16th December 2016, 12:19 | #21 | Link | |
Professional Code Monkey
16th December 2016, 13:41 | #22 | Link |
Some hints assuming you use Visual Studio
build just the plugin with debug info and with no optimizations set breakpoints to all major functions specify launch options for debugging (application and command line)
VirtualDub2 |
16th December 2016, 14:21 | #23 | Link |
I'm Siri
rgblab = new long[16777216]; labrgb = new long[16777216]; use smart pointers if you want some kind of automatic GC for C++ like in Java or C# and both arrays do not feature a runtime determined length, simply make them static if worrying about blowing the stack up Code:
static int32_t rgblab[16777216]; static int32_t labrgb[16777216]; |
16th December 2016, 14:58 | #24 | Link |
I'm Siri
or a bit more organized with C++ 14..
#include <cstdint> auto operator""ElementsLUTTable(size_t length) { struct LUTTable final { int32_t *RGBToLab = nullptr; int32_t *LabToRGB = nullptr; LUTTable(size_t length = 0) { RGBToLab = new int32_t[length]; LabToRGB = new int32_t[length]; } LUTTable(const LUTTable &) = delete; LUTTable(LUTTable &&obj) { RGBToLab = obj.RGBToLab; LabToRGB = obj.LabToRGB; obj.RGBToLab = nullptr; obj.LabToRGB = nullptr; } auto &operator=(const LUTTable &) = delete; auto &operator=(LUTTable &&obj) { if (this != &obj) { RGBToLab = obj.RGBToLab; LabToRGB = obj.LabToRGB; obj.RGBToLab = nullptr; obj.LabToRGB = nullptr; } return *this; } ~LUTTable() { delete[] RGBToLab; delete[] LabToRGB; } }; return LUTTable(length); } auto table = 16777216ElementsLUTTable; Last edited by feisty2; 16th December 2016 at 15:00. |
16th December 2016, 17:03 | #25 | Link | |
Beyond Kawaii
...desu! |
16th December 2016, 17:18 | #26 | Link |
There was nothing wrong about labrgb tables except missing delete/wrong singleton. God idea to fix just that issue. Tables must not be static (they take space).
VirtualDub2 |
16th December 2016, 17:39 | #27 | Link | |||
I'm Siri
#include <cstdint> #include <cstdlib> #include <iostream> auto operator""ElementsLUTTable(size_t length) { struct LUTTable final { int32_t *RGBToLab = nullptr; int32_t *LabToRGB = nullptr; LUTTable(size_t length = 0) { RGBToLab = new int32_t[length]; LabToRGB = new int32_t[length]; } LUTTable(const LUTTable &) = delete; LUTTable(LUTTable &&obj) { RGBToLab = obj.RGBToLab; LabToRGB = obj.LabToRGB; obj.RGBToLab = nullptr; obj.LabToRGB = nullptr; } auto &operator=(const LUTTable &) = delete; auto &operator=(LUTTable &&obj) { if (this != &obj) { RGBToLab = obj.RGBToLab; LabToRGB = obj.LabToRGB; obj.RGBToLab = nullptr; obj.LabToRGB = nullptr; } return *this; } ~LUTTable() { delete[] RGBToLab; delete[] LabToRGB; } }; return LUTTable(length); } auto table = 16777216ElementsLUTTable; auto main()->int { table.LabToRGB[123] = 123456; std::cout << table.LabToRGB[123] << std::endl; system("pause"); } Quote:
auto value = 1.234; auto val = 123; user defined literals (operator""xxx) have been introduced to C++ since C++11, which makes such stuff Code:
auto cval = 3 + 1.123i; //operator""i auto table = 16777216ElementsLUTTable; //operator""ElementsLUTTable Quote:
16th December 2016, 17:45 | #28 | Link |
Posts: n/a
LUTTable(LUTTable &&obj) { RGBToLab = obj.RGBToLab; LabToRGB = obj.LabToRGB; obj.RGBToLab = nullptr; obj.LabToRGB = nullptr; } Code:
auto &operator=(LUTTable &&obj) { if (this != &obj) { RGBToLab = obj.RGBToLab; LabToRGB = obj.LabToRGB; obj.RGBToLab = nullptr; obj.LabToRGB = nullptr; } return *this; } |
16th December 2016, 17:51 | #29 | Link | |
I'm Siri
LUTTable(const LUTTable &) // copy constructor LUTTable(LUTTable &&) // MOVE constructor (since C++11) |
17th December 2016, 02:29 | #31 | Link | |
I could add a main function, but I would assume that I would also have to pass data to the functions like it would when the library is in use, otherwise how could I find the problem. when I read about debugging dll libraries on microsoft website they suggest debugging the host application. So I am currently installing Qt5, and trying to get everything in place to debug VSedit while its using the GradCurve plugin. I just hope I am barking up the right tree here, and not off in left field. EDIT: I updated the github https://github.com/jieiku/GradCurve/ Removed variables left behind from vdub specific stuff as well as variables from starting off with HolyWu's AddGrain filter. There is more cleanup to do once I have this working. Last edited by xekon; 3rd December 2021 at 07:32. |
17th December 2016, 02:36 | #33 | Link |
You need to start the host application but you dont have to compile and debug it, the debugger kicks in once your dll is loaded.
VirtualDub2 |
17th December 2016, 02:38 | #35 | Link |
Btw, concerning lab mode
AFAIK is was both slow and low quality, maybe just worth removing anyway.
VirtualDub2 |
17th December 2016, 02:39 | #36 | Link |
I'm Siri
Plus it's "delete[]" for arrays...
not sure if "delete array" will still lead to memory leak (only the first element got deleted) Edit: just googled about that and "delete" works in your case also, cuz both arrays are an array of the basic data type (no destructor). But delete[] makes more sense, so use that instead Edit2: I'm talking about line 673 and line 674 in ur source code Last edited by feisty2; 17th December 2016 at 03:02. |
17th December 2016, 03:09 | #37 | Link | |
and thank you feisty2, i switched it to using brackets. I assumed there were problems other than the memory leak, because when I build under linux vsedit still crashes after correcting the memory leaks, im building a dll under windows and going to try vsedit under windows to see if I still crash. it sounds like the plugin is functioning for you guys, so something must be up with my build environment. |
17th December 2016, 06:52 | #39 | Link |
ah, thanks for taking a look for me. the second picture you posted is where my vsedit crashed I believe. I will keep trying to figure out the reason its crashing. very little of the code was actually written by me, I migrated the code from the vdub c++ filter. I will probably need to get a better idea of how gradation curves is supposed to work before i can fix the problem.
17th December 2016, 16:07 | #40 | Link |
unsigned int
Is d.filename initialised with zeroes? If not, strcat may find a zero past its end. Use the "n" versions of string functions if possible, i.e. strncat. Although I don't see why this isn't str(n)cpy. And since you're using C++ you might as well use std::string.
Are you sure you want those global variables in your library? As far as I can tell, you could call ImportCurve and PreCalcLut from GradCurveCreate. They don't seem to use any data from the filter's input frames. It also looks like oldr, oldg, oldb, medr, medg, and medb can be local variables. Then you can switch to fmParallel. Your filter accepts integer formats, but it assumes the frames always contain float pixels. If you test your filter with integer clips, the processing loop will inevitably read and write past the end of the frame.
Buy me a "coffee" and/or hire me to write code! Last edited by jackoneill; 17th December 2016 at 16:14. |
color correct, curves, gradation, vapoursynth, virtualdub |
