3rd April 2014, 13:55 | #13021 | Link |
To all having problems with crashing client. Does encoding client crash if you change affinity to single core? (I use Process Explorer)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 3rd April 2014 at 13:59. |
3rd April 2014, 13:58 | #13022 | Link |
yes if you mean encoding with x265. Unfortunately x265 still does not have psy-rdo.
4th April 2014, 16:22 | #13023 | Link |
hi atak, what should i do when get error like this:
encoded 165892 frames, 9.81 fps, 661.71 kb/s The batch file cannot be found. 'C:\Temp\RipBot264temp\Job3\Job3_MuxFiles.cmd' is not recognized as an internal or external command, operable program or batch file. 'C:\Temp\RipBot264temp\Job3\Job3_RemoveEmptyFolders.cmd' is not recognized as an internal or external command, operable program or batch file. my vps wind serv 2012, please help, thanks |
6th April 2014, 17:02 | #13024 | Link |
I tried this and each time the encodingclient run it goes back to use any/all processors. so I found this utility: http://www2.robpol86.com/guides/ImageCFG/
I used it and we will now let it run and see if it crashes... will keep you posted... |
13th April 2014, 10:18 | #13027 | Link |
Good! Atleast we have workaround
13th April 2014, 22:10 | #13029 | Link |
how many encodes have made without crash?
19th April 2014, 07:37 | #13030 | Link |
Good Morning everybody!
Discovered DE yesterday and i have admit it works REALLY fine! @Atak: one questions concerning DE: i've seen that you are creating junks of about 1 minute in length. In terms of overhead (CPU efficiency), wouldn't it be better to create a bit longer (5min, 10min) junks? Thanks once again for the great piece of software! nice easter to everybody! yours, Juergen |
19th April 2014, 11:45 | #13031 | Link |
nope. Longer chunks will reduce server usage at the end of the encoding process. 7 servers will stay idle while last one is still encoding last long chunk. On other hand too small chunks may increase file size (more key frames) and reduce overall encoding speed (starting process can steal few seconds). summary 1 min chunk is optimal.
24th April 2014, 01:55 | #13033 | Link |
I just ripped Thor: The Dark World and I noticed it missed the forced subs. I then ran it through handbrake and it correctly found the forced subs. I noticed handbrake found an additional playlist (810) which ripbot did not. That additional playlist was the correct one in handbrake. The other two playlists which matched ripbots did not have the forced subs. There must have been a navigational command or something in that playlist noting to include the forced subs. Anyone have any idea why ripbot would miss that playlist? Let me know if additional details are needed. Thanks
24th April 2014, 14:24 | #13035 | Link |
I have checked all the playlists ripbot provided. I believe handbrake gave playlists 800, 801 & 810 (among a bunch other small ones). Ripbot had 800 & 801 (810 was not included). 810 worked correctly in handbrake to include the forced subs. 800 and 801 in handbrake and ripbot did not include the subs. As i mentioned before, i think 810 must have some command to include the subs. The forced subs are in a seperate subtitle track with no forced flags.
24th April 2014, 16:30 | #13036 | Link |
What I do is select the most likely playlist and then let RipBot demux and analyze. I alway pick all subtitles. When that phase finishes if RipBot has identified a Forced English subtitle I select it. If no Forced subs are identified I go to the Job(x) folder in the RipBot temp folder with BDSUP2SUB and look at each of the English subtitles. In the case of Thor: The Dark World you will see that one of the English sub tracks has many fewer subs than the others. You can also see what the subs are in this program. I just selected that track as the sub track to include in the final output and it worked fine. As you mentioned this is one of the few discs I see lately that do it this way.
24th April 2014, 17:09 | #13037 | Link |
Jwjohnson, thanks for that info. Thats exactly what i started doing after i realized what happened with Thor: The Dark World. Before i always counted on ripbot on finding the forced subs because it typically does a fantastic job. I just wonder why ripbot couldnt find that playlist.
27th April 2014, 16:19 | #13038 | Link | |
I got the same problem with a clip with the Codec: MPEG-H Part2/HEVC (H.265) (hevc) (from the media info page of VLC) Note: Other clips with the same codec worked fine. |
27th April 2014, 21:35 | #13039 | Link |
have you tried remuxing with latest mkvmerge?
