Old 19th October 2015, 15:29   #1  |  Link
serhannn
FFmpeg error while encoding raw video into H.264
I use the following FFmpeg command to encode the well-known Akiyo sequence from raw `y4m` format with H.264:
    ffmpeg -f rawvideo -pix_fmt yuv420p -s:v 352x288 -r 30 -i akiyo_cif.y4m -c:v libx264 akiyo_cif.mp4
However, the encoded video I get is distorted, i.e. there is horizontal panning/sliding of frames and the colors are not accurate. FFmpeg yields the following error:
    [rawvideo @ 0x7f5e7c57b140] Invalid buffer size, packet size 1844 < expected frame_size 152064
    Error while decoding stream #0:0: Invalid argument
I don't understand the error. I provided the CIF resolution (352x288) and frame rate (30 fps) as input, so there shouldn't be anything wrong with those. What could be the source of this problem?
serhannn is offline   Reply With Quote
Old 19th October 2015, 17:18   #2  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
rawvideo
y4m is not raw video - it has headers. You should just omit everything,
ffmpeg -i akiyo_cif.y4m -c:v libx264 akiyo_cif.mp4
vivan is offline   Reply With Quote
Old 20th October 2015, 08:15   #3  |  Link
serhannn
This solved my problem. I didn't know that y4m was not raw video. Thank you!
ffmpeg, h264, yuv
