30th January 2007, 17:08 | #161 | Link |
Didée Fan
bypass: Does not Deinterlace.
Linear interpolation: Works but has combing artifact, and Rippling line Effect. Linear blending: Works but removes too much detail. cubic interpolation: Works but has combing artifact, and Rippling line Effect. cubic blending: Works median: Works but has Rippling line Effect. tomsmocomp: Works but has Rippling line Effect. Latest Avisynth version does not have rippling line artifact. dgbob: Only first mode works. Has combing artifact, and Rippling line Effect. framerate doubler: Does not Deinterlace. ffmpeg deinterlacer: Works but has slight combing artifact, and Rippling line Effect. 5 tap lowpass: Works. kernal deinterlacer: Does not Deinterlace. kernal bob: Does not Deinterlace. Here's a picture of Tomsmocomp version 0.0.1.8 used in FFDshow Avisynth, tomsmocomp(1,5,1). No Rippling Last edited by Jeremy Duncan; 30th January 2007 at 17:21. |
31st January 2007, 02:51 | #162 | Link |
XviD User
libmpeg2 seems to decode DVD's just fine for me but the problem comes in when seeking. I get random crashes/lockups on DVD's when seeking or navigating the DVD menu.
DFI NF4 SLI Expert | Opteron 165 CCBBE 0616 XPMW (9x325HTT=2.9Ghz) | 2x1GB G.Skill HZ (3-4-4-8-12-16-2T) | LG 62L DVD/CD | Geforce 7300GT | All SATA | Antec 650 Trio PSU | XP SP2 |
1st February 2007, 04:29 | #164 | Link |
there is something very wrong with Audio Decoder.
If you open it up (the gui I mean) and enable only the Mixer, set Speaker Configuration to 2/0 (this far everything works fine), but now enable the LFE checkbox and your system will reboot once you try to play back a movie. Setting Speakers to 2/1 fixes it. But still even if 2/0 is a wrong setting, the computer shouldn't reboot. (gray out LFE checkbox in unsupported settings maybe?) ffdshow 844, xp sp2 + haali splitter (xvid + mp3 input)
Geforce GTX 260 Windows 7, 64bit, Core i7 MPC-HC, Foobar2000 Last edited by lexor; 1st February 2007 at 04:49. |
1st February 2007, 10:50 | #165 | Link |
request: color space "adj"
Is it possible to include option to disable adjusting color space in ffdshow? I would like to have it in native scale as it was from decoder without any recalculations. It shouldn't be much work. Regards Piotr |
1st February 2007, 11:40 | #166 | Link |
Revision 864
H.264 MBAFF hardware deinterlacing support. It was a request from stream47. Samples originally posted by stream47 (In Japanese). English translation MPEG4-ASP hw-deinterlacing is supported only by libavcodec, not xvid. |
1st February 2007, 12:06 | #168 | Link | |
Angel of Night
lexor, either disable reboot on bug check, or use Event Viewer (eventvwr.msc) to determine the probable cause of the fault. It'll give you a something.sys, you might have to google around to find out just which driver that is. Awesome, getting AVIVO and Purevideo to work should be much simpler now. Last edited by foxyshadis; 1st February 2007 at 12:08. |
1st February 2007, 13:02 | #169 | Link | |
Life's clearer in 4K UHD
EDIT: I've only been banging on about the need to provide proper support for decoding interlaced MPEG-4 Part-2 sources for years (plain old "Bob" would have done in the meantime). I wonder if this move has been promted by DivX's recent announcement regarding their 6.5 direct-show decoder offering support too?!
1st February 2007, 14:53 | #171 | Link |
20-35 a win for Revolver.
Hi world ...
First : thanks to the new dev team for the work ! FFDShow reborn is really a great news !!! Second, where can I find a list of each FFDShow's filter whith the color space allowed by the filter please ? ... ( This to avoid the YV12 conversion done by some filters ... ) Thanks ! Seb |
1st February 2007, 15:42 | #172 | Link |
ffdshow user
ffdshow
I can't play .evo files on my computer properly.
Tested with AMD x2 + 2gb DDR2 + 7900 + ffdshow + MPC. No Open-Source solution can handle it. Maybe someday libavcodec h264 decoder is going to be multithreaded. ftp://mplayerhq.hu/MPlayer/samples/e...%20Trailer.EVO |
1st February 2007, 16:03 | #174 | Link |
Check out this thread for info about .evo:
http://forum.doom9.org/showthread.php?t=120652
MPC-HC 2.2.1 |
1st February 2007, 16:18 | #175 | Link | |
1st February 2007, 23:23 | #178 | Link |
Angel of Night
Scoty, see this thread for starters. There is no one setting that will magically be best for everything, though, and it's pretty cpu intensive.
2nd February 2007, 00:06 | #179 | Link |
Feature request
Would it be possible to make the priority over which type of subtitle gets loaded by default configurable? For example, like a drop-down box where you can choose between the subtypes like SRT, VOB, SUB etc.
2nd February 2007, 14:37 | #180 | Link |
Are there any "Revision 864" builds (with interlaced support) available yet?
The most up-to date builds on SourceForge stop at 30 Jan 07. Cheers
