17th February 2011, 07:19 | #401 | Link | |
Location: Terneuzen, Zeeland, the Netherlands, Europe, Earth, Milky Way,Universe
http://forum.doom9.org/showthread.php?t=128585&page=4 Fred.
About 8mm film: http://www.super-8.be Film Transfer Tutorial and example clips: https://www.youtube.com/watch?v=W4QBsWXKuV8 More Example clips: http://www.vimeo.com/user678523/videos/sort:newest |
17th February 2011, 09:18 | #402 | Link |
Sorry, my english was (is) not very clear... ;-)
I'll do as you say. Thank you for the link. One thing more: In the first times, I intended to use the script, only to cure a few Super 8 footages (those which were a little too unstable and/or "dirty"). But I quickly saw the obvious improvement, and now ALL the family films I transfer to burn DVD, even the best ones, are cleaned and stabilized, trying to set the corrections "just as I have to do" for each reel, sometimes each take, for as John said "no two reels are the same, and each is going to require custom tweaking". Last edited by Gargamel; 17th February 2011 at 10:10. |
5th March 2011, 02:17 | #403 | Link |
I need help. I would like to improve the quality of my Super 8 films. I followed the "film restoration script by videoFred". Intalled Avisynth
and other programs for it. Changed only two parameters in -> play speed=20 and numerator=30 because I record my films in NTSC with 1/60, I can run my .avi file in VirtualDub. Unfortunatelly when I want to run the restoration script I got the following: Avisynth open failure: I don't know what "stab_reference" means. MT command commented out with # because my CPU is AMD Athlon 64 Processor 3500+ 2.2GHZ Please advice me how can I run this Avisynth script without error. BTW is it any chache to improve on this film: http://www.youtube.com/svaradi#p/a/u/1/w740GzJYO1c ? Thanks. |
5th March 2011, 03:58 | #404 | Link | |
However, if you want to use the script, you won't get good results with the film you linked to. I downloaded your video from YouTube, and it looks like you used a 100 fps camera to capture the film from your projector. There are many, many duplicate frames where no motion occurs. These must be eliminated using an inverse telecine script (IVTC using TFM and TDecimate). In addition, even after you eliminate the duplicates, you still have some ghost frames that result from using the video camera to capture film from a projector. You may still be able to get results from Fred's script, but these ghost frames will probably reduce the ability to get good sharpness, and may fool the motion estimation algorithms. |
6th March 2011, 01:20 | #405 | Link | |
Thanks for the advice. |
6th March 2011, 01:41 | #406 | Link |
I forget to explain how I captured this film. I used my videocamera setting exposure 1/60 sec. in NTSC system. Projector set on 20fsp. After I edit this film in iMovie: slow it down 15%,flipped, crop, rotate. Maybe the ghost frames came from the slowing down the film?? BTW in VirtualDub I see 7127 frames playing time 3:57:804 this is 29.97 fps as standard NTSC. Should I change something in this workflow order??
What program determine: "used a 100 fps camera" ? Thanks. |
6th March 2011, 22:38 | #407 | Link |
The 100 fps is what GSpot reported on the MP4 that I downloaded from YouTube. From what you say, you just used a normal video camera, so I don't know how the file got set to 100 fps. That actually isn't important. What IS important is that there are a LOT of duplicated fields and frames. If you want to use Videofred's script, you have to remove these. The IVTC in VD isn't useful: you have to use the TIVTC.dll plugin for AVISynth and then use these two functions:
tfm(display=false) tdecimate(mode=0) However, for your video, you will have to use settings other than the defaults, because you have a very non-standard cadence. |
7th March 2011, 07:54 | #408 | Link | |
Fred.
7th March 2011, 21:04 | #409 | Link |
I have to command out this line because it contain MT_binarize also. I do not have multi core CPU Ok I break the line before MT_binarize. Now the next error: Avisynth open failure: I don't know what "result5" means
Is it possible to run this script with single core CPU computer? How? Thanks. |
9th March 2011, 01:27 | #413 | Link |
One more question: I see now in the VirtualDub right panel "Result3: autolevels, manual color correction" What happened with Result4 and Result5?? Maybe my script is working only partially?? Any idea how can I get more details from the "dark" exposure parts?
Thanks |
9th March 2011, 05:09 | #414 | Link | |
result="result3" will give you #RESULT3: AUTOLEVELS, MANUAL COLOR CORRECTIONS If you put an "S" in front of the number, you can see both the original and the corrected version side-by-side. Result5 is a special test clip. Don't use it. To get a brighter clip, use Results1 or Results3, since they both have Autolevels. You can then brighten the image further by setting the "gamma" parameter to something other than 1.0. If you use manual levels, you will probably find settings in the 1.05 - 1.20 are all you'll need. With Autolevels, you may need to use larger amounts. |
9th March 2011, 08:20 | #415 | Link | ||
@ Johnmeyer: thank you for the support John.
Fred.
About 8mm film: http://www.super-8.be Film Transfer Tutorial and example clips: https://www.youtube.com/watch?v=W4QBsWXKuV8 More Example clips: http://www.vimeo.com/user678523/videos/sort:newest Last edited by videoFred; 9th March 2011 at 08:24. |
10th March 2011, 01:02 | #416 | Link |
[QUOTE=videoFred;
I have added a manual, Logar. Please read it. Fred.[/QUOTE] Thank you for your support. I was so eager to start the project I forget to read BOTH files. I read only the installation help. Now I read Film_restoring_help.txt also. I still do not know how to save .avi file with the result ONLY panel in it? Do you know any similar program for Mac OS X?? My MacBook Pro is much faster than my windows computers. |
10th March 2011, 01:16 | #417 | Link | |
result="resultS1" gives you both the before and after video in the same frame; result="result1" gives you the "result ONLY panel," as you described it. |
10th March 2011, 04:55 | #418 | Link | |
What I was trying to say regarding the lens, I was merely talking about the lens on the camera and not the projector, thus wouldnt one remove the projector's lens so one can directly see the film plane, and use a macro lens on the camera itself to record the film that's projecting in the film plane. Not a macro lens on the projector which lead you to say that there isnt one to your knowlege, this is where I think the confusion was. And once again, would an Elmo 16-CL projector be a good choice for a project like this or similar to yours? Anyways I hope that clears some things up, and I hope to hear back. |
10th March 2011, 07:13 | #419 | Link |
There is no way to focus on the 16mm frame without using a lens in the projector. Just put a frame of 16mm film on a table and see if you can get it to fill the entire frame on your video camera. I don't think you can do it.
I don't know anything about the Elmo 16-CL, so I can't help you there. |
16th March 2011, 18:01 | #420 | Link |
Avi
Hello everyone, first time posting and a little scared to join the 8mm-grandfathers. It all started by Fred vimeo example's for me, and I was blowing away seeing the results by the script from Freddy!!
A few questions Wy are the output avi files so big? input file avi 3Gb and the output file from the script is around 30Gb. Pieter |
