21st August 2019, 19:22 | #1661 | Link | |
I guess that you mean that "vp92" files (actually "VP9" content, I guess, and vp92 is just not recognized by MediaInfo so displayed as is) don't have transfer_characteristics related info. Please provide a file (not a link to a youtube channel page). If I read well the VP9 spec, HDR10+ info is in the container (WebM) and it would be relevant for me to support that (WebM still used by Google), currently it is not supported (looks like they don't use the same method than Matroska), but if it is in the VP9 bitstream I would be less motivated (VP9 is abandoned in favor of AV1...)
Want to know all about your media files? http://mediaarea.net/MediaInfo |
21st August 2019, 19:27 | #1662 | Link | |
Life's clearer in 4K UHD
I recently found this Dolby TrueHD high-level bitstream description - Dolby Developer [.pdf file] documentation but I can't seem to find out what FBA stands for...
22nd August 2019, 10:07 | #1663 | Link |
You see in that doc "referred to in this document as the FBA syntax." ;-)
FBA and FBB are the last 12 bits of the magic sync value (0xF8726FBA / 0xF8726FBB). IIUC FBB syntax is the first one (before Dolby buys Meridian Audio related technology) then Dolby updated the bistream syntax and has set FBA instead of FBB in the magic value for their version. I don't have access to Meridian FBB spec, so difficult to know the exact purpose of the modified bit (was it planned or not? ...), but I was said that technical people working on MLP use the "FBA" term for speaking about the Dolby version.
24th September 2019, 01:59 | #1665 | Link | |
Both PQ and HLG are now reported correctly for these vp92 clips. Many thanks and best regards, |
18th October 2019, 18:50 | #1666 | Link |
Why DTS-MA is reported as DTS instead of DTS XLL?
MediaInfoA_Get(Handle_, streamkind, 0, PChar('Format'), 1, 0)
18th October 2019, 20:26 | #1667 | Link |
Post full media of that file.
19th October 2019, 14:32 | #1668 | Link |
General ID : 1 (0x1) Complete name : E:\_Video_Samples\m2ts\Wanted_DTSMA.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 102 MiB Duration : 33 s 200 ms Overall bit rate mode : Variable Overall bit rate : 25.7 Mb/s Maximum Overall bit rate : 35.5 Mb/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : 27 Duration : 32 s 616 ms Bit rate mode : Variable Maximum bit rate : 32.3 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Muxing mode : Stream extension Codec ID : 134 Duration : 32 s 853 ms Bit rate mode : Variable Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossless Delay relative to video : 3 ms Language : English
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 19th October 2019 at 14:34. |
28th October 2019, 22:57 | #1669 | Link |
It's because 'Format' shows the format family name. Take a look at the raw view:
6th November 2019, 12:52 | #1670 | Link |
The raw text summary has a column width limit of 32 characters, larger parameters are trimmed:
MasteringDisplay_ColorPrimaries_ : Stream MasteringDisplay_Luminance_Sourc : Stream Code:
MasteringDisplay_ColorPrimaries_Source : Stream
11th April 2020, 08:07 | #1671 | Link |
Small request: Would be nice if MediaInfo would report the rotation flags of mkv files.
I created a file using: Code:
mkvmerge --ui-language en -o "E:\Output\source with rotation flag.mkv" --global-tags "E:\Temp\source with rotation flag_08_56_54_1010__06.xml" -d 0 --default-track 0:yes --projection-type 0:0 --projection-pose-roll 0:90 --track-name 0:"VideoHandle" --language 0:en --default-duration 0:2984100/100000fps --aspect-ratio-factor 0:1/1 --fourcc 0:MP4V --no-chapters --compression -1:none --forced-track 0:yes --no-audio --no-subtitles --timecodes 0:"E:\Temp\timecodeV2_08_56_54_1010.tc" "E:\Temp\08_56_54_1010_03.264" Cu Selur |
5th January 2021, 18:29 | #1672 | Link |
So I'm finding a weird thing iwth the latest version of Premiere Pro 2020 on Windows. Encoding:
HEVC (H.265) Match Source Software Encoding Profile: Main 10 Level: 6.2 Tier: High Check Rec 2020 Color Primaries Check High Dynamic Range Check Include HDR10 Metadata Color primaries: Rec2020 Luminance Min: 0.005 Liminance Max: 4000 Constant Light Levels Maximum: 4000 Constant Light Levels Average: 1166 CBR encoded OK so that's the settings for both encodes. One is the full hour and a half movie that returns in MediaInfo: Code:
Video Count : 378 Count of stream of this kind : 1 Kind of stream : Video Kind of stream : Video Stream identifier : 0 StreamOrder : 0 Inform : English, 20.0 Mb/s, 3840*1600 (2.40:1), at 23.976 (24000/1001) FPS, HEVC (Main 10@L6.2@High) ID : 1 ID : 1 Format : HEVC Format : HEVC Format/Info : High Efficiency Video Coding Format/Url : http://www.itu.int Commercial name : HEVC Format profile : Main 10@L6.2@High Internet media type : video/H265 Codec ID : hvc1 Codec ID/Info : High Efficiency Video Coding Codec ID/Url : http://www.itu.int/ Duration : 5262257 Duration : 1 h 27 min Duration : 1 h 27 min 42 s 257 ms Duration : 1 h 27 min Duration : 01:27:42.257 Duration : 01:27:43;14 Duration : 01:27:42.257 (01:27:43;14) Bit rate : 19998744 Bit rate : 20.0 Mb/s Width : 3840 Width : 3 840 pixels Height : 1600 Height : 1 600 pixels Sampled_Width : 3840 Sampled_Height : 1600 Pixel aspect ratio : 1.000 Display aspect ratio : 2.400 Display aspect ratio : 2.40:1 Rotation : 0.000 Frame rate mode : CFR Frame rate mode : Constant Frame rate : 23.976 Frame rate : 23.976 (24000/1001) FPS FrameRate_Num : 24000 FrameRate_Den : 1001 Frame count : 126168 Color space : YUV Chroma subsampling : 4:2:0 Chroma subsampling : 4:2:0 Bit depth : 10 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.136 Stream size : 13154829406 Stream size : 12.3 GiB (100%) Stream size : 12 GiB Stream size : 12 GiB Stream size : 12.3 GiB Stream size : 12.25 GiB Stream size : 12.3 GiB (100%) Proportion of this stream : 0.99988 Language : en Language : English Language : English Language : en Language : eng Language : en Encoded date : UTC 2021-01-05 12:22:00 Tagged date : UTC 2021-01-05 12:22:00 colour_description_present : Yes colour_description_present_Source : Stream Color range : Full colour_range_Source : Stream Color primaries : BT.2020 colour_primaries_Source : Stream Transfer characteristics : PQ transfer_characteristics_Source : Stream Matrix coefficients : BT.2020 non-constant matrix_coefficients_Source : Stream Codec configuration box : hvcC Code:
Video Count : 378 Count of stream of this kind : 1 Kind of stream : Video Kind of stream : Video Stream identifier : 0 StreamOrder : 0 Inform : English, 20.0 Mb/s, 3840*1600 (2.40:1), at 23.976 (24000/1001) FPS, HEVC (Main 10@L6.2@High), HDR10 ID : 1 ID : 1 Format : HEVC Format : HEVC Format/Info : High Efficiency Video Coding Format/Url : http://www.itu.int Commercial name : HEVC Format profile : Main 10@L6.2@High HDR format : SMPTE ST 2086 HDR format : SMPTE ST 2086, HDR10 compatible HDR_Format_Commercial : HDR10 HDR_Format_Compatibility : HDR10 Internet media type : video/H265 Codec ID : hvc1 Codec ID/Info : High Efficiency Video Coding Codec ID/Url : http://www.itu.int/ Duration : 131131 Duration : 2 min 11 s Duration : 2 min 11 s 131 ms Duration : 2 min 11 s Duration : 00:02:11.131 Duration : 00:02:11;04 Duration : 00:02:11.131 (00:02:11;04) Bit rate : 20008316 Bit rate : 20.0 Mb/s Width : 3840 Width : 3 840 pixels Height : 1600 Height : 1 600 pixels Sampled_Width : 3840 Sampled_Height : 1600 Pixel aspect ratio : 1.000 Display aspect ratio : 2.400 Display aspect ratio : 2.40:1 Rotation : 0.000 Frame rate mode : CFR Frame rate mode : Constant Frame rate : 23.976 Frame rate : 23.976 (24000/1001) FPS FrameRate_Num : 24000 FrameRate_Den : 1001 Frame count : 3144 Color space : YUV Chroma subsampling : 4:2:0 Chroma subsampling : 4:2:0 Bit depth : 10 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.136 Stream size : 327964146 Stream size : 313 MiB (100%) Stream size : 313 MiB Stream size : 313 MiB Stream size : 313 MiB Stream size : 312.8 MiB Stream size : 313 MiB (100%) Proportion of this stream : 0.99986 Language : en Language : English Language : English Language : en Language : eng Language : en Encoded date : UTC 2021-01-05 17:06:57 Tagged date : UTC 2021-01-05 17:06:57 colour_description_present : Yes colour_description_present_Source : Stream Color range : Full colour_range_Source : Stream Color primaries : BT.2020 colour_primaries_Source : Stream Transfer characteristics : PQ transfer_characteristics_Source : Stream Matrix coefficients : BT.2020 non-constant matrix_coefficients_Source : Stream Mastering display color primaries : BT.2020 MasteringDisplay_ColorPrimaries_Source : Stream Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 MasteringDisplay_Luminance_Source : Stream Maximum Content Light Level : 4000 cd/m2 MaxCLL_Source : Stream Maximum Frame-Average Light Level : 1166 cd/m2 MaxFALL_Source : Stream Codec configuration box : hvcC |
27th June 2021, 17:57 | #1674 | Link |
Can we get a new listing for whether the Original MKV track flag is set?
https://matroska.org/technical/notes.html This is going to be important moving forward as the changes to the Default flag mean it cannot be used to differentiate between the original and dubs as they all count as Default tracks. The Original flag is the correct way to mark the original track. Last edited by kuchikirukia; 27th June 2021 at 18:14. |
22nd February 2022, 23:51 | #1675 | Link |
Any suggestions for a GUI which handles full-scanning best, hopefully including scan progress indication?
MediaInfoGUI doesn't do it well, and appears to read the whole file into memory. MediaInfo.NET is okay but very minimalistic. |
6th October 2022, 20:43 | #1676 | Link |
SuperVirus
current version = 22.09
Changelog: Code:
Version 22.09, 2022-10-04 ------------- + Italian language update + USAC: IOD and sampling rate coherency checking + ADM: support of nested objects and complementary objects + AC-4: Display of Custom downmix targets + IAB: Parsing of IAB bitstream and ADM-like output + Frame rate: store FrameRate_Num/Den also for integer values + MPEG-4/MOV: support of time codes >30 fps + MOV/MPEG-4: List of QuickTime time code discontinuities + Dolby Vision: add info about more profiles x Text streams: show stream frame rate if not same as container frame rate x CDP: fix rounding of frame rate x SCC: fix of CEA-608 FirstDisplay_Delay_Frames x SCC: fix TimeCode_Last x MPEG-4/MOV: last time code value for all kind of QuickTime time codes x MOV/MPEG-4: Fix frame count for NDF non-integer frame rates x JSON: fix invalid output in some corner cases x Several other parsing bug/crash fixes (thanks to fuzzing by users)
«Your software patents have expired.» |
8th October 2022, 10:16 | #1677 | Link | |
QfG Group Germany
Is it possible to add Auro3D classification on DTS-HD MA streams?
29th December 2022, 18:45 | #1679 | Link |
war59312.com
AV1 Netflix samples:
http://download.opencontent.netflix....x=AV1/Chimera/ Would be sweet if MediaInfo supported the .obu files. |
30th December 2022, 03:31 | #1680 | Link |
QfG Group Germany
I wrote this to the support but i do it here, too:
In version 22.12 the entry under video "BitsPixel_Frame" is changed to "Bits-Pixel_Frame". I use a PHP script to read via a JSON file all video informations. But the "-" is a problem in PHP, this will be called as an function . Example (older version) Code:
$json["bitrate"] = $video[0]->BitRate_String." => ".$video[0]->BitsPixel_Frame." Bits/(Pixel*Frame)"; Example (v22.12) Code:
$json["bitrate"] = $video[0]->BitRate_String." => ".$video[0]->Bits-Pixel_Frame." Bits/(Pixel*Frame)"; Is there any chance to rallback to "BitsPixel_Frame" in JSON output?
