Old 7th March 2008, 21:47   #841  |  Link
Encoder888
Encoder888's Avatar
Okay, I don't wanna repeat other people's questions, but I have the following problem - The English audio of the BD I'm trying to encode does not show up as an option for me in the audio menu. All the other languages do, but the English doesn't. The reason for that is because the English audio stream is the original uncompressed PCM, which demuxes into a .pcm file, while all the other languages demux into .ac3 as usual, so they're visible. And RipBot does not seem to demux/recognize the .pcm file. So, I can't encode my movie with English audio Please, help.
Encoder888 is offline   Reply With Quote
Old 7th March 2008, 22:26   #842  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Send me short sample (about 25Mb)
Use this http://www.filesplitter.org/Free-Fil...-v4.1.0075.exe
^ is there no option to choose temp files location??
edit .ini
Old 7th March 2008, 22:57   #843  |  Link
Furiousflea
Samples please!
Does preview work with SetMT...?
No, preview doesn't work.
But it didn't work before on my XP setup when MT was enabled.
However the video would still encode, sometimes video would get encoded without audio on my XP setup but usually it would be OK with MT.
Furiousflea is offline   Reply With Quote
Old 7th March 2008, 23:48   #844  |  Link
eyekyu
Are you sure that PS3 supports BluRay movies on BD-RW??? First DVD players didn't play DVD-RW...
yeah iam sure, it worked before on about 3 movies now they dont show up
eyekyu is offline   Reply With Quote
Old 8th March 2008, 01:23   #845  |  Link
KingWeaver88
Could someone please explain how to batch convert files using this program?
KingWeaver88 is offline   Reply With Quote
Old 8th March 2008, 03:41   #846  |  Link
survivant001
@Atak_Snajpera
I try the tsmuxer 1.4.3b with my problematic movie.
I try the bluray output and the FF WORKS, and the audio is SYNC.
we have a winner
I just copy the 00001.msts on a USB key and play it on the PS3.
I'll stick with that. Will try with Tversity later.
I'll try the x264 build 748 modified too. will keep you inform
survivant001 is offline   Reply With Quote
Old 8th March 2008, 05:42   #847  |  Link
Ajax_Undone
I dont care so should you
Ajax_Undone's Avatar
Ok the correct audio delay is not being picked up by RipBot
Sample of VOB: http://www.mediafire.com/?mczd4ydujzz
Sample of mp4: http://www.mediafire.com/?gtwxnztdc5m
My Installer's ||
Ajax_Undone is offline   Reply With Quote
Old 8th March 2008, 19:04   #848  |  Link
Furiousflea
Weird, I got the video to load by installing the Xvid codec....I thought FFDShow should be able to decode that on its own, no?
The MT thing still isn't working though, when I click the "preview" button MPC loads with a tiny box in the middle, when I press play it says "SetMTmode(2,0) function is unrecognised" or something like that....does that mean its not installed properly?
Very confused!!!
Thanks for any help
Old 8th March 2008, 22:03   #849  |  Link
Atak_Snajpera
You need special version of AviSynth.dll in /system32 (If you have x32) and MT.dll in AviSynth 2.5\plugins directory
Old 8th March 2008, 22:38   #850  |  Link
Atak_Snajpera
Correct delay is ~800ms. Nothing is perfect so always check synchronization in preview!
Old 9th March 2008, 01:17   #851  |  Link
Furiousflea
Hi, thanks for replying
Thing is, I have put the MT.dll inside the Avisynth plugins folder, and I have also put the modifiied avisynth.dll from the MT 0.7 package in the windows\system32 folder...
I'm using Vista x64 could it be that that is the problem?
Thanks, Rob
Old 9th March 2008, 02:07   #852  |  Link
survivant001
I'm ready to test a new release with the bluray output
Old 9th March 2008, 04:57   #853  |  Link
Ajax_Undone
Ok just figured you would be interested...
My Installer's ||
Old 9th March 2008, 07:33   #854  |  Link
Atak_Snajpera
It's almost ready. I have to add subtitles support and create new correct formula for size calculation Overhead seems to be lower than after TSRemux :/
Old 9th March 2008, 12:59   #855  |  Link
lighttear
Small avisynth correction for a correct timestreching
Hi, I'm facing this problem when converting a 23,976 bluray film into a 25fps PAL compliant movie: the audio is not correctly stretched so I looked in the avisynth script created from RipBot264 and changed in this way:
original avs script:
#Tempo
video=AssumeFPS(video,25)
#Delay
audio=DelayAudio(audio,0)
#Normalize
audio=Normalize(audio,1)
#AudioDub
audio=ConvertAudioTo16bit(audio)
AudioDub(video,audio) <<<< IT'S NOT ENOUGH
#Triming
Trim(0,3125)
my working correction is:
#Tempo
#Delay
#Normalize
#AudioDub
TimeStretch(tempo = (100.0*25.0)/23.976) <<< NECESSARY
#Triming
Trim(0,3125)
I hope this helps
Cheers
L.
lighttear is offline   Reply With Quote
Old 9th March 2008, 18:59   #856  |  Link
eyekyu
so u'll be coming out with a new release of ripbot soon?
Old 9th March 2008, 22:30   #857  |  Link
Atak_Snajpera
http://img182.imageshack.us/img182/3014/new1qj4.png
@lighttear
You forgot something!
Once again I have to do many encodes to create correct formula for Blu-Ray. Current formula works well only if you use TSRemux otherwise few megabytes are always wasted (undersize).
Old 9th March 2008, 23:19   #858  |  Link
jfcarbel
Programmer
I want to convert Quicktime HD movie trailers to play on my Blu-Ray player in full 1080 glory.
Can this tool convert ACC 5.1 to AC3 5.1?
Since all the HD movie trailers from Apples site contain ACC 5.1 for the audio.
I know it can accept MP4 container as input and can output to a .m2ts stream, so all it really needs to make this happen is the audio conversion.
I can get to MP4 container from Quicktime using the Quicktime Pro version to export the video and audio with passthrough settings to an MP4 container.
jfcarbel is offline   Reply With Quote
Old 9th March 2008, 23:38   #859  |  Link
Atak_Snajpera
If you use true MP4 instead of renamed MOV everything should go well.
Old 10th March 2008, 03:14   #860  |  Link
KingWeaver88
how do you batch convert files with this program
