Old 4th February 2009, 10:20   #8141  |  Link
DrNein
Originally Posted by jfcarbel View Post
On this note, does anyone know if its possible with the ArcSoft DTS Decoder to do similar.
That is, install the full version but then remove all its filters except for the one that eacto needs. I don't mind getting ArcSoft TotalMedia Theatre but I fear all its filters will gunk up my other software like PowerDVD, ProShow Gold. Anyone have any experience with installing a Lite version or have a batch script that can unregister all the unneeded filters except for the one eacto needs?
Also curious, do people have scripts that load/unload filters based on tools that may need them? That way, they are loaded when needed and removed when task is completed.
I suppose that maybe eacto is coded to strictly build its graph manually to force its use of a specific filter. But I am not well versed in all this graph, DS Filters, codecs to know for sure. I just know that installing one program can hijack another programs use of its filters that it installed for a specific task. What a nightmare - DLL hell for codecs
Jom covered some of that here:
http://forum.doom9.org/showthread.ph...86#post1239786
Also, see post #8037 and 8041
http://forum.doom9.org/showthread.ph...55#post1242555
As for codec hell, that's what a good configurable player such as MPC-HC is for.
Although others like PowerDVD will only use their own anyway.
DrNein is offline
Old 4th February 2009, 10:24   #8142  |  Link
DrNein
Originally Posted by lchiu7 View Post
I am having problems with eac3to finding and using the Nero 7 DD decoder. Initially -test would show it had found it but every time I would run a job to extract the DD track from a eac3 track, it would die in some random place in the file. I have had to use -libav to complete the processing.
Installed the latest update to Nero 7 7.11.10 and how when I run -test I receive the following message\
Nero Audio Decoder (Nero 7) is not working correctly
http://www.nero.com/eng/store-blu-ray.html
Nero works fine since I am able to use Nero Vision to playback a .ts file with h.264 video and DD 5.1 audio
Not entirely sure what to do now. If I continue to use -libav what sonic compromises, if any, am I having to make?
Thanks
Also, see #7880 and on and particularly:
http://forum.doom9.org/showthread.ph...09#post1238209
DrNein is offline
Old 4th February 2009, 13:28   #8143  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by Blue_MiSfit View Post
This one is the 3.1ch 640kbps AC3 track from the BluRay release of Bubble. eac3to complains about encoding it down to a 2ch AC3:
How can I convert this bad boy down to 2ch, 192kbps Dolby Digital properly?
Select your preferred downmix
function Dmix3Stereo(clip a)  # 3 Channels L,R,C
  flr = GetChannel(a, 1, 2)
  fcc = GetChannel(a, 3, 3)
  return MixAudio(flr, fcc, 0.5858, 0.4142)
function Dmix4lStereo(clip a)  # 4 Channels L,R,C + LFE
  lfe = GetChannel(a, 4, 4)
  clf = MixAudio(fcc, lfe, 0.2929, 0.2929)
  return MixAudio(flr, clf, 0.4142, 1.0)
NicAc3Source("Bubble.ac3")
Dmix3Stereo
#Dmix4lStereo
Normalize()
And encode with EncWAVtoAC3 v3.0b
tebasuna51 is offline
Old 4th February 2009, 16:23   #8144  |  Link
idbirch2
I just demuxed Eight Below, purely to see the subtitle information and if the english SUPs contained any forced captions and there's a discrepency between the subtitle track numbers displayed at the beginning of the log and those used at the end to display forced caption info. Here's the log so you can see what I mean:
eac3to v3.06
command line: "C:\program files\audio\eac3to\eac3to.exe" "I:\0Stuff\Eight Below Blu-Ray" 1) -demux
M2TS, 1 video track, 10 audio tracks, 16 subtitle tracks, 2:00:24, 24p /1.001
1: Chapters, 15 chapters
2: MPEG2, 1080p24 /1.001 (16:9)
3: RAW/PCM, English, 5.1 channels, 16 bits, 48khz
4: AC3, English, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
5: DTS, French, 5.1 channels, 24 bits, 1509kbps, 48khz, dialnorm: -4dB
6: AC3, French, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
7: DTS, Italian, 5.1 channels, 24 bits, 1509kbps, 48khz, dialnorm: -4dB
8: AC3, Italian, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
9: DTS, German, 5.1 channels, 24 bits, 1509kbps, 48khz, dialnorm: -4dB
10: AC3, German, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
11: DTS, Spanish, 5.1 channels, 24 bits, 1509kbps, 48khz, dialnorm: -4dB
12: AC3, Spanish, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
13: Subtitle (PGS), English
14: Subtitle (PGS), English
15: Subtitle (PGS), French
16: Subtitle (PGS), Italian
17: Subtitle (PGS), German
18: Subtitle (PGS), Spanish
19: Subtitle (PGS), Dutch
20: Subtitle (PGS), Norwegian
21: Subtitle (PGS), Danish
22: Subtitle (PGS), Swedish
23: Subtitle (PGS), Finnish
24: Subtitle (PGS), Icelandic
25: Subtitle (PGS), French
26: Subtitle (PGS), Italian
27: Subtitle (PGS), German
28: Subtitle (PGS), Spanish
Creating file "00046 - Chapters.txt"...
[a11] Extracting audio track number 11...
[a07] Extracting audio track number 7...
[a09] Extracting audio track number 9...
[a10] Extracting audio track number 10...
[a10] Removing AC3 dialog normalization...
[s14] Extracting subtitle track number 14...
[s20] Extracting subtitle track number 20...
[a05] Extracting audio track number 5...
[s15] Extracting subtitle track number 15...
[s17] Extracting subtitle track number 17...
[a08] Extracting audio track number 8...
[s21] Extracting subtitle track number 21...
[s13] Extracting subtitle track number 13...
[s23] Extracting subtitle track number 23...
[s27] Extracting subtitle track number 27...
[s25] Extracting subtitle track number 25...
[a08] Removing AC3 dialog normalization...
[a07] Removing DTS dialog normalization...
[s16] Extracting subtitle track number 16...
[s19] Extracting subtitle track number 19...
[a03] Extracting audio track number 3...
[s22] Extracting subtitle track number 22...
[a11] Removing DTS dialog normalization...
[a09] Removing DTS dialog normalization...
[a06] Extracting audio track number 6...
[a06] Removing AC3 dialog normalization...
[s18] Extracting subtitle track number 18...
[s24] Extracting subtitle track number 24...
[a05] Removing DTS dialog normalization...
[a12] Extracting audio track number 12...
[a12] Removing AC3 dialog normalization...
[s28] Extracting subtitle track number 28...
[v02] Extracting video track number 2...
[a03] Reading RAW/PCM...
[s26] Extracting subtitle track number 26...
[a04] Extracting audio track number 4...
[a03] Swapping endian...
[a04] Removing AC3 dialog normalization...
[a03] Remapping channels...
[a03] Creating file "00046 - 3 - PCM, English, 5.1 channels, 16 bits, 48khz.pcm"...
[v02] Creating file "00046 - 2 - MPEG2, 1080p24.m2v"...
[a05] Creating file "00046 - 5 - DTS, French, 5.1 channels, 24 bits, 1509kbps, 48khz.dts"...
[a07] Creating file "00046 - 7 - DTS, Italian, 5.1 channels, 24 bits, 1509kbps, 48khz.dts"...
[a09] Creating file "00046 - 9 - DTS, German, 5.1 channels, 24 bits, 1509kbps, 48khz.dts"...
[a11] Creating file "00046 - 11 - DTS, Spanish, 5.1 channels, 24 bits, 1509kbps, 48khz.dts"...
[a04] Creating file "00046 - 4 - AC3, English, 5.1 channels, 640kbps, 48khz.ac3"...
[a06] Creating file "00046 - 6 - AC3, French, 5.1 channels, 640kbps, 48khz.ac3"...
[a08] Creating file "00046 - 8 - AC3, Italian, 5.1 channels, 640kbps, 48khz.ac3"...
[a10] Creating file "00046 - 10 - AC3, German, 5.1 channels, 640kbps, 48khz.ac3"...
[a12] Creating file "00046 - 12 - AC3, Spanish, 5.1 channels, 640kbps, 48khz.ac3"...
[s14] Creating file "00046 - 14 - Subtitle (PGS), English.sup"...
[s17] Creating file "00046 - 17 - Subtitle (PGS), German.sup"...
[s13] Creating file "00046 - 13 - Subtitle (PGS), English.sup"...
[s24] Creating file "00046 - 24 - Subtitle (PGS), Icelandic.sup"...
[s18] Creating file "00046 - 18 - Subtitle (PGS), Spanish.sup"...
[s23] Creating file "00046 - 23 - Subtitle (PGS), Finnish.sup"...
[s20] Creating file "00046 - 20 - Subtitle (PGS), Norwegian.sup"...
[s22] Creating file "00046 - 22 - Subtitle (PGS), Swedish.sup"...
[s21] Creating file "00046 - 21 - Subtitle (PGS), Danish.sup"...
[s16] Creating file "00046 - 16 - Subtitle (PGS), Italian.sup"...
[s15] Creating file "00046 - 15 - Subtitle (PGS), French.sup"...
[s19] Creating file "00046 - 19 - Subtitle (PGS), Dutch.sup"...
[a03] The original audio track has a constant bit depth of 16 bits.
[a04] Audio overlaps for 18ms at playtime 0:47:21. <WARNING>
[a04] Audio overlaps for 22ms at playtime 1:38:36. <WARNING>
[a05] Audio overlaps for 7ms at playtime 0:47:21. <WARNING>
[a06] Audio overlaps for 18ms at playtime 0:47:21. <WARNING>
[a06] Audio overlaps for 22ms at playtime 1:38:36. <WARNING>
[a07] Audio overlaps for 7ms at playtime 0:47:21. <WARNING>
[a08] Audio overlaps for 18ms at playtime 0:47:21. <WARNING>
[a08] Audio overlaps for 22ms at playtime 1:38:36. <WARNING>
[a09] Audio overlaps for 7ms at playtime 0:47:21. <WARNING>
[a10] Audio overlaps for 18ms at playtime 0:47:21. <WARNING>
[a10] Audio overlaps for 22ms at playtime 1:38:36. <WARNING>
[a11] Audio overlaps for 7ms at playtime 0:47:21. <WARNING>
[a12] Audio overlaps for 18ms at playtime 0:47:21. <WARNING>
[a12] Audio overlaps for 22ms at playtime 1:38:36. <WARNING>
[s25] Creating file "00046 - 25 - Subtitle (PGS), French.sup"...
[s26] Creating file "00046 - 26 - Subtitle (PGS), Italian.sup"...
[s27] Creating file "00046 - 27 - Subtitle (PGS), German.sup"...
[s28] Creating file "00046 - 28 - Subtitle (PGS), Spanish.sup"...
[a04] Starting 2nd pass...
[a04] Realizing (E-)AC3 gaps...
[a05] Starting 2nd pass...
[a05] Realizing DTS gaps...
[a06] Starting 2nd pass...
[a06] Realizing (E-)AC3 gaps...
[a07] Starting 2nd pass...
[a07] Realizing DTS gaps...
[a08] Starting 2nd pass...
[a08] Realizing (E-)AC3 gaps...
[a09] Starting 2nd pass...
[a09] Realizing DTS gaps...
[a10] Starting 2nd pass...
[a10] Realizing (E-)AC3 gaps...
[a11] Starting 2nd pass...
[a11] Realizing DTS gaps...
[a12] Starting 2nd pass...
[a12] Realizing (E-)AC3 gaps...
Video track 2 contains 173195 frames.
Subtitle track 14 contains 947 captions.
Subtitle track 15 contains 1053 captions.
Subtitle track 16 contains 864 normal and 24 forced captions.
Subtitle track 17 contains 892 normal and 27 forced captions.
Subtitle track 18 contains 943 normal and 29 forced captions.
Subtitle track 19 contains 949 normal and 31 forced captions.
Subtitle track 20 contains 694 normal and 21 forced captions.
Subtitle track 21 contains 947 normal and 27 forced captions.
Subtitle track 22 contains 945 normal and 30 forced captions.
Subtitle track 23 contains 952 normal and 29 forced captions.
Subtitle track 24 contains 923 normal and 31 forced captions.
Subtitle track 25 contains 889 normal and 20 forced captions.
Subtitle track 26 contains 23 forced captions.
Subtitle track 27 contains 25 forced captions.
Subtitle track 28 contains 27 forced captions.
Subtitle track 29 contains 29 forced captions.
eac3to processing took 23 minutes, 43 seconds.
Done.
As you can see, at the beginning of the log, the subs are listed as using tracks 13-28 and indeed, these are the numbers used in the filenames of the demuxed subs but right at the end of the log, subtitle tracks suddenly go from 14-29, is this a bug?
idbirch2 is offline
Old 4th February 2009, 19:37   #8145  |  Link
pihug12
I try to make a batch file to convert DTS sounds in MKV to AC3 640kbit/s.
mkdir temp
cd temp
..\eac3to.exe ..\%Input% -demux
..\eac3to.exe *.dts *.ac3 -640
..\eac3to.exe *.h264+*.ac3 %Output%
The demux works fine but then I get :
Source file "*.dts" not found.
Source file "*.h264" not found.
I think I cannot use the * character. How can I make that ?
___________
Why can't I demux a MKV file in an another output folder (ex: eac3to.exe video.mkv temp -demux) ?
C:\Documents and Settings\User\Desktop\eac3to>eac3to.exe video.mkv temp -demux
MKV, 1 video track, 2 audio tracks, 2 subtitle tracks, 1:38:42, 23.975p
1: V_MPEG4/ISO/AVC, English, 1280x528p (80:33)
2: DTS-ES, English, 5.1 channels, 24 bits, 1509kbps, 48khz
"DTS"
3: AC3 EX, French, 5.1 channels, 640kbps, 48khz
"AC3 5.1"
4: S_TEXT/UTF8, French
5: S_TEXT/UTF8, French
Track 2 is used for destination file "temp".
This audio conversion is not supported.
pihug12
pihug12 is offline
Old 4th February 2009, 21:13   #8146  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
@Tebasuna51:
Thanks for your help! You're always the man with the downmixing scripts!
Quick question though. I currently have EncWAVtoAC3 2.0, and am trying to find 3.0. The official site seems to be down. Do you have a good mirror? For now, I will just use the handy-dandy SoundOut avisynth plugin, but I'd like to update EncWAVtoAC3.
Thanks again!
~MiSfit
Blue_MiSfit is offline
Old 4th February 2009, 21:36   #8147  |  Link
ACrowley
@Tebasuna51:
Thanks again!
~MiSfit
http://code.google.com/p/wavtoac3encoder/
ACrowley is offline
Old 4th February 2009, 23:34   #8148  |  Link
jj666
link.
Would suggest to try something similar to the above link. As that's obviously a HD source with re-encoded video, why didn't you convert the audio at the same time as encoding the movie?
-jj-
jj666 is offline
Old 5th February 2009, 00:12   #8149  |  Link
laserfan
Aging Video Hobbyist
Bug in chapter detection
Today I looked at my new Vantage Point BD and eac3to reported 51 chapters. This movie has 16 chapters so on a hunch went back to an earlier version of eac3to and sure enough, got 16 chapters. After trying subsequent versions I found that it broke going from v2.65 to v2.66:
eac3to v2.65
command line: eac3to h:\bdmv\stream\00011.m2ts
M2TS, 2 video tracks, 7 audio tracks, 15 subtitle tracks, 1:30:05
1: Chapters, 16 chapters *CORRECT*
2: h264/AVC, 1080p24 /1.001 (16:9)
3: h264/AVC, 480p24 /1.001 (20:11)
4: TrueHD/AC3, English, 5.1 channels, 48khz
5: AC3, French, 5.1 channels, 640kbps, 48khz, dialnorm: -30dB
6: AC3, Spanish, 5.1 channels, 640kbps, 48khz, dialnorm: -30dB
7: AC3, Portuguese, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
8: AC3, Thai, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
9: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
10: DTS Express, English, 2.0 channels, 24 bits, 192kbps, 48khz
11: Subtitle (PGS), English
12: Subtitle (PGS), English
13: Subtitle (PGS), French
14: Subtitle (PGS), Spanish
15: Subtitle (PGS), Portuguese
16: Subtitle (PGS), Chinese
17: Subtitle (PGS), Chinese
18: Subtitle (PGS), Korean
19: Subtitle (PGS), Thai
20: Subtitle (PGS), Spanish
21: Subtitle (PGS), Portuguese
22: Subtitle (PGS), Korean
23: Subtitle (PGS), Spanish
24: Subtitle (PGS), Portuguese
25: Subtitle (PGS), English
eac3to v2.66
1: Chapters, 51 chapters *INCORRECT*
A peek at the changelog shows the likely culprit:
v2.66
* changed eac3to to allow AAC encoding with 7.1 channels (for new Nero encoder)
* fixed AGM creation for files bigger than 4GB
* added support for Nero's new AAC Encoder download URL
* lowered volume of error/success sounds
* when there are 2 similar playlists the one with less chapters is ignored now
Broken all the way to 3.06. Let me know Madshi if I can help in any way to fix it.
laserfan is offline
Old 5th February 2009, 01:07   #8150  |  Link
Snowknight26
Assuming there is only 1 video and 1 DTS track:
for /f "delims=;" %%a in ('dir *.mkv /b /s') do {
	eac3to %%a 1: %%a.video.mkv 2: %%a.ac3
	mkvmerge -o %%a.DTS.mkv  --language 1:eng --default-track 1:yes -d 1 -A -S %%a.video.mkv -a 0 -D -S %%a.ac3 --track-order 0:1,1:0
	del %%a.video.mkv
	del %%a.ac3
pause
Something like that at least.
Snowknight26 is offline
Old 5th February 2009, 01:28   #8151  |  Link
~bT~
н∂-ƒαиαтι¢
@ laserfan
have you tried the latest version??
~bT~ is offline
Old 5th February 2009, 01:40   #8152  |  Link
sidekick2
Originally Posted by ~bT~ View Post
@ laserfan
He said it's broken all the way thru 3.06 at the bottom of his post. He was using older versions to see where the breakage had occurred.
When I started reading his post myself, I thought, why the *heck* isn't he using a version from this century?!?
sidekick2 is offline
Old 5th February 2009, 03:19   #8153  |  Link
laserfan
And who knows, maybe it's the authoring that's wrong, not eac3to! I should not have assumed a Madshi bug when it comes to BD discs!
laserfan is offline
Old 6th February 2009, 19:42   #8154  |  Link
madshi
Originally Posted by honai View Post
I'm trying to remux an MKV I created with an earlier version of eac3to which still contains pulldown information.
However, demuxing with -demux works and eac3to correctly identifies the video as VC-1.
Is this a bug or intentional misbehavior?
Support for such older VC-1 MKVs will come in a future version.
Originally Posted by Snowknight26 View Post
Madshi, though you say you plan on adding chapter and subtitle demuxing from mkvs, you didn't mention attachments. Any plans for those?
In the long run, yes. In theory it's really easy to extract MKV attachments. However, making the eac3to infrastructure understand that there are not only "video", "audio" and "subtitle" tracks, but also "attachments" is quite a lot of work. So it might take a while until I find the time to implement that. Don't know...
Also, doing anything with eac3to over a network share seems to be really slow. I'm remuxing an mkv and eac3to uses 0% CPU usage 90% of the time. It spikes up to about 10% for a fraction of a second... same with the network usage graph.
Anyone else having similar problems? It seems to work fine for me. Did older versions work better?
Wonder why most can't be parsed while a few odd ones (like this first one) can
Because some of them have sequence headers in the stream and some don't.
And finally, a small observation. Analysing mkvs with FLAC audio tracks takes far longer than ones with AC3 or DTS. Weird how that happens.
That's because eac3to actually decodes the FLAC track during analyzation. I guess I can optimize that...
I suggest to madshi don't put the bitdepth of the source with standard DTS and DTS HR because this data is misunderstand (and irrelevant).
Might be a good idea, at least to get rid of all these annoying "is it really necessary that eac3to patches it to 24bit?" questions. Will think about it.
Originally Posted by magic144 View Post
Up until now, I've just been using:-
eac3to L: 1) -demux, followed by
eac3to video.vc1 video.mkv
to demux and then put/house the demuxed .vc1 'raw' output into a more useful .mkv container for graphedit to use for frameserving (via Haali Media Splitter, WMVideo Decoder DMO)
however, I'm curious to know if that would produce *exactly* the same video result (frame-for-frame) as, e.g. (assuming track 2 is the video in question):-
eac3to L: 1) 2: video.mkv
would the first 2-step method lose/discard any important information (frame-rate, etc) that the original container used to define the .vc1 stream?
I have read that a raw .vc1 stream is somewhat dependent on its container to fully specify it, so I'm worried that a 2-step process would be lossy in some way?
Both methods should produce similar results, as long as there are no gaps/overlaps in the video track (which is really rare). VC-1 does not depend on the container.
Originally Posted by odin24 View Post
Is it possible that eac3to reports the wrong information in regards to 1080p or 1080i? I have a BD that says 1080i on the back... which is odd, however eac3to and tsMuxeR both report 1080p. I trust eac3to more than what's on the back cover.
eac3to reports two different things: In the track listing (e.g. if you do "eac3to BluRayFolder") eac3to shows what the Blu-Ray information records say without actually looking at the video data itself. This information *should* be reliable, more so than the back cover, but it could theoretically be wrong. If you actually let eac3to parse the movie file, it checks out the video bitstream. This should be even more reliable (unless there's a bug in eac3to). In your specific case it seems that the back cover is simply wrong.
Here's another silly sample for you, Madshi (20mb cut of source AC3)
eac3to currently can't downmix funny channel configurations. It's on my to do list to add support for that, but it doesn't have top priority right now...
Thanks, looks like a clear bug.
You can't just invent your own command line commands. You'll have to live with what eac3to understands. What you could do is "eac3to video.mkv temp\video.*". That will demux into the MKV into a folder named "temp", if that's what you want.
Can you please upload the CLIPINF and PLAYLIST folders? Zipped that should only be a few KBs.
madshi is offline
Old 6th February 2009, 20:44   #8155  |  Link
lchiu7
Originally Posted by DrNein View Post
Sorry but can't see the relevance of those posts. I am having problems with the Nero codec, not Arcsoft.
A quick check of the DS Filter chain shows
"Nero Audio Decoder 2",{83E69A3D-56A5-4850-89C9-F6B6F003EB9B},00600000,"c:\program files\common files\ahead\dsfilter\neaudio2.ax"
Not entirely sure what else to check
And I am running Nero 7, not 8.
lchiu7 is offline
Old 6th February 2009, 21:29   #8156  |  Link
laserfan
...eac3to reported 51 chapters. This movie has 16 chapters so on a hunch went back to an earlier version of eac3to and sure enough, got 16 chapters. After trying subsequent versions I found that it broke going from v2.65 to v2.66...
Here you go--I think 00216 is the mpls of interest and the clpi prolly 00011. Advise if I can provide any further info!
laserfan is offline
Old 6th February 2009, 21:33   #8157  |  Link
magic144
thanks for the reply madshi,
are you saying that one of these 2 methods does NOT remove/compensate for gaps/overlaps - I thought eac3to would always remove gaps/overlaps when demuxing a full-disc-structure title... if this is not the case, which of these 2 methods doesn't invoke eac3to's gap removal...?
or is it simply the case that eac3to does not do ANY Video gap compensation (in any mode - i.e. it just does audio) - I guess if that was the case and that ever happened, eac3to would just flag it in an info/warning message? (never seen such a warning on any of my discs to date anyway) - is it something eac3to might handle in the future?
cheers again,
m
ps - incidentally, does anybody out there know of a way to accurately frameserve (in an AviSynth script) a raw .vc1 file without going to an intermediate .mkv container? I don't think the Haali source file splitter filter will take a .vc1 file as input if I try to build such a graph in graphedit.
magic144 is offline
Old 6th February 2009, 22:49   #8158  |  Link
Thunderbolt8
better upload it externally, as getting approval can take ages.
Thunderbolt8 is offline
Old 6th February 2009, 22:56   #8159  |  Link
laserfan
Wonder what this is about; the last time I attached something here no approval was needed at all afaict.
laserfan is offline
Old 6th February 2009, 23:56   #8160  |  Link
topsham
Originally Posted by nautilus7 View Post
I am trying to use the new aften build (762), but i get this error:
eac3to input.eac3 output.ac3
E-AC3, 5.1 channels, 1:42:01, 2046kbit/s, 48khz, dialnorm: -27dB
Removing dialog normalization...
Decoding with DirectShow (Nero Audio Decoder 2)...
Disabling DRC for Nero (E-)AC3 decoding...
DirectShow reports 5.1 channels, 24 bits, 48khz
Encoding AC3...
invalid number of channels
Initialization of the AC3 encoder failed.
eac3to is latest (2.30) and this happens with all libaften builds (generic, SSE3 etc). It also happens when i use as input wav or raw or ac3 files. In other words always. But if i use aften.exe and encode to ac3 outside eac3to everything works fine.
Does it seem as a libaften or an eac3to problem?
I am just starting to use eac3to and have encountered this problem. Is there a fix please?
topsham is offline
eac3to
