27th May 2017, 00:00 | #221 | Link |
Matroska find' ich toll
chapterEditor Alpha 3 is available. An update for the DVD2mkv editor.
Windows Linux The Single and Batch mode is finished and can be tested. Besides the normal titles, the menus can also be converted to an mkv. For this, however, PgcDemux must be used because the Mod version does not work. Both PgcDemux versions can exist in the same folder. Title and menus can be reserved for the batch process. Code:
added & fixed * improved # changed % rev1.00(Alpha 3) 2017-05-27 // DVD2mkv & Single and Batch process mode & Track selection & change track order & adjustable track properties & BDSup2Sub Log * Extracting forced subtitles did not work properly # PgcDemux for the DVD menus |
17th June 2017, 03:29 | #222 | Link |
Hi hubblec4, I hope you add a function for separate chapter like this:
original chapter: Code:
CHAPTER01=00:00:00.000 CHAPTER01NAME= CHAPTER02=00:00:20.020 CHAPTER02NAME= CHAPTER03=00:01:52.112 CHAPTER03NAME= CHAPTER04=00:12:40.760 CHAPTER04NAME= CHAPTER05=00:22:05.324 CHAPTER05NAME= CHAPTER06=00:23:36.415 CHAPTER06NAME= CHAPTER07=00:24:09.448 CHAPTER07NAME= CHAPTER08=00:24:29.468 CHAPTER08NAME= CHAPTER09=00:26:01.560 CHAPTER09NAME= CHAPTER10=00:36:13.171 CHAPTER10NAME= CHAPTER11=00:46:14.772 CHAPTER11NAME= CHAPTER12=00:47:45.863 CHAPTER12NAME= Code:
CHAPTER01=00:00:00.000 CHAPTER01NAME= CHAPTER02=00:00:20.020 CHAPTER02NAME= CHAPTER03=00:01:52.112 CHAPTER03NAME= CHAPTER04=00:12:40.760 CHAPTER04NAME= CHAPTER05=00:22:05.324 CHAPTER05NAME= CHAPTER06=00:23:36.415 CHAPTER06NAME= Code:
CHAPTER01=00:00:00.000 CHAPTER01NAME= CHAPTER02=00:00:20.020 CHAPTER02NAME= CHAPTER03=00:01:52.112 CHAPTER03NAME= CHAPTER04=00:12:03.723 CHAPTER04NAME= CHAPTER05=00:22:05.324 CHAPTER05NAME= CHAPTER06=00:23:36.415 CHAPTER06NAME= |
25th June 2017, 17:33 | #224 | Link |
chapterEditor Alpha 4 is available. An update for the DVD2mkv editor.
Windows Linux Multi-Edition-MKV mode is ready. In this mode it is possible to save from a DVD, which contains different editions of a movie, into a single mkv. The editions are named by tags, and are then selectable in the player. Unfortunately, this procedure is much more complicated than with Bluray, where the m2ts files always contain all the tracks. So unfortunately it happens that the VobIDs not all audio and subtitle tracks are present. For the subtitles you can simply insert a "dummy" file. However, with the audios does not work that easy. Therefore in the Multi-Edition MKV only audio tracks can be used which are present in all VobIDs / Titles. In the normal case, all audio tracks should also be found. My test DVDs (Alien 1-4) have audio tracks from the director which is only available in one edition. In the cE folder is now a data folder Data. There is the subtitle dummy file (dummy.idx / dummy.sub). You can exchange this file, but the file name can not be changed. Is currently still hard-coded (will be adjustable later with file dialog). The titles/editions can be moved before demuxing, and the edition name should be set also before(or later in the tags file). In the test DVD Salt, MTX 12 unfortunately had problems, which Mosu in MTX 13 has fixed. As of now, MTX 13 is required for the chapterEditor. There is still a problem with the "ordered chapters". The times agreed for the appended VobIDs do not always match. When muxing(append) the VobIDs with mkvmerge apparently the playing periods are not exactly met. The times have always shifted a bit backwards. 100 to 200ms which then makes up to 4 seconds for 20 attached VobIDs. In the chapter creating process are all chapter names expand with the VobID number. With a small manual adjustment then ran all Multi MKVs neat. For another test DVD (Christi) which has multi-angle, everything went right immediately, since there is only one different VobID there. The Vob2Vob demux function (not for the menus) is now implemented and should always be used. MTX can read the time stamps from VOB files and thus all audio tracks remain synchronous to the video. A test with track demux brought horrible audio unsynchronities. Code:
added & fixed * improved # changed % rev1.00(Alpha 4) 2017-06-25 // DVD2mkv & Multi-Edition-MKV mode & MKV file titel & MKV Tags (only for Multi-Edition-MKV) & Load Tags in the editor (settings) & VOB to VOB demux - Audio synchronicity is better because MTX can read the time stamps from the VOBs & Track delay adjustable for all VobIDs * Ignore last chapter did not work properly * empty Menu-tables(IFO) caused an error Last edited by hubblec4; 25th June 2017 at 19:19. |
30th June 2017, 01:14 | #225 | Link |
Hi all
In the next update I plan support to add sub-pictures which are supported by MKVToolNix. Bluray(sup), VobSub(idx) and Subtitle Ripper(srt) files are present. Can someone tell me where I can find all the other supported files? Substation Alpha(ass) Advanced Substation Alpha(ssa) Universal Subtitle Format(usf) OggKate(ogx/ogg) |
30th June 2017, 08:32 | #226 | Link |
No one uses usf. Don't bother. I don't really know about OggKate but I assume it is similar. I doubt anyone will ever ask you about those two. For SSA and ASS you can create/convert with Subtitle Edit or Aegisub.
30th June 2017, 11:52 | #227 | Link | |
3rd July 2017, 13:20 | #228 | Link |
Hi
Does CE has an option to resync chapter files (keeping Chap01 at 0 and shifting the rest either forward or back time wise) ? I found time adjustment option but it's only for positive values (not sure if it's ms, sec, minutes). also, the download links on the first post don't seem to work at the moment. thanks |
3rd July 2017, 14:29 | #229 | Link | ||
Hi mini-moose
With the option "Action range" you can specify a start chapter. Time formats: - HH:MM:SS (00:00:00) - HH:MM:SS.ms/ns (00:00:00.123456789) - Seconds (120) - Minutes (7m) - as float value (1.2345 or 1,6789) Quote:
You can download cE from Softpedia. |
3rd July 2017, 17:53 | #230 | Link | |
I did try that before posting with negative value but it doesn't do anything. Perhaps I'm doing it wrong: Action Range: All Chapters FPS/Multi times: default Move times: -00:00:01.123 Nothing changes on the times on the chapter list on the left side when I use "-". It only changes if I don't use "-" and forward of course. |
3rd July 2017, 19:04 | #231 | Link | |
I hope a have tomorrow a bit time, then I will upload a new version. |
5th July 2017, 11:31 | #232 | Link |
chapterEditor Alpha 5 is available.
Windows Linux There are a few important updates for the cE and the Matroska Chapters editor. There are also new features. Code:
added & fixed * improved # changed % rev1.00(Alpha 5) 2017-07-04 // chapterEditor * Language: Norwegian did not work // Settings & Disc2mkv: Predefinable language - is used for chapters, SimpleTags and some external subtitles & DVD2mkv: Select subtitle dummy file with file dialog // Matroska Chapters * Flag "Standard" for editions had 2 errors - Copy/duplicate or delete a Standard edition // Time adjustments * Negative time shift did not work * cutting: - Start time at 0 did not work - Start time greater than or equal to End time is now ignored // DVD2mkv & Add subtitle files - Support for most MTX subtitle formats & Text Favorites - Tags: Editionname - Track name: Video, Audio, Subtitle Last edited by hubblec4; 5th July 2017 at 11:35. |
5th July 2017, 20:12 | #233 | Link |
Thanks hubblec4!
I can confirm negative values now work, however only if they are over 1 second long: Code:
-00:00:00.789 / 00:00:00.789 will not shift, -00:00:01.000 / 00:00:01.000 will shift. The program rounds the original times - is it meant to be like that?: Code:
00:10:36.261 becomes: 00:10:36.0.000 Last edited by mini-moose; 5th July 2017 at 20:14. |
6th July 2017, 01:51 | #234 | Link | ||
Hi mini-moose
Thanks for yor tests. I will look into this. Quote:
EDIT: In my test is all fine. Which cE version are you using? Can you explain a bit more detailed in what you do? Last edited by hubblec4; 6th July 2017 at 01:54. |
6th July 2017, 11:39 | #235 | Link | |
I load the existing chapters file (from bluray or DVD) in the OGG/OGM tab, Go to "Time Adjustments", Add the value in "Move times", add -00:00:00.789 there and hit "Adjust times". on the original chapters files the times are presented in this format (1st bluray, 2nd dvd): Code:
CHAPTER02=00:10:36.261 CHAPTER02NAME= and CHAPTER02=00:09:25.240 CHAPTER02NAME=Chapter 2 Code:
00:10:36.0.000 and 00:09:25.0.000 They are not shifting when I use a value under 1second in "Move Times", and MS is ignored if I use 00:00:01.789 (increases or decreases by 1sec steps only). Using the "Multipy times by the following factor" does move MS too but I find it too confusing for what I need (which is to add a certain velue and let the tool do the shift it). Last edited by mini-moose; 6th July 2017 at 11:50. |
6th July 2017, 12:39 | #236 | Link |
Mmhh, all my test are fine. I have made a new OGG.txt chapter file, load to OGG/OGM editor enter your time shift code and press "Adjust times".
A OGG/OGM from scratch work fine too. I guess the chapter files came from eac3to? Could you send me your chapter files? (do not upload in this forum please) "Multipy times by the following factor" can't be used for time shift, it is an equivalent to FPS change(in one step). |
6th July 2017, 13:07 | #237 | Link | |
6th July 2017, 13:21 | #238 | Link |
MKVToolNix author
hubblec4, are you perhaps using a number parsing function that pays attention to the user's locale regarding the decimal point? If so, maybe mini-moose's locale uses a comma as the decimal point.
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
6th July 2017, 13:54 | #239 | Link | |
The chapter files have decimal points. |
bluray backup, chapter editor, dvd2mkv, matroska menu, metadata, multi-edition-mkv, xml tag |
