Old 9th July 2010, 01:35   #1981  |  Link
RedDwarf1
RedDwarf Fan
I've noticed that when using DGMultiSource in both AvsP and MeGUI, GPU memory never gets released until the application is closed. Selecting release all videos from memory in AvsP doesn't free GPU memory, only closing the tab or AvsP releases the memory.
If I open a video using AvsP and resize the window to x2, it uses more memory, if I then resize it again either up to x3 or back to x1, more memory is used and so on and so on until the only option is to close AvsP or the tab (script) to release the memory. That's very inconvenient when looking through a video file.
I wasn't certain whether this was purely an AvsP problem but the fact I experienced similar things with MeGUI suggests it's not.
My Video card has 1GB of memory so I have more room for such memory leaks than some but it still gets very severe.
RedDwarf1 is offline   Reply With Quote
Old 9th July 2010, 02:45   #1982  |  Link
Originally Posted by dgeise View Post
Is there any chance you could support other vendors' GPU products, either by a separate decoder stack or bu using platform-neutral CUDA coding techniques?
If and when the other vendors expose an API for video decoding, it becomes a possibility. That is not the case at this time.
Consider running a secondary Nvidia card only for decoding alongside your main ATI card (if that is what you decide upon).
Old 9th July 2010, 02:46   #1983  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Hi Don,
I was wondering- the changes to your API function naming scheme seem to be opening a window for supporting 'other' <whisper> non-nvidia </whisper> video cards in the future.
The reason I ask is that I'm starting to look into buying a new computer, and the ATI video cards look to be a better deal from a price/performance/power perspective.
I'm pretty well hooked on your video processing tools, which makes it difficult to switch to different hardware. Your answer may somewhat influence my purchasing decisions, so I'll ask it right out.
Since this may be of general interest, I'm asking here on the forum.
Thanks & as always keep up the fantastic work-
- a big fan
CUDA is proprietary, hence supported by nvidia only.
The most probable and logical change would be moving toward OpenCL (that is also very similar to CUDA), but im not Donald, so i dont know what he wants to do and if it is doable.
That said, you should wait for an "official" answer from Donald.
Edit: he was faster than me... so you have your answer.
Old 9th July 2010, 03:59   #1984  |  Link
dgeise
ignorance is bliss
thanks for the responses.
maybe I'll stick with nvidia GPUs for the next iteration after all.
dgeise is offline   Reply With Quote
Old 9th July 2010, 06:38   #1985  |  Link
tormento
Acid fr0g
tormento's Avatar
How far is your card selection feature going?
@turment on Telegram
Old 9th July 2010, 11:15   #1986  |  Link
kebulek
kebulek's Avatar
Originally Posted by kebulek View Post
I've done some testing today and that bug occurs only with DGSource(...) and CUVIDserver. With DGMultiSource is everything OK.
Green frames show up after frame 744+.
Looks like I was wrong. I've encoded whole movie with DGMultiSource and at the end there are 2 bad repeating frames. But before encoding, I didn't see them in VDub...
MKV Sample (2MB)
kebulek is offline   Reply With Quote
Old 9th July 2010, 14:20   #1987  |  Link
OK
about "__aud__"
Hello,neuron2
I can't get a string of audio path by using "__aud__".
This situation have been continuing since dgdecnv2015.
I couldn't get dgdecnv2014, so I still use dgdecnv2013.
Dgdecnv2013 is fine, about the situation.
Please check it.
I attached an avs file about the situation.
File Type: zip template_deinterlace2.zip (692 Bytes, 31 views)
OK is offline   Reply With Quote
Old 9th July 2010, 15:05   #1988  |  Link
I'm aware of it because I saw it with your previous sample, even though you said it didn't happen!
Investigating. Use trim until I release a fix. It only happens in some cases at end of file.
Old 9th July 2010, 15:12   #1989  |  Link
Duplicated. Will fix for next release. Thanks for your report.
Old 10th July 2010, 02:50   #1990  |  Link
It's written on a piece of paper called my "to-do list".
@all
We have good news on the memory leak problem. Nvidia came through yet again in a fabulous manner. My secret contact O told me how to use "floating contexts" to dissociate the CUVID object creation/deletion from the invoking threads. Without that it didn't work because the creation and deletion was done from different threads, which was virtually forced upon me by the Avisynth architecture.
Now I can hit F2 in VirtualDub until the cows come home.
Say your goodbyes to the CUVID Server. He has served us well but must now move on to the quantum vacuum. May he serve in peace.
A test version is imminent.
@OK
Your bug is fixed.
@kebulek
You're up next.
Old 10th July 2010, 03:17   #1991  |  Link
Lyle_JP
Unreasonable User
Lyle_JP's Avatar
WooHoo! This memory leak was my biggest complaint as well, though I never brought it up neuron2 because I was never sure if it wasn't Avisynth x64's fault.
Lyle_JP is offline   Reply With Quote
Old 10th July 2010, 08:16   #1992  |  Link
tormento
Acid fr0g
tormento's Avatar
If there will be no more MEGUI/VDub errors I think there should be another imminent donation
Old 10th July 2010, 13:08   #1993  |  Link
kebulek
kebulek's Avatar
I've got another mystery - just made some testing with XviD and picture resizing directly with DGTools.
LoadPlugin("C:\Program Files\DGTools\DGMultiDecodeNV.dll")
DGMultiSource("E:\video.dgi", deinterlace=1, resize_w=624, resize_h=352).Trim(0,153290)
With this script, I'm able to open the .AVS only once in VD. Another try (with proper close and re-open) failed and VD freezed.
DGMultiSource("E:\video.dgi", deinterlace=1).LanczosResize(624,352).Trim(0,153290)
With this script works everything fine.
So is there something wrong with internal resize or it's a VD bug?
Old 10th July 2010, 22:35   #1994  |  Link
mikeyakame
lookin for my sanity
Location: it all depends on the day and which country comes to mind
@Neuron2
That is awesome news about the memory leak being fixed! It definitely means no more need to use DGSource to prepare a video!
mikeyakame is offline   Reply With Quote
Old 11th July 2010, 02:45   #1995  |  Link
meatwad
meatwad's Avatar
Can someone using StaxRip 1.1.6 confirm that build 2019 is working fine with it? I'm having some problems getting it to work with it, but I'm pretty sure it's an error on my part somewhere.
meatwad is offline   Reply With Quote
Old 11th July 2010, 08:55   #1996  |  Link
tormento
Acid fr0g
tormento's Avatar
I jumped on MeGui wagon. I suggest you to do the same as it is much more complete and you can train to use it as in near future I suggest you to use the x64 version too. It is much faster and stable.
Old 11th July 2010, 10:17   #1997  |  Link
Groucho2004
I'm a bit at a loss here. Why do people use these buggy "GUIs" when the DG tools do (almost) everything for them already? All that has to be done in most cases is to feed the script into the encoder.
I'll try to keep my opinion about the "GUI designers" to myself, many of them don't know squat about programming that goes beyond putting some fancy dialogs together in Visual Basic.
So, what am I missing? Is it really so hard to create a batch file (considering the countless examples that can be found here on Doom9)?
Or is it about calculating the bitrate? Multiplexing?
Just curious.
Old 11th July 2010, 12:06   #1998  |  Link
tormento
Acid fr0g
tormento's Avatar
Personally I edit the avs by hand BUT I can't remember every x264 switch I need AND I can't stay at home to manually wait to launch the next job.
To sum things up: create x264 command line and batch it. Stop.
Old 11th July 2010, 12:36   #1999  |  Link
General discussion of GUIs is off topic here. Thank you.
Old 11th July 2010, 12:57   #2000  |  Link
MOS-Marauder
Well if i prepare my Cue with MeGui (latest Dev Build and DGTools NV 2019) and DONT use Cuvid Server it crashes badly on after adding to cue and trying to create the 2nd AVS with the AVS Script Generator. DGMultiSource isnt yet working good. if i check "use Cuvid Server" all is working as expected.
Also.. if one AVS using DGMultisource is playing in Mediaplayer i cannot open another one (Cuvid Deode error, no video...crashing BOTH then)..
Edit: Ahem sorry for mentioning "the GUI".. but in fact it also happens w/o it...
Chris
MOS-Marauder is offline   Reply With Quote
