30th March 2013, 13:36 | #2901 | Link |
My mistake, i mean 59,94.
Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 3.83 GiB Duration : 1h 19mn Overall bit rate mode : Variable Overall bit rate : 6 933 Kbps Writing application : Lavf53.3.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1h 19mn Bit rate : 6 797 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 3:2 Frame rate mode : Variable Frame rate : 59.940 fps Minimum frame rate : 59.940 fps Maximum frame rate : 60.000 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Bits/(Pixel*Frame) : 0.328 Stream size : 3.75 GiB (98%) Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 1h 19mn Bit rate mode : Variable Bit rate : 128 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 72.4 MiB (2%) |
30th March 2013, 14:40 | #2902 | Link |
The most current DGIndexNV version should be able to read MP4 and derive the frame rate from its header.
Changes.txt Code:
Build 2044 ---------- * Added MP4 container support. ... |
30th March 2013, 15:07 | #2904 | Link |
A raw H.264 video stream may not contain any information about its framerate at all. No surprise that this step was not useful.
How about converting the container to MKV, using mkvmerge (MMG)? Or rebuilding the MP4 with MP4Box before using it in DGIndexNV? "Writing application : Lavf53.3.0" is an indication towards ffmpeg, which is known to create incomplete MP4 containers (due to its "filter" behaviour, sequentially writing the output only once). Last edited by LigH; 30th March 2013 at 15:23. |
30th March 2013, 15:36 | #2905 | Link |
No, it stills detect the half lenght of the video and forcing it 59.94FPS accelerate the video.
Its strange, FFmpegSource2 run and index it perfectly. Is there any way to transform the .ffindex of FFmpegSource2 in .dgi of DGNV? Sure its a nonsense, just guessing. Last edited by stranno; 30th March 2013 at 15:41. |
30th March 2013, 16:15 | #2906 | Link |
If you post a sample stream that I can use to duplicate your issue, I'll be able to tell you what is happening and what you should do. If DGIndexNV says there are 142143 frames, I would believe that.
Where did you get this movie MP4 file? Last edited by Guest; 30th March 2013 at 16:20. |
7th May 2013, 08:13 | #2913 | Link | |
DGMPGDec Known Issues and Limitations states:
It's kind of annoying having to rename all unicode files or use a 8.3 compatible short file names (if the file system supports it). Cu Selur |
13th May 2013, 22:15 | #2916 | Link |
I got a problem with "Gran Torino" and DGIndexNV 2045 (32bit). There is a position in the movie which let DGIndexNV crash (or the NVIDIA driver). In the final movie output the image just stops in that position and displays the whole last piece of the movie (only audio is played till the end). So I took a second look and opened the Video preview of MeGUI, switched to that position and pressed play. This is what will happen everytime: http://i.imagebanana.com/img/7q5g7ttj/Gran.jpg In english like "the display driver 'NVIDIA Windows Kernel Mode Driver' doesn't react anymore and was restored after an error." When I look to the original movie file, at this position there is one frame, which is completly wrong, but MeGUI already crashs 3 frames before the 'wrong' frame appears. I have a GTX480 newest WHQL driver, Windows 8 64bit. What can I do? Last edited by Morku; 13th May 2013 at 22:18. |
13th May 2013, 23:39 | #2917 | Link |
Please post a link to an unprocessed source stream sample that I can use to try to reproduce the issue. Use DGSplit to cut the stream and make sure the problem happens with the file that you upload. Use a hosting site such as mediafire.com and post the link here. Thank you.
