Old 31st March 2016, 19:12   #1  |  Link
Roco
Encode 4K at 4:4:4 possible?
Is there a way to encode 4K content with x.265 at 4:4:4?
If yes, what utilities/plugins and script will I need?
Roco is offline   Reply With Quote
Old 31st March 2016, 19:29   #2  |  Link
sneaker_ger
You don't need any special utilities or plugins. You can work with 4:4:4 YUV in AviSynth just fine via the YV24 colorspace. Then create an y4m pipe into x265.exe using e.g. avs2pipemod. Or if you want to feed raw x265 has the --input-csp parameter.
Old 1st April 2016, 10:48   #3  |  Link
Roco
Thanks, megui has also x265 support, I'll try with that first.
4:4:4, encode, uhd, x.265
