Old 23rd February 2018, 01:35   #1  |  Link
beto@endrix
Issue with MPC-BE + madVR + LAV + XySubFilter
So yesterday I found out just how much better this combo is compared to VLC, and spent my night configuring it (following this and this) and getting it ready to watch a BluRay 4K movie today.
However, I stumbled on a problem: the movie is in a matroska container and it has forced french .pgs subtitles coded in, although it has many others in the same file (forced and not). When I switch to another language, or when I set my preferred language to play at start, as soon as the first subtitle appears, the video loses all its quality, the image appears really dull and washed. I think that happens because the renderer swaps to internal, or madVR crashes. Maybe it's none of that, still new to this.
Can someone tell me what is happening and how can I fix it?
Windows 7
1070 on the latest drivers
Happy to provide more information if you need.
beto@endrix is offline   Reply With Quote
Old 23rd February 2018, 02:19   #2  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Try use internal filters + madVR.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 23rd February 2018, 02:42   #3  |  Link
beto@endrix
That works, but the trade-off is losing LAV, which I'd prefer not to...
Is that the only solution that comes to your mind or is there something else I could try?
Old 23rd February 2018, 04:12   #4  |  Link
Aleksoid1978
If no problem without LAV ...
Old 23rd February 2018, 08:40   #5  |  Link
chros
chros's Avatar
I'm pretty sure it's xysubfilter (I also use lavfilters but with the internal subengine). You can try to drop xysubfilter first to see what will change.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 23rd February 2018, 18:08   #6  |  Link
beto@endrix
Yeah, that's it. The thing is, it works fine on the usual 1080p H.264 stuff. Maybe a conflict with HEVC?
I guess I have to drop that to watch 4K...
Another thing, is using Direct3D 11 for presentation on the rendering settings of madVR supposed to give you a better performance? Every time I turn that on and reset, the player freezes all over the place..
Old 23rd February 2018, 18:19   #7  |  Link
nevcairiel
If its HDR content, xysubfilter will probably "lose" the HDR metadata in the process.
Old 23rd February 2018, 20:45   #8  |  Link
beto@endrix
It's Dunkirk, pretty sure it has HDR, so that should be the problem. Damn shame, the subtitles look way better with xysub, but I guess I have to live with it..
Nothing on the D3D 11 thingy?
Also, thank you so much for the help thus far, really appreciate it!
Old 23rd February 2018, 21:44   #9  |  Link
sneaker_ger
But XySubFilter sits between splitter and renderer, not between video decoder and renderer? And has its own input into madvr that's independent?
Old 24th February 2018, 02:16   #10  |  Link
Asmodian
Use whatever works better, D3D11 or D3D9. There aren't any major performance improvements in D3D11, just that it might interact with new OSes a little better.
madVR options explained
Old 24th February 2018, 05:31   #11  |  Link
beto@endrix
That's exactly what I wanted to know, thanks a lot.
Old 24th February 2018, 10:56   #12  |  Link
chros
chros's Avatar
Damn shame, the subtitles look way better with xysub ...
Although I have never used xysub but I don't have any issues with the internal subfilter, not to mention the ability to use subresync (ctrl+6). Take a look at these posts, it can be problematic to set it up properly:
- https://forum.doom9.org/showthread.p...37#post1819937
- https://forum.doom9.org/showthread.p...39#post1820039
And here's a modded Android remote for this setup
Enjoy!
Old 26th February 2018, 11:05   #13  |  Link
beto@endrix
Enjoy!
Thanks for the helpful reply!
But what changes if my screen is better than 1080p? What's the impact of the "disable scaling if image size changes by only" option? Can I reduce/uncheck that?
Also, why does the Android remote need android.permission.READ_PHONE_STATE? Did you manage to completely remove the ads too? Because there still is ad activity unfortunately...
Good job modding it though, and thanks for telling me about it, appreciate it.
Old 26th February 2018, 11:39   #14  |  Link
chros
chros's Avatar
That's fine as well. I just mentioned this in the first post because I specified pixel values couple of times (so you have to modify yours).
From the 2nd post:
"---- it doesn't turn on the scaling algorithms for small size changes, e.g.: if your display is 1920x1080 and your video file 1904x1064 (e.g. with web-dls)"
So it save GPU power for unnecessary scaling, just use it this way.
It can auto-pause/unpause playback during incoming calls.
Well, I'm not sure about this one: at least they aren't visible anymore
Thanks, enjoy!
And let me know how the internal subengine compares to xysubfilter quality-wise after those settings were applied.
Old 26th February 2018, 13:38   #15  |  Link
beto@endrix
I can't seem to get the app to work, I followed your guide and I'm pretty sure I got the IP and port right. What is supposed to show up when you test the connection on the phone browser?
Subengine looks great now, but I prefer to get outlined subs instead of an opaque box, I think it looks better.
Thanks again for the help!
Old 26th February 2018, 15:18   #16  |  Link
chros
chros's Avatar
The player should be running (playing some content) and you should see the slider moving, the filename, etc. (Note that the app can't start the player itself, it can only communicate with a running instance.)
If it's not working and you're on the same subnet then it's probably some firewall settings on the PC (e.g. windows builtin firewall, antivirus firewall, etc.)
It's easy to test: have you taken a look at the guide inside the app itself?
If it still won't work until the evening, I'll write couple steps how to test it.
Old 26th February 2018, 19:45   #17  |  Link
chros
chros's Avatar
Web Interface settings:
- x Listen on port: 13579
- x Enable compression
- only in MPC-HC: x Enable preview
Try out on the same PC first:
- start MPC-BE/HC
- open a browser use this URL: http://localhost:13579
-- you should see: dropdown with commands, and several links (e.g. File browser, Info page, etc)
Then do the same on your mobile:
- open a browser and use the IP address of the PC, eg.: http://192.168.1.6:13579
If it works then the app should also work.
Old 26th February 2018, 23:48   #18  |  Link
beto@endrix
- start MPC-BE/HC
Got it! It was an issue with Android's firewall, it's fixed now.
Thank you so very much, have a wonderful week!
Old 27th February 2018, 10:40   #19  |  Link
chros
chros's Avatar
Interesting , I'm glad it worked! And you too!
4k movie, bluray, madvr, matroska, mpc
