6th August 2010, 13:13 | #12221 | Link |
Kid for Today
his broken english makes my eyes bleed, and mark also doesn't see the point to show the audio infos in ffdshow VIDEO: http://forum.doom9.org/showpost.php?...ostcount=12121
but surely, we're not worthy |
6th August 2010, 13:38 | #12222 | Link |
@devs:
we're working on defining a new media type (GUID + structure), with the main purpose being to connect 3D splitters, decoders and renderers. If you're interested, please post your feedback here: http://forum.doom9.org/showthread.php?t=156051 |
8th August 2010, 17:35 | #12223 | Link |
Kid for Today
10th August 2010, 06:55 | #12224 | Link |
Hi.
I noticed in "ffdshow_rev3517_20100731_clsid.exe" that DTS is not decoded correctly when use libavcodec, libdts working fine (i am not using passthrough). EDIT: Seems to be already fixed in "ffdshow_rev3527_20100808_xhmikosr.exe".
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin Last edited by hoborg; 10th August 2010 at 07:22. |
10th August 2010, 12:48 | #12225 | Link |
Hi, when using 'libsamplerate high quality' as resampler it crashes mpc-hc.
'ff_samplerate.dll' is the problem said by OS crash report This is reproducible on my computer, here is the steps: 1. open any movie file 2. randomly click on the seek bar 3. after 10~20 clicks, there is a chance that mpc-hc will crash when using libavcodec as resamper, everything is fine my computer spec: win xp sp3 mpc-hc svn.2212 ffdshow_rev3527_20100808_xhmikosr_icl11 |
10th August 2010, 14:13 | #12227 | Link |
tried ffdshow_rev3528_20100810_xhmikosr, still crashes mpc-hc
after more investigation, the crash always happens when playing avi video files I remux avi into mkv, and the problem is gone, quite weird... Last edited by 27049215; 10th August 2010 at 14:21. |
10th August 2010, 18:41 | #12229 | Link | |
ffdshow user
10th August 2010, 19:28 | #12230 | Link | |
however, i tried ffdshow_rev3425_20100508, no problem with this version I think it's something else that trigger this crash, I will try more svn builds later Update: I have located the problem is between 3498 and 3507 Last edited by 27049215; 10th August 2010 at 19:39. |
12th August 2010, 17:43 | #12234 | Link |
Audio & video enthusiast
Just updated from vista to 7, now I have problems with FFDshow, I can't get DXVA to work with Win 7 32-bit, in vista it worked perfectly.
My system is: Win 7 HD4200 with cat. 10.1 MPC-HC rev.2223 output EVR Sync FFDshow rev.3488 Edit: Seems that UAC needs to be enabled or FFDshow DXVA won't load. Last edited by NiFa; 12th August 2010 at 18:26. Reason: found problem |
14th August 2010, 01:10 | #12235 | Link |
Can anybody please fix this bug with the DXVA part of ffdshow: http://sourceforge.net/tracker/?func...41&atid=867360
I also made a topic about this in th ffdshow forum, but no one is responding. See here: http://ffdshow-tryout.sourceforge.ne...pic.php?t=1560 This bug is really annoying because some movies are really small (cinema format). Placing those subtitles into an already small picture is not really comfortable to watch :P |
14th August 2010, 14:33 | #12237 | Link |
I have some questions which I can't find in the FAQ. I am confused about the Audio Decoder settings.
I have an Audigy 4 sound card with an analogue amplifier and relatively cheap (but not too bad) speakers. The card is theoretically 24/96 capable but it doesn't support any HDCP encryption. I used to leave the Windows 7 output settings on 16/48. (Can it theoretically hurt the 16/48 sources if I set it to 24/96? Just to make sure that it will be able to handle a 24/96 signal if I will have any...?) I use MPC-HC (latest SVN right now) with madVR video (FS exclusive) and ReClock (WASAPI exclusive) audio renders. I use the internal Source Filters but I disabled every internal Transform Filters to use the external FFDShow codec (it gives me more control over the settings and it is more compatible with madRV). I try to avoid any unnecessary data manipulations. So, I don't use any FFDShow filters/plugins except the Subtitles and Mixer. (I don't really need the mixer because most of the sources match with my 5.1 speaker configuration. But the Subtitle renderer let me use madVR. It is a very nice feature. ) I used to watch movies with 16/48 DTS-1536 or AC3-640 tracks (or the "cores"). I fairly sure that I can't decode the full TrueHD or DTS-HD MA 24/96 tracks with a simple software codec and send it to a non-HDCP compliant soundcard in full resolution (and enjoy a very little bit of the extra quality). And I think I should disable the jitter correction with ReClock. But I am not sure anymore because the Info & CPU tab says this (with TrueHD track): Input description: 48000Hz, 6 channels truehd (libavcoced) Current bitrate: 5376 kbps Juitter: -11ms Does it really work with the full bitrate? Will it work with 24 bit if I insert a disc with 24 bit track? (I don't have any of them yet. -> Or I don't know, may be I see them as 16 bit because the softwares can't recognize the full track...) And it says this with another disc (with DTS-HD MA track): Input description: 48000Hz, 6 channels dts (libavcoced) Current bitrate: 1536 kbps Juitter: -11ms And here is the Processing tab with the allowed sample formats. How should I configure it with 16 bit sources, 16(/24) bit soundcard and none known additional sound processing? Or does FFDShow need to do some kind of processing anyway? So, if I don't care about the CPU utilization, then should I set it to 32 bit FP + dithering with light noise shaping (to minimize the rounding errors) or should I set it to 16 bit only without dithering (to avoid the unnecessary resample steps with additional dithering noise)? Does it even matter when I don't use any signal manipulation plugins? I have no idea... If there is some proessing (even without additional filters/plugins), then how should I set the output format? Should I enable the 32 bit FP processing only and set the output format to 24 bit (to minimize the rounding errors)? A last (and little) thing: Is there a chance to support ASIO (or may be OpenAL) outputs? This software Dsound is weird with Vista+ (after 2006...!). This is why I choose the ReClock WASAPI output. (But it is not as convincing as the ASIO or OpenAL plugins for Winamp.) I don't apply 23.976->24 fps speedup with it (I enabled the PAL speedup but I don't watch DVDs anymore.), so I use it only as a smarter audio renderer. Last edited by janos666; 14th August 2010 at 14:40. |
14th August 2010, 15:52 | #12238 | Link |
So is there any other technique that can be used to get the subtitles on the bottom of the screen when using DXVA? In MPC-HC this is possible, but as this is a standalone player, it's not really fair to compare. Is it possible to use the same technique for this as MPC-HC does? Or is this not possible with a standalone directshow codec?
14th August 2010, 17:32 | #12239 | Link | |
4:2:0 hater
I say at the moment because some time ago tal.aloni talked about DXVA substreams or something like that, not sure if it could be used for this or not. Either way tal is missing, so you should forget about it. Just use software decoding. |
15th August 2010, 08:24 | #12240 | Link |
I'm still around, PM if you need anything.
DXVA substreams has the same limitations as our software overlay method when it comes to where we can place subtitles, so it's not going to help here. p.s. it's not possible to use the same technique as MPC-HC does, because MPC-HC has control over the renderer. |
