Old 15th May 2014, 03:45   #1  |  Link
darkslayer00
hi10p or hi444p?
i was thinking was ith good for compression, pc efficiency, keeping the same color and brightness
darkslayer00 is offline   Reply With Quote
Old 16th May 2014, 06:42   #2  |  Link
MichaelRow
MichaelRow's Avatar
afaik, It's better to keep YUV444P with higher quantizer rather than downsample to YUV420P with lower quantizer, as for efficiency, it doesn't make much difference on my computer.
ScreenShot:
YUV444P10
YUV420P10
You can see this thread for more information.
MichaelRow is offline   Reply With Quote
Old 18th May 2014, 23:42   #3  |  Link
Asmodian
There is usually no reason to stick to 4:4:4 8 bit, better to go all the way to 4:4:4 10 bit as MichaelRow suggested. Of course if your source is already 4:2:0 4:4:4 is not helpful.
compression, h264, hi10p, hi444p, quality
