Old 5th December 2016, 12:54   #1  |  Link
hanfrunz
hanfrunz's Avatar
[MeGUI] use converttoyv12(interlaced=true) for interlaced source !
Hello everyone,
if you have a interlaced 4:2:2 source, you need to use converttoyv12(interlaced=true) if your x264 encode is also interlaced!
If you don't use it you will get artifacts (flicker on bright red colors etc.). Maybe that should be checked or asked in MeGui?
regards
hanfrunz
hanfrunz is offline   Reply With Quote
Old 7th December 2016, 23:26   #2  |  Link
kuchikirukia
MeGUI's, "I noticed your file isn't YV12, would you like me to add converttoyv12() at the end of your script" is there so a user can catch his mistakes, not to do his thinking for him. If you needed interlaced=true, you should have put that in your script.
kuchikirukia is offline   Reply With Quote
interlaced, megui
