Old 2nd April 2007, 23:14   #981  |  Link
Dr Pizza
Dr Pizza's Avatar
Originally Posted by drevil_xxl View Post
64-bit compile:
.\src\TffDecoder.cpp(1511) : error C3861: 'SetThreadIdealProcessor': identifier not found
I'm using the Vista SDK's and that's working for me; that error suggests that _WIN32_WINNT isn't being set correctly for you (that function prototype has a guard around it requiring NT4 and up).
C:\Program Files\Microsoft Visual Studio 8\VC\include\limits.h(42) : warning C4005: 'INT_MIN' : macro redefinition
Harmless, albeit irritating. Doesn't seem to be 64-bit specific?
Creating library Releasex64/ff_x264.lib and object Releasex64/ff_x264.exp
predict-c.obj : error LNK2001: unresolved external symbol predict_16x16_p_core_mmxext
predict-c.obj : error LNK2001: unresolved external symbol predict_8x8_ddl_mmxext
predict-c.obj : error LNK2001: unresolved external symbol predict_16x16_dc_top_mmxext
predict-c.obj : error LNK2001: unresolved external symbol predict_8x8_dc_left_mmxext
predict-c.obj : error LNK2001: unresolved external symbol predict_16x16_v_mmx
predict-c.obj : error LNK2001: unresolved external symbol predict_8x8_v_mmxext
predict-c.obj : error LNK2001: unresolved external symbol predict_4x4_vl_mmxext
predict-c.obj : error LNK2001: unresolved external symbol predict_8x8_vr_core_mmxext
predict-c.obj : error LNK2001: unresolved external symbol x264_intra_sa8d_x3_8x8_core_sse2
predict-c.obj : error LNK2001: unresolved external symbol predict_8x8_dc_top_mmxext
predict-c.obj : error LNK2001: unresolved external symbol predict_8x8_vl_sse2
predict-c.obj : error LNK2001: unresolved external symbol predict_8x8_ddl_sse2
predict-c.obj : error LNK2001: unresolved external symbol predict_8x8c_dc_core_mmxext
predict-c.obj : error LNK2001: unresolved external symbol predict_8x8c_v_mmx
predict-c.obj : error LNK2001: unresolved external symbol predict_8x8_ddr_sse2
predict-c.obj : error LNK2001: unresolved external symbol predict_16x16_dc_core_mmxext
predict-c.obj : error LNK2001: unresolved external symbol predict_4x4_ddl_mmxext
predict-c.obj : error LNK2001: unresolved external symbol predict_8x8c_p_core_mmxext
predict-c.obj : error LNK2001: unresolved external symbol predict_8x8_dc_mmxext
This means that the asm has failed to build.
Dr Pizza is offline   Reply With Quote
Old 2nd April 2007, 23:16   #982  |  Link
Dr Pizza
Dr Pizza's Avatar
Please test the VFW interface of ffdshow 64-bit. I am curious if my workaround is working.
How would one go about doing that?
What is the workaround?
Old 3rd April 2007, 00:28   #983  |  Link
clsid
The workaround of putting it in the appdir.
You should be able to test if it works with 64-bit VirtualDub:
http://virtualdub.sourceforge.net/
MPC-HC 2.2.1
Old 3rd April 2007, 01:23   #984  |  Link
zambelli
Doom9ing since 2001
zambelli's Avatar
Originally Posted by siim04 View Post
You can switch between 64-bit and 32-bit WMP in Windows XP (I think it worked similar to Vista version). I tried using 64-bit WMP, but had to change back to 32-bit version as most codecs were not available.
My point was that WMP11 is only available in 32-bit version for XP. The version marked 64-bit is meant to be installed on XP x64, but is actually just the same 32-bit version for most part. I think the only 64-bit parts of that package are some portable device drivers and the WMP shell object. The only true 64-bit WMP11 is in Vista x64.
Also Windows Media Encoder is only 64-bit on Windows XP x64, which means that I can't use it for converting files either (and I really would like to compress my mpeg1, mpeg2 and xvid videos as they are taking up too much space).
Actually, WME9 32-bit installs on XP x64 just fine.
Anyway, this is all off-topic to this thread.
zambelli is offline   Reply With Quote
Old 3rd April 2007, 01:40   #985  |  Link
Dr Pizza
Dr Pizza's Avatar
The ExpandConstant thing you suggested doesn't seem to work; it's not expanding it (so my registry is getting stuff that says literally ExpandConstant in it). However, even with that changed (so it puts the right strings into the registry) vdub is claiming to be unable to find a suitable VFW codec. It doesn't look like it's even trying to load ff_vfw.dll, in fact; using depends to profile vdub shows no attemp to load the .dll.
Old 3rd April 2007, 06:43   #986  |  Link
Jeremy Duncan
Didée Fan
Jeremy Duncan's Avatar
Can somebody add Leak's Patch to Drevil's and XXL's FFDshow builds.
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity.
Jeremy Duncan is offline   Reply With Quote
Old 3rd April 2007, 14:48   #987  |  Link
clsid
Split personality
MPC-HC 2.2.1
Old 3rd April 2007, 15:04   #988  |  Link
clsid
Spaces in the path cause problems. Hence the usage of GetShortName. Try if this works:
[Registry]
Root: HKLM; Subkey: SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32; ValueType: string; ValueName: VIDC.FFDS; ValueData: {code:GetVFWLocation|};  Flags: uninsdeletevalue; Components: ffdshow\vfw
[C0de]
function GetVFWLocation(dummy: String): String;
begin
  Result := GetShortName(ExpandConstant('{app}\ff_vfw.dll'));
end;
MPC-HC 2.2.1
Old 4th April 2007, 09:40   #989  |  Link
haruhiko_yamagata
Originally Posted by Peuj View Post
I don't know if it's ffdshow issue but I have a problem with this mov file: http://www.jeuxvideo.fr/telecharger-...lay-43971.html
I use the build ffdshow_rev1082_20070328_clsid.exe and the latest MPC version compiled by drevil_xxl.
When I play the video everything is perfect excepted that I don't have sound at all and no error message from MPC.
It's like there is no audio stream.
Does somebody know what can be the problem?
Thanks
8KB/s for 360MB. I cannot download.
Please use faster file sharing service.
[ Download ffdshow | Wiki ]
haruhiko_yamagata is offline   Reply With Quote
Old 4th April 2007, 13:47   #990  |  Link
siim04
On my PC WME9 32-bit says that the machine type is not supported and won't install.
On the bright side. I tested the x64 version of ffdshow tryouts and it worked well (at least with WME x64, so it should work with graphedit as well).
Thank you for the x64 version!
siim04 is offline   Reply With Quote
Old 4th April 2007, 14:08   #991  |  Link
Peuj
Peuj's Avatar
Hi, thanks for looking at my problem.
I don't have problem to download the video maybe there was too much download when you have tried?
Anyway I have upload the file on http://www.megaupload.com/fr/?d=0O31ORW2
If you know a faster file sharing service let know I will upload the file on it.
Here's the information about the file:
Format : QuickTime
Format/Info : Original Apple specifications
Format/Family : MPEG-4
File size : 360 MiB
PlayTime : 1mn 45s
Bit rate : 29 Mbps
StreamSize : 4.57 MiB
Encoded date : UTC 2007-03-27 01:17:32
Tagged date : UTC 2007-03-26 16:39:21
Video #0
Codec : Sorenson 3
Codec/Info : Sorenson Media Video 3 (Apple QuickTime 5)
PlayTime : 1mn 45s
Bit rate : 28 Mbps
Width : 720 pixels
Height : 576 pixels
Aspect ratio : 5/4
Frame rate : 30.000 fps
Standard : PAL
StreamSize : 351 MiB
Encoded date : UTC 2007-03-26 16:17:32
Audio #0
Codec : PCM
PlayTime : 1mn 47s
Bit rate : 353 Kbps
Channel(s) : 2 channels
Sampling rate : 44 KHz
Resolution : 16 bits
StreamSize : 4.50 MiB
Thanks
Peuj is offline   Reply With Quote
Old 4th April 2007, 15:10   #992  |  Link
clsid
It is probably a splitter issue.
MPC-HC 2.2.1
Old 4th April 2007, 15:56   #993  |  Link
thuan
Same problem with the file as OP. mplayer can play the file fine. Here's the log
Playing infernal_video_1_-_gameplay_anglais_34539.mov.
Quicktime/MOV file format detected.
VIDEO: [SVQ3] 720x576 24bpp 30.000 fps 0.0 kbps ( 0.0 kbyte/s)
[ass] auto-open
[ass] Init
Fontconfig error: Cannot load default config file
[ass] Updating font cache.
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffsvq3] vfm: ffmpeg (FFmpeg Sorenson Video v3 (SVQ3))
Opening audio decoder: [alaw] aLaw/uLaw audio decoder
AUDIO: 44100 Hz, 2 ch, s16le, 705.6 kbit/50.00% (ratio: 88200->176400)
Selected audio codec: [ulaw] afm: alaw (uLaw)
AO: [dsound] 44100Hz 2ch s16le (2 bytes per sample)
Starting playback...
VDec: vo config request - 720 x 576 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
VO: [directx] 720x576 => 480x384 Planar YV12
A: 6.2 V: 6.2 A-V: 0.001 ct: 0.006 187/187 10% 19% 0.1% 0 0
thuan is offline   Reply With Quote
Old 4th April 2007, 16:19   #994  |  Link
clsid
The file plays correctly with the Nero Digital MP4/MOV parser (NDParser.ax). So this is NOT a ffdshow problem.
MPC-HC 2.2.1
Old 4th April 2007, 16:20   #995  |  Link
Peuj
Peuj's Avatar
So it's a MPC problem ?
Old 4th April 2007, 19:25   #996  |  Link
clsid
Yes, more specifically with the internal MP4/MOV splitter. Haali's splitter doesn't work at all with this file.
MPC-HC 2.2.1
Old 4th April 2007, 19:36   #997  |  Link
clsid
A lot of people are having trouble finding the 'presets' functionality in ffdshow because it is not in a very obvious place.
Some suggestions to improve the GUI:
* Rename 'Image settings' to 'Profiles/Presets'
* Rename 'Show/hide filters' to 'Filters' and remove the indentation.
* Remove indentations for 'Decoder options', 'Queue & misc' and 'Output'.
And for ffdshow audio decoder:
* Rename 'Audio settings' to 'Profiles/Presets'.
* Rename 'Show/hide filters' to 'Filters' and remove indentation.
* Remove indentation for 'Output'.
MPC-HC 2.2.1
Old 4th April 2007, 21:54   #998  |  Link
chros
chros's Avatar
@Kado
I'm debuging Winamp plugin feature. ffdshow's code around there is not written very nicely, as is unusual with Milan. I have fixed some (not commited yet), but Multiple-DSP Stacker still seems to be incompatible with ffdshow. I'm thinking of excluding it. Do you have any other such plugins?
Thanks for this act! I have asked about a month ago about the new DFX plugin (ver. 8.x) which is able to connect to multichannel audio (it works in winamp), but not working in ffdshow !
Can you do something about it ? (dts, aac, ac3, etc.)
Thank you !
Old 5th April 2007, 15:53   #999  |  Link
vlada
H, I'd like to report some problems with Aspect Ratio of MPEG-4 ASP in AVI. I prepared a 320x240 file where I set DAR to 2.35:1 (using MPEG4 Modifier). I did some tests with following results:
XviD decoder - WMP OK, MPC OK
ffdshow decoder - WMP 4/3, MPC 16/9
So I guess there is something wired in ffdshow regarding AR setting. In fact how does AR signalling work? Does ffdshow sends any special signals to a player? I think it would be very nice to have a feature which would resize the video to a correct AR (expand or shrink). This might then also solve the problem with DVD letterboxing I mentined before.
Another strange thing is, that ffdshow reports the AR to be 4/3 when playing the file.
vlada is offline   Reply With Quote
Old 5th April 2007, 16:54   #1000  |  Link
kurt
sidekick
kurt's Avatar
@ vlada: which rev. do you use? recently there was a fix for this AR-bug (since rev 1075)...
greets, kurt.
Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC
kurt is offline   Reply With Quote
