Old 7th May 2014, 18:08   #1  |  Link
pcroland
Mkvmerge error.
A wanted to merge these files:
01.h264
01.ac3 (Hungarian)
01.aac (English)
01.srt (English)
I merged these files with mkvmerge like that:
mkvmerge -o 01.mkv --language 0:eng 01.h264 --language 0:hun 01.ac3 --language 0:eng 01.aac --default-track 0:no --language 0:eng 01.srt
This is the mediainfo output:
General
Unique ID                                : 198539730609906208309661724493362967467 (0x955D5C79C7BF50F52B3116D1D5C733AB)
Complete name                            : 01.mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 170 MiB
Duration                                 : 22mn 48s
Overall bit rate                         : 1 042 Kbps
Encoded date                             : UTC 2014-05-07 16:58:10
Writing application                      : mkvmerge v6.9.1 ('Blue Panther') 64bit built on Apr 18 2014 18:34:40
Writing library                          : libebml v1.3.0 + libmatroska v1.4.1
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 16 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 22mn 48s
Width                                    : 720 pixels
Height                                   : 404 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 fps
Bit depth                                : 8 bits
Scan type                                : Progressive
Writing library                          : x264 core 142 r2431 ac76440
Language                                 : English
Default                                  : Yes
Forced                                   : No
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio #1
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : A_AC3
Duration                                 : 22mn 48s
Bit rate mode                            : Constant
Bit rate                                 : 192 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Stream size                              : 31.3 MiB (18%)
Language                                 : Hungarian
Default                                  : Yes
Forced                                   : No
Audio #2
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : A_AAC
Duration                                 : 22mn 48s
Language                                 : English
Default                                  : No
Forced                                   : No
Text
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Language                                 : English
Default                                  : No
Forced                                   : No
So the .mkv file contains only one subtitle, but when I play the video with VLC I see two subtitles: http://i.imgur.com/kArFnwf.png I send the file to my friend and he seen 6 subtitles.
Is this a mkvmerge bug? :-/
pcroland is offline   Reply With Quote
Old 7th May 2014, 20:05   #2  |  Link
Asmodian
More likely it is a bug in VLC (and whatever your friend is using), what does it look like in MPC-HC?
Old 7th May 2014, 20:37   #3  |  Link
pcroland
I'm not able to use MPC-HC on Ubuntu But this is the only file which is buggy, other files with the same structure are okay in VLC. I think this is not a VLC bug :-)
Old 10th May 2014, 01:37   #4  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Your player is picking up external subtitles from somewhere else.
matroska, mkv, mkvmerge, vlc
