -i Eac30.mkv -map 0:2 -acodec pcm_s24le output3.wav
with the same WARNING
Old 15th October 2017, 10:15   #14397  |  Link
tebasuna51
tebasuna51's Avatar
HdBrStreamExtractor is updated in MeGUI -> Tools -> HD Streams Extractor
MeGUI v2771 [HD Streams Extractor] added support for HEVC video tracks (requires eac3to 3.32+)
[Muxer] added support for the h265 file extension
Or UsEac3to v1.2.7
All other GUI's are abandoned.
Old 15th October 2017, 10:40   #14398  |  Link
mini-moose
[url]http://www.rarewares.org/files/lossless/flac_dll-1.3.2-git-2
Thanks. I know I can do that but be nice if it's updated in eac3to package too. Also, wasn't there some bug 1.3.2 and 1.3.2-1 was released? I don't see it in the flac website but it's on megui.
Old 15th October 2017, 13:12   #14399  |  Link
stax76
staxrip & mpv.net
Or UsEac3to v1.2.7
Last major feature megui implemented is x264 released 2004, it lacks anything major since then:
High DPI
VapourSynth
x265 full implementation
AV1
NVEnc
QSVEnc
I have a dream by Martin Luther King
one hundred years later...
We can never be satisfied...
With this faith...
Let freedom ring...
stax76 is online now   Reply With Quote
Old 15th October 2017, 14:44   #14400  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
I would like to suggest small cosmetic addition to eac3to. It would be cool if extension .265 was also supported during demuxing. Currently only .h265 is recognized.
eac3to
