Old 19th May 2007, 12:08   #41  |  Link
mikeyakame
lookin for my sanity
Location: it all depends on the day and which country comes to mind
if the true-hd is outputting in 24bit..try changing the settings for your sound card to 16bit output depth...
im trying it now...ill let you know in a couple of minutes whether it works
edit: nope makes no difference, nero doesn't have a setting for outputs...not sure...ill play with a true-hd track later on
mikeyakame is offline   Reply With Quote
Old 19th May 2007, 12:42   #42  |  Link
zgx
Did you have a chance to check out the content of the decoding? Can you confirm that the least significant 8 bits are not zero? It's really too bad cause if true it means that we don't have a 1:1 lossless decoding yet...
No have not gotten around to buy the filters yet so cannot try it myself at the moment. But if you take the original 24 bit PCM file that you got from the decode and then open it in a HEX editor you should be able to figure out if one third of the bits contains zeros (8bit, 8bit, 8bit, 8bit, 8bit, 8bit, 8bit, 8bit...). In an hex editor "00" probably represents 8bit with just zeros.
zgx is offline   Reply With Quote
Old 19th May 2007, 17:55   #43  |  Link
Austin Forgotten
Hi there,
I am very curious about the TrueHD format, as I have spent a considerable amount of time looking at MLP. I do not own any HD equipment to rip HDDVD or Blueray. I have a few questions and I sure would like to get my hands on a demo/test file to have a look. For one, what is the file extension used for TrueHD format? Oh, I suppose I should have asked this 1st.. Has anyone been able to demux TrueHD to a file yet? Anyway if someone could provide a link to a test file [doesn't have to be to large :-) ]. Thanks.
-AF
Austin Forgotten is offline   Reply With Quote
Old 19th May 2007, 19:02   #44  |  Link
zgx
Originally Posted by Austin Forgotten View Post
Hi there,
-AF
There are a few programs able to demux TrueHD streams out of a HD DVD. The most common is probably EVOdemux available at http://pel.hu/down
I think different programs use different extensions for TrueHD.
At the moment the major problem is that the only way to play TrueHD or decode it is from within EVO files (using PowerDVD for example or now eac3to).
Old 19th May 2007, 19:14   #45  |  Link
zgx
Check your mailbox in a few minutes.
Old 20th May 2007, 00:46   #46  |  Link
Rectal Prolapse
madshi: I just looked at a raw PCM dump and I see the same thing - the 3rd byte of each sample is not always zero! What is going on here...?
Rectal Prolapse is offline   Reply With Quote
Old 20th May 2007, 05:11   #47  |  Link
mikeyakame
this is the info for The Matrix TrueHD track.
Audio attribute :
Audio application mode : surround
Audio format : MLP
Sampling frequency : 48000
Sampling quantization : 24
Number of audio channels : 6
Number of audio streams : 8
Bitrate: 2544 Kbps
I get both 24-bit outputs with this track on Nero Showtime & PowerDVD 7.3.2911
Old 20th May 2007, 06:59   #48  |  Link
pasta03
pasta03's Avatar
Someone can give me direct link to Nero Audio Decoder 2 not to all nero recording only for decoder
pasta03 is offline   Reply With Quote
Old 20th May 2007, 07:12   #49  |  Link
Revgen
Nero packages the recorder and every software it makes together without any separate packages. You cannot get it any other way. At least not legally.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline   Reply With Quote
Old 20th May 2007, 07:17   #50  |  Link
Revgen
BTW do Nero's decoders work in Windows XP.
Moe: Why?
Old 20th May 2007, 13:18   #51  |  Link
zgx
Audio attribute :
Audio format : MLP
Bitrate: 2544 Kbps
The Matrix TrueHD soundtrack is "1 682 946 322" bytes long. The movie is 136 minutes long. That gives it a bitrate of 1611 Kbps. That's about the same bitrate as a 6 channel 16/48 movie soundtrack compressed to FLAC.
Uncompressed 16 bit/48 kHz/6 channel PCM: 4500 Kbps
Uncompressed 24 bit/48 kHz/6 channel PCM: 6750 Kbps
It's hard to say but I do not believe it's possible to losslessly compress a 24/48 soundtrack from an action movie like The Matrix to 1611 Kbps and the way I see it they must have used a 16/48 source.
People here say that the least significant 8 bits are not zero as they should be. Is it possible that even if the TrueHD track is stored with the least significant 8 bits as zeros that the Nero Audio Decoder reads the 16 bit most significant bits and upsample them to 24 bit?
Old 20th May 2007, 19:20   #52  |  Link
madshi
Yes, I'm running everything in XP.
Old 20th May 2007, 19:23   #53  |  Link
madshi
Audio attribute :
Audio format : MLP
Bitrate: 2544 Kbps
Where do you have this information from? Do you have a software which outputs this kind of information? 8 audio streams for MLP is extremely strange because to my best knowledge MLP only supports 6 channels!
FWIW, highdefdigest claims Matrix TrueHD to be 48/16:
http://hddvd.highdefdigest.com/matrix_umc.html
Old 20th May 2007, 20:05   #54  |  Link
zgx
I think the Matrix HDDVD actually has 8 different audio tracks. Look at my reply a few posts up for the information on The Matrix.
Old 21st May 2007, 09:44   #55  |  Link
Neo Fagin
Mmmmmmmmangoscam!
Neo Fagin's Avatar
Another unusual error, this time with TrueHD (Matrix Reloaded)
Muxing evo's first audio track to raw. Please wait...
Converting the raw file to wav. Please wait...
sox.exe sox: Channels value '0' is not a positive integer
"sox" reported error code "1". A valid *.raw file was created sucessfully, though.
Neo Fagin is offline   Reply With Quote
Old 21st May 2007, 09:50   #56  |  Link
madshi
Ah, I think that's a bug I introduced when adding support for mono E-AC3 files. I'll upload a fixed build soon.
Old 21st May 2007, 10:02   #57  |  Link
Neo Fagin
Mmmmmmmmangoscam!
Neo Fagin's Avatar
Just out of curiosity, what sox/aften commandlines does eac3to use during the conversion process?
Old 21st May 2007, 10:05   #58  |  Link
madshi
Depends on the audio tracks, of course...
Here's version 1.7:
http://madshi.net/eac3to.zip
There's a new option "-8". eac3to can currently not automatically find out how many channels the TrueHD track has, so it assumes 6 channels. If you know it to be 8 channels, use the "-8" option. I'm not sure how many channels Matrix has. Also I'm not sure if Nero's decoder is even able to output more than 5.1. Probably not. So the default (6 channels) is probably the right choice for Matrix, too.
Old 21st May 2007, 10:23   #59  |  Link
Neo Fagin
Mmmmmmmmangoscam!
Neo Fagin's Avatar
Nero vision reports Matrix Reloaded to be 7.1 (and says it's unsupported by Nero at this time) but it does play audio despite the error, though I don't know if it's playing 5.1, stereo, mono or what. That may be the cause of the numerous problems the track is causing.
Old 21st May 2007, 10:29   #60  |  Link
madshi
Well, the sox complaint you reported was a clear bug in eac3to. So you should retry with version 1.7. Maybe it works. But I guess decoding will probably be limited to 5.1 channels.
eac3to
