Old 3rd April 2018, 17:50   #1  |  Link
doomleox999
6 channels to Stereo
Hi everyone, first of all english is not my first language, sorry for any mistakes I make.
When I encode a 6ch audio to stereo with MeGUI I use this setting:
The final result is not as loud as the original audio, now, if I extract the audio track from the file and encode it with ffmpeg (-i sixchannels.aac -ac 2 -ab 128k stereo.aac something like that) the result is amazing! It's almost indistinguible from the original.
I'm no expert, so I'm not sure if I'm right, but I feel that ffmpeg mixes the 6 channels and MeGUI only takes 2 out of the 6. Again, I'm not sure if that's right but that's the impression I get.
Am I right? Am I wrong? Is it possible to use ffmpeg WITH MeGUI (to save time) or tell MeGUI to "mix the 6 channels into stereo"?
Thanks in advance!
doomleox999 is offline   Reply With Quote
Old 3rd April 2018, 21:50   #2  |  Link
tebasuna51
tebasuna51's Avatar
Of course with 2 speakers we can't obtain the same volume than with 6 speakers.
Then use ffmpeg instead MeGUI. No problem.
Nope, MeGUI (AviSynth) mix the 6 channels an normalize to obtain the max volume without distort.
To save time use ffmpeg out of MeGUI, you don't need AviSynth for your conversion.
Old 4th April 2018, 04:00   #3  |  Link
hello_hello
If you check the log file you'll find the script MeGUI uses for downmixing the audio. It reduces the volume to prevent clipping when the channels are combined, followed by Normalize() to increase the peaks to maximum after downmixing (assuming the Normaize option is checked).
Maybe ffmpeg doesn't prevent clipping by default, and likewise when you playback 5.1ch audio being downmixed to stereo, the volume isn't being reduced to prevent clipping either, so they sound the same.
Old 4th April 2018, 04:49   #4  |  Link
doomleox999
---[Information] Audio
--[Information] [04/04/18 00:36:34] Trying to open the file with LWLibavAudioSource()
--[Information] [04/04/18 00:38:03] Successfully opened the file with LWLibavAudioSource()
-[NoImage] ClearAutoloadDirs()
-[NoImage] AddAutoloadDir("C:\Users\USER\MeGUI\tools\avs\plugins")
-[NoImage] LoadPlugin("C:\Users\USER\MeGUI\tools\lsmash\LSMASHSource.dll")
-[NoImage] LWLibavAudioSource("C:\Users\USER\Desktop\MeGUI Output\AUDIO.aac")
-[NoImage] # detected channels: 6
-[NoImage] # detected channel positions: 3/2/0.1
-[NoImage] LoadPlugin("C:\Users\USER\MeGUI\tools\avisynth_plugin\AudioLimiter.dll")
-[NoImage] c6_stereo(ConvertAudioToFloat(last))
-[NoImage] Normalize()
-[NoImage] return last
-[NoImage] # 5.1 Channels L,R,C,LFE,SL,SR -> stereo + LFE
-[NoImage] function c6_stereo(clip a)
-[NoImage]   {
-[NoImage]      fl = GetChannel(a, 1)
-[NoImage]      fr = GetChannel(a, 2)
-[NoImage]      fc = GetChannel(a, 3)
-[NoImage]      lf = GetChannel(a, 4)
-[NoImage]      sl = GetChannel(a, 5)
-[NoImage]      sr = GetChannel(a, 6)
-[NoImage]      fl_sl = MixAudio(fl, sl, 0.2929, 0.2929)
-[NoImage]      fr_sr = MixAudio(fr, sr, 0.2929, 0.2929)
-[NoImage]      fc_lf = MixAudio(fc, lf, 0.2071, 0.2071)
-[NoImage]      l = MixAudio(fl_sl, fc_lf, 1.0, 1.0)
-[NoImage]      r = MixAudio(fr_sr, fc_lf, 1.0, 1.0)
-[NoImage]      return MergeChannels(l, r)
-[NoImage]   }
-[NoImage] # 5 Channels L,R,C,SL,SR or L,R,LFE,SL,SR-> Stereo
-[NoImage] function c5_stereo(clip a)
-[NoImage]   {
-[NoImage]      sl = GetChannel(a, 4)
-[NoImage]      sr = GetChannel(a, 5)
-[NoImage]      fl_sl = MixAudio(fl, sl, 0.3694, 0.3694)
-[NoImage]      fr_sr = MixAudio(fr, sr, 0.3694, 0.3694)
-[NoImage]      l = MixAudio(fl_sl, fc, 1.0, 0.2612)
-[NoImage]      r = MixAudio(fr_sr, fc, 1.0, 0.2612)
-[NoImage]   }
-[NoImage] # 5 Channels L,R,C,LFE,S -> Stereo
-[NoImage] function c52_stereo(clip a)
-[NoImage]   {
-[NoImage]      bc = GetChannel(a, 5)
-[NoImage]      fl_bc = MixAudio(fl, bc, 0.3205, 0.2265)
-[NoImage]      fr_bc = MixAudio(fr, bc, 0.3205, 0.2265)
-[NoImage]      fc_lf = MixAudio(fc, lf, 0.2265, 0.2265)
-[NoImage]      l = MixAudio(fl_bc, fc_lf, 1.0, 1.0)
-[NoImage]      r = MixAudio(fr_bc, fc_lf, 1.0, 1.0)
-[NoImage]   }
-[NoImage] # 4 Channels Quadro L,R,SL,SR -> Stereo
-[NoImage] function c4_stereo(clip a)
-[NoImage]   {
-[NoImage]      sl = GetChannel(a, 3)
-[NoImage]      sr = GetChannel(a, 4)
-[NoImage]      l = MixAudio(fl, sl, 0.5, 0.5)
-[NoImage]      r = MixAudio(fr, sr, 0.5, 0.5)
-[NoImage]   }
-[NoImage] # 4 Channels L,R,C,LFE or L,R,S,LFE or L,R,C,S -> Stereo
-[NoImage] function c42_stereo(clip a)
-[NoImage]   {
-[NoImage]      fc_lf = MixAudio(fc, lf, 0.2929, 0.2929)
-[NoImage]      l = MixAudio(fl, fc_lf, 0.4142, 1.0)
-[NoImage]      r = MixAudio(fr, fc_lf, 0.4142, 1.0)
-[NoImage]   }
-[NoImage] # 3 Channels L,R,C or L,R,S or L,R,LFE -> Stereo
-[NoImage] function c3_stereo(clip a)
-[NoImage]   {
-[NoImage]      l = MixAudio(fl, fc, 0.5858, 0.4142)
-[NoImage]      r = MixAudio(fr, fc, 0.5858, 0.4142)
-[NoImage]   }
-[NoImage] # 5.1 Channels L,R,C,LFE,SL,SR -> Dolby ProLogic
-[NoImage] function c6_dpl(clip a)
-[NoImage]   {
-[NoImage]      bc = MixAudio(sl, sr, 0.2265, 0.2265)
-[NoImage]      fl_fc = MixAudio(fl, fc, 0.3205, 0.2265)
-[NoImage]      fr_fc = MixAudio(fr, fc, 0.3205, 0.2265)
-[NoImage]      l = MixAudio(fl_fc, bc, 1.0, 1.0)
-[NoImage]      r = MixAudio(fr_fc, bc, 1.0, -1.0)
-[NoImage]   }
-[NoImage] # 5 Channels L,R,C,SL,SR -> Dolby ProLogic
-[NoImage] function c5_dpl(clip a)
-[NoImage]   {
-[NoImage]   }
-[NoImage] # 5 Channels L,R,LFE,SL,SR -> Dolby ProLogic
-[NoImage] function c52_dpl(clip a)
-[NoImage]   {
-[NoImage]      bc = MixAudio(sl, sr, 0.2929, 0.2929)
-[NoImage]      l = MixAudio(fl, bc, 0.4142, 1.0)
-[NoImage]      r = MixAudio(fr, bc, 0.4142, -1.0)
-[NoImage]   }
-[NoImage] # 5 Channels L,R,C,LFE,S -> Dolby ProLogic
-[NoImage] function c53_dpl(clip a)
-[NoImage]   {
-[NoImage]      fl_fc = MixAudio(fl, fc, 0.4142, 0.2929)
-[NoImage]      fr_fc = MixAudio(fr, fc, 0.4142, 0.2929)
-[NoImage]      l = MixAudio(fl_fc, bc, 1.0, 0.2929)
-[NoImage]      r = MixAudio(fr_fc, bc, 1.0, -0.2929)
-[NoImage]   }
-[NoImage] # 4 Channels Quadro L,R,SL,SR -> Dolby ProLogic
-[NoImage] function c4_dpl(clip a)
-[NoImage]   {
-[NoImage]   }
-[NoImage] # 4 Channels L,R,LFE,S  -> Dolby ProLogic
-[NoImage] function c42_dpl(clip a)
-[NoImage]   {
-[NoImage]      bc = GetChannel(a, 4)
-[NoImage]      l = MixAudio(fl, bc, 0.5858, 0.4142)
-[NoImage]      r = MixAudio(fr, bc, 0.5858, -0.4142)
-[NoImage]   }
-[NoImage] # 4 Channels L,R,C,S -> Dolby ProLogic
-[NoImage] function c43_dpl(clip a)
-[NoImage]   {
-[NoImage]   }
-[NoImage] # 3 Channels L,R,S  -> Dolby ProLogic
-[NoImage] function c3_dpl(clip a)
-[NoImage]   {
-[NoImage]      bc = GetChannel(a, 3)
-[NoImage]   }
-[NoImage] # 5.1 Channels L,R,C,LFE,SL,SR -> Dolby ProLogic II
-[NoImage] function c6_dpl2(clip a)
-[NoImage]   {
-[NoImage]      ssl = MixAudio(sl, sr, 0.2818, 0.1627)
-[NoImage]      ssr = MixAudio(sl, sr, -0.1627, -0.2818)
-[NoImage]      fl_fc = MixAudio(fl, fc, 0.3254, 0.2301)
-[NoImage]      fr_fc = MixAudio(fr, fc, 0.3254, 0.2301)
-[NoImage]      l = MixAudio(fl_fc, ssl, 1.0, 1.0)
-[NoImage]      r = MixAudio(fr_fc, ssr, 1.0, 1.0)
-[NoImage]   }
-[NoImage] # 5 Channels L,R,C,SL,SR -> Dolby ProLogic II
-[NoImage] function c5_dpl2(clip a)
-[NoImage]   {
-[NoImage]   }
-[NoImage] # 5 Channels L,R,LFE,SL,SR -> Dolby ProLogic II
-[NoImage] function c52_dpl2(clip a)
-[NoImage]   {
-[NoImage]      ssl = MixAudio(sl, sr, 0.3714, 0.2144)
-[NoImage]      ssr = MixAudio(sl, sr, -0.2144, -0.3714)
-[NoImage]      l = MixAudio(fl, ssl, 0.4142, 1.0)
-[NoImage]      r = MixAudio(fr, ssr, 0.4142, 1.0)
-[NoImage]   }
-[NoImage] # 4 Channels Quadro L,R,SL,SR -> Dolby ProLogic II
-[NoImage] function c4_dpl2(clip a)
-[NoImage]   {
-[NoImage]   }
--[Information] [04/04/18 00:38:09] AviSynth script
--[Information] [04/04/18 00:38:09] Command line used: -ignorelength -br 128000 -if - -of "{0}"
--[Information] [04/04/18 00:38:09] AviSynth script environment opened
--[Information] [04/04/18 00:38:15] Script loaded
--[Information] [04/04/18 00:38:15] Output Decoder
---[Information] [04/04/18 00:38:15] Channels: 2
---[Information] [04/04/18 00:38:15] Bits per sample: 32
---[Information] [04/04/18 00:38:15] Sample rate: 48000
--[Information] [04/04/18 00:38:15] Job command line: C:\Users\USER\MeGUI\tools\eac3to\neroAacEnc.exe -ignorelength -br 128000 -if - -of "C:\Users\USER\Desktop\MeGUI Output\AUDIO.m4a"
--[Information] [04/04/18 00:38:16] Process started
--[Information] [04/04/18 00:38:16] Standard output stream
--[Information] [04/04/18 00:38:16] Standard error stream
So this is the log, do you see something weird?
Is it possible to copy a log of ffmpeg?
Old 4th April 2018, 05:42   #5  |  Link
hello_hello
Nothing that I can see.
-[NoImage] {
-[NoImage] }
The first quoted section shows MeGUI is downmixing with the c6_stereo() function, followed by Normalize(), and the second quoted section shows the c6_stereo() function, which seems normal.
0.2929 means the front left and surround left channels are being downmixed with a (roughly) 10.5dB volume reduction for each. The same applies to FR and SR.
0.2071 means the centre and LFE channels are being mixed together with a (roughly) 13.5dB reduction, then they're added to left and right. The upshot is, the centre and LFE channels have their volumes reduced by 3dB relative to the other channels, which is normal.
That's a fair volume reduction, but Normalize() will increase it again until the peaks are at maximum. Sometimes they're very close to maximum anyway (hence reducing the volume so much to prevent clipping when downmixing) and Normalize() will therefore not increase the volume much.
You could try importing the downmixed audio into Auidacity to see if it can be amplified without clipping, but you shouldn't be able to.
You can also try downmixing with one of the Pro Logic stereo options. They should sound the same as normal stereo but they don't include the LFE channel, which means the rest of the channels are mixed together at a slightly higher volume, and you might find the peaks are coming from a loud LFE channel, so Normalize() will have more effect without it. I never include the LFE channel when downmixing, but unfortunately there's no option to not include it when downmixing to normal stereo with MeGUI.
Add -report to the beginning of the command line and ffmpeg should save a log file.
I think it's likely ffmpeg isn't reducing the volume to prevent possible clipping (or maybe it uses Pro Logic downmixing by default?) but I've never used it for downmixing so I don't know how much the log file will tell you about it.
Old 4th April 2018, 09:01   #6  |  Link
tebasuna51
tebasuna51's Avatar
The ffmpeg log don't say the matrix used to downmix. In my test I found than use:
FL' = FL + 0.7*FC + 0.7*SL
FR' = FR + 0.7*FC + 0.7*SR
- A simple stereo downmix is used.
- The LFE is ignored (recommended).
- Don't prevent clip. Volume values until 2.4 can be obtained and all values over 1.0 are clipped.
The matrix used in MeGUI function c6_stereo is:
FL' = 0.2929*FL + 0.2071*FC + 0.2071*LFE + 0.2929*SL
FR' = 0.2929*FR + 0.2071*FC + 0.2071*LFE + 0.2929*SR
Is a matrix with normalized coeficients than can output a max volume value of 1.0 (without clip)
To avoid low volume values after mix is Normalized to obtain max volume without clip.
You can use BeHappy to downmix with more options to prevent the know problem of low volume dialogs.
For instance simple Stereo without LFE:
FL' = 0.3694*FL + 0.2612*FC + 0.3694*SL
FR' = 0.3694*FR + 0.2612*FC + 0.3694*SR
Or 'Night Mode' forcing Center channel:
FL' = 0.1875*FL + 0.625*FC + 0.1875*SL
FR' = 0.1875*FR + 0.625*FC + 0.1875*SR
Or 'Simple (F+C)':
FL' = FL + 0.7071*FC
FR' = FR + 0.7071*FC
Even you can make your script with the desired mix.
Old 4th April 2018, 18:11   #7  |  Link
mkver
With -loglevel debug or higher ffmpeg tells you the matrix used:
[Parsed_aresample_0 @ 0000000000191080] [SWR @ 00000000001a1000] Using fltp internally between filters
[Parsed_aresample_0 @ 0000000000191080] [SWR @ 00000000001a1000] Matrix coefficients:
[Parsed_aresample_0 @ 0000000000191080] [SWR @ 00000000001a1000] FL: FL:0.414214 FR:0.000000 FC:0.292893 LFE:0.000000 SL:0.292893 SR:0.000000
[Parsed_aresample_0 @ 0000000000191080] [SWR @ 00000000001a1000] FR: FL:0.000000 FR:0.414214 FC:0.292893 LFE:0.000000 SL:0.000000 SR:0.292893
[Parsed_aresample_0 @ 0000000000191080] ch:6 chl:5.1(side) fmt:fltp r:48000Hz -> ch:2 chl:stereo fmt:s16 r:48000Hz
mkver is offline   Reply With Quote
Old 4th April 2018, 21:09   #8  |  Link
tebasuna51
tebasuna51's Avatar
You are right, using -loglevel debug the matrix is showed, but the mine confirm my first post with clip problems:
[auto_resampler_0 @ 0000000000440a40] [SWR @ 0000000002b21140] Using fltp internally between filters
[auto_resampler_0 @ 0000000000440a40] [SWR @ 0000000002b21140] Matrix coefficients:
[auto_resampler_0 @ 0000000000440a40] [SWR @ 0000000002b21140] FL: FL:1.000000 FR:0.000000 FC:0.707107 LFE:0.000000 BL:0.707107 BR:0.000000
[auto_resampler_0 @ 0000000000440a40] [SWR @ 0000000002b21140] FR: FL:0.000000 FR:1.000000 FC:0.707107 LFE:0.000000 BL:0.000000 BR:0.707107
Old 5th April 2018, 13:00   #9  |  Link
hello_hello
Is the difference in log files the difference between using -ac 2 and the audio resampler function, whatever the command line for using it might be? It appears the audio resampler has some sort of clipping prevention (rematrix_maxval) although by the description I assume it performs some sort of peak limiting rather than peak normalising.
Old 5th April 2018, 13:20   #10  |  Link
mkver
1. If I use -ac2 the only difference I get is that it now reports "auto_resampler", not the explicitly called "Parsed_aresample":
[auto_resampler_0 @ 0000000000169a00] [SWR @ 0000000000169c40] Using fltp internally between filters
[auto_resampler_0 @ 0000000000169a00] [SWR @ 0000000000169c40] Matrix coefficients:
[auto_resampler_0 @ 0000000000169a00] [SWR @ 0000000000169c40] FL: FL:0.414214 FR:0.000000 FC:0.292893 LFE:0.000000 SL:0.292893 SR:0.000000
[auto_resampler_0 @ 0000000000169a00] [SWR @ 0000000000169c40] FR: FL:0.000000 FR:0.414214 FC:0.292893 LFE:0.000000 SL:0.000000 SR:0.292893
[auto_resampler_0 @ 0000000000169a00] ch:6 chl:5.1(side) fmt:fltp r:48000Hz -> ch:2 chl:stereo fmt:s16 r:48000Hz
2. I use an input file that ffmpeg detects as 5.1(side), whereas your file has back channels according to ffmpeg. I don't think that this is the reason behind the difference, but it should be noted. My ffmpeg has been built less than two weeks ago, when has yours?
3. My first test was with using aresample like this: -filter:a aresample=ocl=stereo
Old 5th April 2018, 15:49   #11  |  Link
tebasuna51
tebasuna51's Avatar
EDIT: I used only the parameter -ac 2 to let ffmpeg select the default downmix...
We can also instruct ffmpeg with the desired downmix using a filter, for instance:
-af "pan=stereo|FL < FL + .7FC + .3BL + .3SL + 0.2LFE|FR < FR + .7FC + .3BR + .3SR + 0.2LFE"
But the problem is always the same, with normalized coeficients => low volume, with big coeficients => more volume but clip risk.
Old 5th April 2018, 18:33   #12  |  Link
hello_hello
Could the type of audio being downmixed make a difference? What sort of audio were you using as the source?
AC3 has rules about how 5.1ch is supposed to be downmixed to stereo, and if ffmpeg is following those rules when decoding and downmixing, it'd probably apply a volume reduction. I think it's around 7.5dB over-all, which is roughly what it seems to be doing in your case.
I wonder if ffmpeg might downmix different sources differently? I might play around with it tomorrow if I get a chance. I've not downmixed with ffmpeg before.
Old 5th April 2018, 18:59   #13  |  Link
mkver
My source was a 5.1 ac3 file (which ffmeg treats as 5.1(side) -- ac3 only has one 5.1 channel layout); I just decoded said file to a 5.1(side) wav file to get rid of any special information for downmixing. And if I downmix said wav file, I get exactly the same coefficients as before. If I decode the ac3 and resample to 5.1 (with back channels), the side channels are simply copied to the back channels (and the other channels stay the same). If I downmix said file to stereo, I get the same coefficients as in the 5.1(side) case (just with BL/BR instead of SL/SR). So I can only think of two more possibilities: tebasuna51 uses a different ffmpeg version or he uses a file with embedded downmix coefficients that are honored by ffmpeg.
Old 5th April 2018, 22:58   #14  |  Link
doomleox999
Wow you guys know a lot about this, I can't understand everything you are talking about (specially "clipping") but I think that MeGUI DOES something different than ffmpeg and that's the reason why they deliver different results. What is not clear for me is if you can instruct MeGUI to (forgive my ignorance) downmix just like ffmpeg does, do I have to add some lines to the script?
Old 6th April 2018, 11:22   #15  |  Link
tebasuna51
tebasuna51's Avatar
AC3 has rules about how 5.1ch is supposed to be downmixed to stereo, and if ffmpeg is following those rules when decoding and downmixing...
You are right, in the header of AC3 there are fields:
Center mix level
    0 = -3.0 dB (default in Aften encode, recommended)
    1 = -4.5 dB (default in ffmpeg encode)
    2 = -6.0 dB
Surround mix level
    0 = -3 dB (default in Aften encode)
    1 = -6 dB (default in ffmpeg encode, recommended)
    2 = 0
than can be used by ffmpeg, but the source of doomleox999 is a sixchannels.aac, and ADTS aac headers don't have that fields.
I used wav input files to let free ffmpeg downmix.
BTW the question is what downmix matrix use, we can force to ffmpeg use any custom matrix (-af "pan=stereo...") and we can use any downmix script with AviSynth.
When try to play with only 2 speakers we can't obtain the same volume than using 6 speakers, we need choice between less volume (normalized coeficients) or distort high volumes (signal clip).
What is clip? (short explain)
Audio samples can be stored in float formats without limits of volume.
But always must be converted to int samples (at least at end of digital-analog conversion).
And float values greater than 1.0 are truncated to 1.0 and asigned to max integer allowed.
Values greater than 1.0 are lossed, in a audio editor show like a clip (red values in image):
Old 6th April 2018, 12:15   #16  |  Link
tebasuna51
tebasuna51's Avatar
...if you can instruct MeGUI to downmix just like ffmpeg does...?
Yes, but what ffmpeg do?
Y tried with a sixchannels.aac and now uses:
[auto_resampler_0 @ 0000000002bf5140] [SWR @ 0000000002bf5240] Matrix coefficients:
[auto_resampler_0 @ 0000000002bf5140] [SWR @ 0000000002bf5240] FL: FL:0.414214 FR:0.000000 FC:0.292893 LFE:0.000000 BL:0.292893 BR:0.000000
[auto_resampler_0 @ 0000000002bf5140] [SWR @ 0000000002bf5240] FR: FL:0.000000 FR:0.414214 FC:0.292893 LFE:0.000000 BL:0.000000 BR:0.292893
or:
FL' = 0.414214*FL + 0.292893*FC + 0.292893*SL
FR' = 0.414214*FR + 0.292893*FC + 0.292893*SR
Is a normalized mix without clip, the difference with MeGUI is don't use the LFE channel (like is recommended) but is not a big diference in volume:
Front coeficient 0.4 versus 0.3
Center coeficient 0.3 versus 0.2
And MeGUI do a last Normalize to obtain max volume without clip, ffmpeg don't normalize at end.
You can use the same mix and Normalize at end with this script:
ClearAutoloadDirs()
a=LWLibavAudioSource("C:\Users\USER\Desktop\MeGUI Output\AUDIO.aac")
#  lf = GetChannel(a, 4)
  fl_sl = MixAudio(fl, sl, 0.414214, 0.292893)
  fr_sr = MixAudio(fr, sr, 0.414214, 0.292893)
  l = MixAudio(fl_sl, fc, 1.0, 0.292893)
  r = MixAudio(fr_sr, fc, 1.0, 0.292893)
  MergeChannels(l, r)
Normalize()
return last
Old 7th April 2018, 06:51   #17  |  Link
doomleox999
So I just load that script in "Audio Input" in MeGUI? Is that how it works?
By the way, I was testing 6ch to stereo again with ffmpeg and the same file and something new happened at the end of the encode. To be honest I'm not sure if it happened everytime before, I'm talking about those red lines at the bottom:
Old 7th April 2018, 08:31   #18  |  Link
tebasuna51
tebasuna51's Avatar
Yes, put the megui log to confirm.
ffmpeg show that message when Noise scalefactors are greater than 30.
Maybe it is a encoder bug or a file corruption, it don't seems critical.
Old 9th April 2018, 11:54   #19  |  Link
doomleox999
So the noise scalefactors thing from ffmpeg is not important? Even if they are red? (I sound childish haha but if the program use red I'd guess is for a reason)
I get the same result with the custom script, just to be sure, this is where I have to load it right?
Old 9th April 2018, 16:02   #20  |  Link
tebasuna51
tebasuna51's Avatar
I say not critical because is a problem in the source file than can't be corrected. If sound bad at some point we can do nothing, maybe find other source file.
There are other message (yelow) to suspect over the encoder than make this aac file.
Yes.
BTW the in the Config Encoder Settings you can't use a preset for multichannel if you downmix to stereo.
For a stereo with a bitrate near 128 Kb/s (absolutely not recomended for multichannel) you can use a VBR with Q = 0.4
Also if downmix and Normalize are already in the .avs don't repeat them, use some config like:
6channels, ffmpeg, megui, stereo
