5th February 2019, 17:20 | #23222 | Link |
I think that I was the reason that it was disabled again.
It caused LAVFilters to freeze up so hard that I had to kill it via process manager. But maybe it could be added as an option somewhere, if it doesn't clutter up the settings too badly? |
5th February 2019, 17:47 | #23223 | Link |
An option that is known to practically cause the entire hardware to hang is not something that'll ever be exposed to users.
Unless some effort is invested to figure out what makes some videos cause this problem, and find out if its possible to fix it, it really doesn't make sense to open it up to issues again.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 5th February 2019 at 18:00. |
6th February 2019, 00:15 | #23224 | Link | |
6th February 2019, 04:58 | #23225 | Link |
Wanted to report here, as well. Watching Incredibles 2 MKV and not a single issue with this new build. Very happy!
7th February 2019, 19:34 | #23227 | Link | ||
I have re-visited the problem and done some additional filtering of the bitstream to hopefully avoid the problem. However, I was also unable to reproduce it anymore, even with old LAV and old drivers, so maybe something in a Windows 10 update fixed it. Anyhow, its now possible to enable H.264 MVC HW decoding in LAV Video, if you have a Intel GPU. Its default off. Testing would be appreciated. Even more so if you previously had the hang problem. It'll be available in a couple hours in the next nightly build at https://files.1f0.de/lavf/nightly/
7th February 2019, 23:12 | #23228 | Link |
Cross post (JRiver Thead0 but FYI - Tested the following historic probs with had/soft drops and they all played fine with the latest LAV Nightly (all folder rips).
- "Incredibles 2" - Soft Drop : eg drops at 3:16 at the seamless branching point where it goes to the Incredibles 2 spinning logo - “Pirates of the Caribbean - Dead Men Tell No Tales” - Hard Drop : eg drops out a couple of times between 17:45 and 19:00 minutes into the movie - “Guardians of the Galaxy Vol II” - Hard Drop : eg drops out at 1:09:24 where TaserFace gets killed is one example. - “Maze Runner: The Death Cure” - Hard Drop : eg Right at the beginning of the Main Title when the 20th Century clip is running Thanks Hendrik - looks good to me. |
7th February 2019, 23:28 | #23231 | Link |
For JRiver, I just copy them from my laptop into the plugins/lav folder. However, you really should register the ax files from there which is what I do. Mainly because I have custom settings for LAV Video in JRiver so I can use D3D11 decoding.
8th February 2019, 08:58 | #23233 | Link | |
SuperVirus
8th February 2019, 13:22 | #23234 | Link |
LAVVideo.ax bug in two latest nightly builds
Two latest nightly builds 0.73.1-14 and 0.73.1-11 are buggy! LAVVideo.ax is not loadable under Windows 2008 Server x86 Service Pack 2.
Build 0.73.1-6 is working normally. Last edited by eugeny; 8th February 2019 at 13:25. Reason: Add "x86" in OS description |
8th February 2019, 13:46 | #23235 | Link | |
As you know I had to unregister MadVR and move it to the plugins, and register it there, but it didn't seem to be necessary for LAV, which makes updating it easier (I simply install the new version). The added benefit is that it installs both teh 64bits and the 32bits version, the latter being needed for MadMeasureHDR. Maybe Nevcairiel will correct me if there is a better way to keep LAV updated when using jRiver, but for now it's working well for me.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K |
8th February 2019, 13:58 | #23236 | Link |
I think it is because of update to latest Intel MSDK decoder. It's use function SetThreadErrorMode, it's minimum support Windows 7/2008 R2.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
8th February 2019, 17:15 | #23237 | Link | |
8th February 2019, 17:55 | #23238 | Link | |
8th February 2019, 18:13 | #23239 | Link | |
If I was to do it your way, I should: Copy the LAV x64 most recent LAV files into the plugin directory Uninstall LAV standalone Register the plugin version using regsvr32 Then when a new version of LAV arrives, unpack it and copy the x64 files to the plugin? Then what I do I do to have the x86 version registered for MadMeasureHDR? The only issue I have a the moment is lots of UHD BD Menus won't play properly (direct movie playback works fine). If this is unlikely to fix it, I'm tempted to stay as it is...
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 8th February 2019 at 18:22. |
8th February 2019, 18:29 | #23240 | Link |
I doubt that'll fix the UHD menu issue. If you have examples of titles not playing menus correctly, you should visit the bd menu thread on JRiver forum and post about them there so they can be looked at.
