Old 3rd October 2007, 16:33   #1001  |  Link
Thunderbolt8
edited
Old 3rd October 2007, 16:34   #1002  |  Link
Thunderbolt8
I've spent too much time on eac3to lately.
nah, not too much time, the final changes made it almost perfect
Old 3rd October 2007, 17:54   #1003  |  Link
madshi
Originally Posted by honai View Post
By the way, do you have plans to implement STDIN streaming for the source?
No plans as of yet. What would that be good for?
Old 3rd October 2007, 18:05   #1004  |  Link
madshi
eac3to v1.22 released
http://madshi.net/eac3to.zip
* 6.1 -> 7.1 channel doubling was sometimes incorrectly skipped
* OS speaker settings now don't have to be 7.1, anymore
* added detection of 5.1 output when 6.1 was expected
* DTS and DTS-ES files are now forcefully patched to 24 bit by eac3to (workaround for Sonic decoder)
* Sonic Audio Decoder is now always used by default for DTS decoding
See also updated first post in this thread.
Old 3rd October 2007, 18:09   #1005  |  Link
madshi
I've noticed some strange things with DTS 6.1 tracks:
The Nero decoder always outputs 5.1, but the back channel seems to be mixed into the surround channels!
The Sonic decoder most of the time gives out proper 6.1. However, with I've one sample where it only outputs 5.1, although the track is definitely 6.1 Discrete. Very strange. With this one special track I can see the Nero has the back channel mixed into the surrounds again. With Sonic I only get 5.1 and the back channel is totally missing. Fortunately for 4 other sample Discrete tracks Sonic gives out proper 6.1.
Old 3rd October 2007, 18:13   #1006  |  Link
nautilus7
nautilus7's Avatar
Do i have to set OS speakers to 5.1 to get a 5.1 output, or stereo is just fine?
nautilus7 is offline   Reply With Quote
Old 3rd October 2007, 18:15   #1007  |  Link
madshi
Here's a little goodie for all ya Windows FLAC users:
http://forum.doom9.org/showthread.php?t=130498
Old 3rd October 2007, 18:15   #1008  |  Link
madshi
Originally Posted by nautilus7 View Post
Do i have to set OS spekers to 5.1 to get a 5.1 output, or stereo is just fine?
Stereo should be fine. The OS speaker settings shouldn't matter at all, anymore.
Old 3rd October 2007, 18:19   #1009  |  Link
honai
Posts: n/a
I'm writing a bridge tool between your tool and an EVOB demuxer. That way I could just invoke your tool with demuxed audio streams without storing them as separate files beforehand.
Old 3rd October 2007, 18:40   #1010  |  Link
madshi
I see. The problem is that eac3to is using DirectShow filters and they want to load a file. So even if I added STDIN support, I'd have to store the files on harddisk, anyway...
Old 3rd October 2007, 19:04   #1011  |  Link
honai
Posts: n/a
For all audio stream types?
Old 3rd October 2007, 19:22   #1012  |  Link
nautilus7
nautilus7's Avatar
I 've just decode a 5.1 dts having set OS speaker setting to headphones (stereo). It worked fine! Thanks!
Old 3rd October 2007, 21:45   #1013  |  Link
madshi
No, but for all compressed audio formats. Basically both decoding and encoding only works with files on harddisk. Things eac3to does itself (channel mapping, raw to wav(s) conversion, dts/ac3 core extraction, dialnorm removal, etc) could theoretically be done without hard disk. But the question is whether this all makes sense if only some parts of eac3to would get along without real files.
Old 4th October 2007, 04:27   #1014  |  Link
superx
E-AC3, 5.1 channels, 1:00:13, 640kbit/s, 48khz, dialnorm: -27dB
Remove Dialog Normalization information. Please wait...
Decoding eac3 file to raw. Please wait...
Getting "Nero File Source / Splitter" and "DTS/AC3/DD+ Source" instances failed.
This is the error I get can anyone help me with it.
Thanks
superx is offline   Reply With Quote
Old 4th October 2007, 08:04   #1015  |  Link
hristoff2
Thanks
Install Nero 7.x.x.x properly & register the HDDVD/Blu-Ray Plugin, or get the Sonic Decoders (beware, DRC applied on eac3 tracks) & ac3dts source (the new one, with eac3 support)
-> http://uploaded.to/?id=y73jnw ('dtsac3eac3' source)
hristoff2 is offline   Reply With Quote
Old 4th October 2007, 10:22   #1016  |  Link
Beastie Boy
Beastie Boy's Avatar
Is it still possible to buy Nero 7? I see only ver 8 on the web site.
Beastie Boy is offline   Reply With Quote
Old 4th October 2007, 11:49   #1017  |  Link
superx
how do I register the hdvd/blu-ray plugin, where do I get this from.
I just purchased nero 8 will that screw anything up
Old 4th October 2007, 13:37   #1018  |  Link
The_Keymaker
@ALL
I am still working on my WiFi remote control system. But will still try and support EAC3toGUI.
From what I can determine, -down6 and +/-100ms are the only options my GUI does NOT currently support. I will try and update EAC3toGUI with the new parameters this weekend.
Before I can update the program, I need someone to explain to me how to implement the +/-100ms command line parameter, i.e., is it +100 for advance and -100 for delay? and can it be any number from 0 to 100ms or is it fixed at 100ms?
Regards,
The_Keymaker
The_Keymaker is offline   Reply With Quote
Old 4th October 2007, 14:51   #1019  |  Link
madshi
You need to buy the plugin, too, in case you haven't yet. It's not part of the normal Nero package. Once you bought it you'll get an extra serial number for the plugin which you can then feed to the Nero Product Manager (or whatever it was called).
eac3to doesn't work with Nero 8. You need to install Nero 7 if you want to do TrueHD and E-AC3 decoding with eac3to.
Old 4th October 2007, 15:00   #1020  |  Link
TheSof
Can't imagine that there'd be a difference between v1.17 and v1.18. Except if you fed the EVO file into v1.17 instead of the demuxed file? Please check if the 2:47 FLAC stays in sync throughout the movie (after you applied the eventually necessary static delay). Maybe the 2:47 has some extra seconds of silence at the end or beginning of the movie? Don't know...
I'm using it on the demuxed thd.T he flac has about 10 mins extra runtime. The FLAC does not stay in sync, it will keep droping out and then coming back. Its very difficult to tell how far out of sync it is at the end but about 10 mins seems right. With 1.17 it is fine, albeit with the dial norm and thus 24bit.
Is anyone having success with titles such as Superman Returns and V for Vendetta?
TheSof is offline   Reply With Quote
eac3to
