Old 13th May 2006, 19:03   #221  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
@dimzon you finaly back, can you check aslo this bug in encaacplus.exe
Originally Posted by shon3i
@dimzon i founded one small bug into enc_aacPlus.exe. When use LC-AAC and MP4 container i get fake SBR which have 88.2kHz instead 44kHz and in foobar says that is SBR present but insn't when i remuxed this file with YAMB everything is fine, that is probably because you forgot to clear switch -sbr in mp4box comandline for LC-AAC.
shon3i is offline   Reply With Quote
Old 13th May 2006, 19:08   #222  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
Just one question - does anybody still need this encoder since 100% free and legal solution from Nero are avaluable?
dimzon is offline   Reply With Quote
Old 13th May 2006, 19:11   #223  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
I think just me
Old 13th May 2006, 19:46   #224  |  Link
NorthPole
Not me! Using either the free nero encoder or the new ffmpeg encoder.
NorthPole is offline   Reply With Quote
Old 15th May 2006, 14:37   #225  |  Link
dimzon
dimzon's Avatar
done
Old 15th May 2006, 15:02   #226  |  Link
dimzon
dimzon's Avatar
Ok, second name for this Effect is Wavesharper
There are big amount of such formulas
http://musicdsp.org/archive.php?classid=4#207
http://www.google.com/search?lr=&ie=...8&q=Waveshaper
and finally found good approximation
http://img217.imageshack.us/img217/1803/testnew6pc.png
yellow is tera
pink is .55 * Math.Atan(6*x)
Some code from LigH
http://www.ligh.de/software/booster.zip
const
  HalfPi = Pi/2;
function BoostStrong(Value: Single): Single;
begin
  Result := TanH(Value);
end;
function BoostMedium(Value: Single): Single;
begin
  Result := ArcTan(Value*HalfPi)*HalfPi;
end;
function BoostSoft(Value: Single): Single;
begin
  Result := Value/(Abs(Value)+1);
end;
Another good news is BeHappy is now @ third place
Old 15th May 2006, 16:30   #227  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
done
Nice, everything work pefertly now. Thanks
Old 16th May 2006, 01:30   #228  |  Link
dimzon
dimzon's Avatar
new UNSTABLE version is out
get it @ BeHappy workspace at Your own risk
Old 16th May 2006, 02:48   #229  |  Link
Yama4050242
DeadFat
both BeHappy & megui do not support nero 2pass? why?
Yama4050242 is offline   Reply With Quote
Old 16th May 2006, 07:15   #230  |  Link
buzzqw
HDConvertToX author
Using avisynth isn't possibile to do a 2 pass encoding (with piping).
Behappy should first dump the wav file then do the 2 pass encoding... it's a quite long process
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 16th May 2006, 11:38   #231  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
@dimzon, one question:
did you include new CT dialog or not
and can you use mp4 for default extesion insted m4a
Old 16th May 2006, 12:18   #232  |  Link
buzzqw
HDConvertToX author
afaik mp4 mean m4a muxed into mp4 container... so is different from m4a
BHH
Old 16th May 2006, 12:38   #233  |  Link
dimzon
dimzon's Avatar
Wrong! m4a is AAC in MP4 container. So it's just mp4 renamed to m4a
Not yet.
Personally I prefer m4a for audio-only and mp4 for audio+video
bcz I'm using foobar2000 to play m4a (via file association) and MPC to play mp4 (via file association)...
Actually I believe that different extension for audio-only media is good way:
  • RIFF: WAV & AVI
  • ASF: WMA & WMV
  • Matroska: MKA & MKV
  • MP4: M4A & MP4
  • OGM: OGG & OGM
Old 16th May 2006, 12:55   #234  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
damn, i just prefer mp4 for both audio and video, can you in next release show nero and ct encoders as extension, so than i can change this manunaly, if that possible
Not yet.
approx.
Old 16th May 2006, 13:16   #235  |  Link
dimzon
dimzon's Avatar
approx.
Hmm... Maybe I will add ability to use last used extension by default instead first from the list.
Old 16th May 2006, 13:33   #236  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
@Dimzon : looking at the Lame picture, the window title is wrong I think.
We can store also mp3 and alac into the m4a.
Old 16th May 2006, 13:49   #237  |  Link
dimzon
dimzon's Avatar
Copy/Paste - the greatest programming paradigm
Agreed
Old 16th May 2006, 15:53   #238  |  Link
Rockaria
nobody's nobody
Also do you agree that you don't need to (& should not) use my id in your project as I said long ago? It is not only reflecting the reality wrongfully, I am not feeling any honered by those kind of fixture at all.
It's not a simple idea, but a complete set of my philosophy through my own career. I have been independant since very long ago, so should it be reflected as such.
u know everything in the end, or now if aligned... no right(x).right(y) pls. it's confusing... : phase-shift /Jun.2006
Rockaria is offline   Reply With Quote
Old 17th May 2006, 02:32   #239  |  Link
SirLamer
I am having trouble getting this to run. I know I am doing something dumb, but... I need help! heh
When I try to convert from an AC3 into AAC using BeHappy, I get this error log:
Starting job VTS_01_1 01 en-English 3_2ch 448Kbps DELAY 0ms.ac3->moulin rouge audio.mp4
Error: BeHappy.AviSynthException: Script error: there is no function named "NicAc3Source"
at BeHappy.AviSynthClip..ctor(String func, String arg, AviSynthColorspace forceColorspace, AviSynthScriptEnvironment env)
at BeHappy.Encoder.encode()
I have put NicAudio.dll in the MeGUI folder (where I put BeHappy as well) and AviSynth's plugins folder. Does anyone have any ideas?
Also, I am curious - while I know AAC supports 96kHz sample rates, does it also support 24bit fidelity? I have found nothing that says it is either 16bit or 24bit. Does anyone know?
SirLamer is offline   Reply With Quote
Old 17th May 2006, 05:17   #240  |  Link
SirLamer
Hey,
I found out that the error is because the generated AviSynth script is missing a line of code:
LoadPlugin("NicAudio.dll")
It sould appear before the nic script is called.
behappy
